Ошибка во время выполнения скетча.
Пнд, 06/11/2017 - 20:47
Здравствуйте, мой скетч не выполняется, а точнее просто замораживается. Есть следующий код
#include <QList.h>
#include "QList.cpp"
#include <TimerOne.h>
volatile QList <byte> mySignal;
// This example uses the timer interrupt to blink an LED
// and also demonstrates how to share a variable between
// the interrupt and the main program.
void setup(void)
pinMode(LED_BUILTIN, OUTPUT);
//Timer1.initialize(100000);// в микросекундах
Timer1.initialize(300000);// в микросекундах
Timer1.attachInterrupt(blinkLED); // blinkLED to run every 0.10 seconds
// The interrupt will blink the LED, and keep
// track of how many times it has blinked.
int ledState = LOW;
volatile unsigned long blinkCount = 0; // use volatile for shared variables
void blinkLED(void)
if (ledState == LOW) {
ledState = HIGH;
blinkCount = blinkCount + 1; // increase when LED turns on
} else {
ledState = LOW;
digitalWrite(LED_BUILTIN, ledState);
addItemSignal();
// The main program will print the blink count
// to the Arduino Serial Monitor
void loop(void)
QList <byte> signalCopy; // holds a copy of the mySignal
// to read a variable which the interrupt code writes, we
// must temporarily disable interrupts, to be sure it will
// not change while we are reading. To minimize the time
// with interrupts off, just quickly make a copy, and then
// use the copy while allowing the interrupt to keep working.
//int m1=millis();
noInterrupts();
// тут прочитать стек
int signalSize=mySignal.size();
for (int i=0;i<signalSize;i++){
signalCopy.push_back(mySignal.get(i));
interrupts();
//int m2=millis();
//Serial.println(m2-m1);
//Serial.print(signalCopy.get(signalSize-i-1));
Serial.print(signalCopy.get(i));
Serial.print(" ");
Serial.println();
//тут будет DTW
noInterrupts();
Serial.print("num - ");
Serial.print(signalCopy.size());
interrupts();
int disctance=DTWrun(signalCopy,signalCopy);
noInterrupts();
Serial.print(" distance ");
Serial.print(disctance);
Serial.println();
interrupts();
void addItemSignal(){
int curSig=analogRead(A0);
if(curSig>255){
curSig=255;
Serial.println("aaa");
//Serial.println(mySignal.size());
if (mySignal.size()>5){
mySignal.pop_back();
mySignal.push_front((byte)curSig);
int DTWrun( QList <byte> v, QList <byte> w ) {
int cost;
int mGamma [v.size()+1][w.size()+1];
for( int i = 1; i <= w.size(); i++ ) {
mGamma[0][i] = 0;
for( int i = 1; i <= v.size(); i++ ) {
mGamma[i][0] = 0;
mGamma[0][0] = 0;
for( int j = 1; j <= w.size(); j++ ) {
// cost = abs( v[i] - w[j] ) * abs( v[i] - w[j] );
if( v.get(i - 1) == w.get(j - 1) ) {
cost = 0;
else {
cost = 1;
mGamma[i][j] = cost + min( mGamma[i-1][j], min(mGamma[i][j-1], mGamma[i-1][j-1]) );
return 10;
Вывод:
num - 0 distance 10
num - 0 distance 10
num - 0 distance 10
num - 0 distance 10
num - 0aaa
distance 10
num - 1 distance 10
num - 1aaa
distance :⸮⸮
num - 2aa
Ошибка происходить на 78 строчке. После этого перестают работать прерывания (не мигает светодиод, не добывляются новые элементы в список). Если убрать блок кода на 78 строке, все работает как часы. Во время. Стоит отметить что скетч крашится после того как в списке появляется первый элемент. Что я делаю не так?
Плата: Arduino Nano, процессор: ATmega 328P
Возможно, что у вашего QList нет деструктора, освобождающего память. Или вы его не вызываете. Поэтому, скорее всего на каждом лупе вы резервируете память при создании экземпляра QList и через несколько раундов она просто заканчивается, начинается запись в случайные ячейки, что приводит к аварийной ситуации.
Самое простое, думаю, сделать этот экземпляр глобальным и чистить его при заходе в луп, если это необходимо.
Как - не спрашивайте, я такой библиотеки даже и не знаю.
Судя по второй строке. Библиотека еще тем "гением" написана
Слава тебе, Господи, адекватный новичок появился! :)))
давайте, по порядку.
1. Удалите вторую строку. Если библиотека установлена правильно, оно и без неё должно работать.
2. Дайте ссылку на бибилотеку потому. что не видя её я не уверен в дальнейшем
3. например, скорее всего (но не видя библиотеки, трудно утверждать наверное), в строке 78 Вы теряете свой список. Вы передаёте два списка по значению. Если у них нет специального конструктора, то создаются новые экземпляры с теми же указателями и в памяти начинается каша.
Пока Вы мне не дали ссылки на библиотеку, попробуйте просто в строке 99 вместо
int DTWrun( QList <byte> v, QList <byte> w ) {написать
int DTWrun( QList <byte> & v, QList <byte> & w ) {и скажите мне поменялось что-то или нет. Должно поменяться.
И ещё, возьмите вот в этой теме программу memory Explorer (там есть примеры использования) и с её помощью последите за памятью. Может чего интересного увидите.
Как всё это сделаете. выложите свежий скетч и описание как он себя ведёт (ну и ссылку на библиотеку не забудьте).
и вот тут должно вешаца
079noInterrupts();080Serial.print(" distance ");081Serial.print(disctance);082Serial.println();аптамуш, хардсериал по прерываниям работает, а оне тут запрещаюца.
