Ошибка в get запросе
kirsanownic
Всем привет, не работает !!пример от ардуино, нужно отправить запрос вот сюда http://192.168.1.68:3000/
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// if you don't want to use DNS (and reduce your sketch size)
// use the numeric IP instead of the name for the server:
//IPAddress server(74,125,232,128);  // numeric IP for Google (no DNS)
char server[] = "http://192.168.1.68";    // name address for Google (using DNS)
// Set the static IP address to use if the DHCP fails to assign
IPAddress ip(192, 168, 1, 68);
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
EthernetClient client;
  // Open serial communications and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  // start the Ethernet connection:
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    // try to congifure using IP address instead of DHCP:
    Ethernet.begin(mac, ip);
  // give the Ethernet shield a second to initialize:
  Serial.println("connecting...");
  // if you get a connection, report back via serial:
  if (client.connect(server, 80)) {
    Serial.println("connected");
    // Make a HTTP request:
    client.println("GET /measurements HTTP/1.1");
    client.println("Host: 192.168.1.68:3000/");
    client.println("Connection: close");
    client.println();
  } else {
    // if you didn't get a connection to the server:
    Serial.println("connection failed");
  // if there are incoming bytes available
  // from the server, read them and print them:
  if (client.available()) {
    char c = client.read();
    Serial.print(c);
  // if the server's disconnected, stop the client:
  if (!client.connected()) {
    Serial.println();
    Serial.println("disconnecting.");
    client.stop();
    // do nothing forevermore:
    while (true);
DIYMan
DIYMan аватар
Неправильный GET-запрос: Во-первых - сервер на порту 3000, а вы коннектитесь к порту 80, зашибись. Во-вторых - в заголовке Host не надо указывать номер порта, номер порта нужен для коннекта к серверу.
Короче, мои намёки на то, что вам надо почитать основы HTTP - прошли мимо ушей, так? Вместо этого будем каждый раз наступать на одни и те же грабли, вымаливая кусочек готового кода - щас так модно, говорят.
kirsanownic пишет:
Привет! Не работают мозги у юзера kirsanownic, которому посоветовали почитать описание протокола, но он клал на это и предпочитает выставлять себя идиотом.
