Ошибка при загрузке прошивки в Arduino Mega2560 r3
Christian_e
Какая-то не типичная ошибочка. Никто не сталкивался?
Sketch uses 1 662 bytes (0%) of program storage space. Maximum is 258 048 bytes.
Global variables use 11 bytes (0%) of dynamic memory, leaving 8 181 bytes for local variables. Maximum is 8 192 bytes.
C:\Program Files\Arduino/hardware/tools/avr/bin/avrdude -CC:\Program Files\Arduino/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cwiring -PCOM4 -b115200 -D -Uflash:w:C:\DOCUME~1\Admin\LOCALS~1\Temp\build6247594239807316646.tmp/Blink.cpp.hex:i
avrdude: Version 5.11, compiled on Sep  2 2011 at 19:38:36
         Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "C:\Program Files\Arduino/hardware/tools/avr/etc/avrdude.conf"
         Using Port                    : COM4
         Using Programmer              : wiring
         Overriding Baud Rate          : 115200
avrdude: wiring_open(): releasing DTR/RTS
avrdude: wiring_open(): asserting DTR/RTS
avrdude: Send: . [1b] . [01] . [00] . [01] . [0e] . [01] . [14]
avrdude: Recv: . [1b]
avrdude: Recv: . [01]
avrdude: Recv: . [00]
avrdude: Recv: . [0b]
avrdude: Recv: . [0e]
avrdude: Recv: . [08]
avrdude: Recv: A [41]
avrdude: Recv: V [56]
avrdude: Recv: R [52]
avrdude: Recv: I [49]
avrdude: Recv: S [53]
avrdude: Recv: P [50]
avrdude: Recv: _ [5f]
avrdude: Recv: 2 [32]
avrdude: Recv: t [74]
avrdude: stk500v2_getsync(): found AVRISP programmer
         AVR Part                      : ATMEGA2560
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    10     8    0 no       4096    8      0  9000  9000 0x00 0x00
           flash         65    10   256    0 yes    262144  256   1024  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Wiring
         Description     : Wiring
         Programmer Model: AVRISP
avrdude: Send: . [1b] . [02] . [00] . [02] . [0e] . [03] . [90] . [86]
avrdude: Recv: . [02]
avrdude: Recv: . [03]
avrdude: Recv: . [0f]
avrdude: Recv: . [18]
avrdude: Send: . [1b] . [03] . [00] . [02] . [0e] . [03] . [91] . [86]
avrdude: ser_send(): size/send mismatch
Puhlyaviy
Puhlyaviy аватар
перепрошивать нужно аднака
Christian_e
Который контроллер? Atmega8u2?
Puhlyaviy
Puhlyaviy аватар
там один контролер который эмулирует компорт и шьет 2560.. ну можете скечи напрямую в 2560 заливать, способов извратиться куча и тележка
Christian_e
Давайте уточним. Там мега8u2 которая эмулирует полноценный 232 с дтр. Когда я начинаю заливать через уарт в2560 через него пролетает один байт. Дальше собственно ошибка. Т.е. 2560 что-то отвечает и затыкается. Нужно перешить 2560 внешним программатором?
Puhlyaviy
Puhlyaviy аватар
2560 не нужно трогать!
нужно перепрошить 8u2
Christian_e
Запускаю FLIP, после сброса устройство определяется как Atmega16u2(смотрел - на плате оно и установлено), FLIP к нему цепляется. Дальше - ерасит, шьет и проверяет - проверка не проходит на 0 адресе. Какбуд- то защищено от записи. Что посоветуете?
NeiroN
NeiroN аватар
USB-ISP попробуй
Christian_e
C FlIP разобрался. Однако после перепрошивки 16u2 все таже ошибка. ничего залить в 2560 не могу.
Christian_e
у меня 4 штуки разных программаторов, но я хочу разобраться как это должно работать по задумке разработчика. Залить через внешний программатор не проблема, но это не удобно и не правильно.
