pn532 i2c ошибка компиляции скетча
Пт, 22/09/2017 - 03:06
#if 0
#include <SPI.h>
#include <PN532_SPI.h>
#include "PN532.h"
PN532_SPI pn532spi(SPI, 10);
PN532 nfc(pn532spi);
#elif 0
#include <PN532_HSU.h>
#include <PN532.h>
PN532_HSU pn532hsu(Serial1);
PN532 nfc(pn532hsu);
#else
#include <Wire.h>
#include <PN532_I2C.h>
#include <PN532.h>
#endif
void setup(void) {
Serial.begin(115200);
Serial.println("Hello!");
nfc.begin();
uint32_t versiondata = nfc.getFirmwareVersion();
if (! versiondata) {
Serial.print("Didn't find PN53x board");
while (1); // halt
// Got ok data, print it out!
Serial.print("Found chip PN5"); Serial.println((versiondata>>24) & 0xFF, HEX);
Serial.print("Firmware ver. "); Serial.print((versiondata>>16) & 0xFF, DEC);
Serial.print('.'); Serial.println((versiondata>>8) & 0xFF, DEC);
// configure board to read RFID tags
nfc.SAMConfig();
Serial.println("Waiting for an ISO14443A Card ...");
void loop(void) {
uint8_t success;
uint8_t uid[] = { 0, 0, 0, 0, 0, 0, 0 }; // Buffer to store the returned UID
uint8_t uidLength; // Length of the UID (4 or 7 bytes depending on ISO14443A card type)
// Wait for an ISO14443A type cards (Mifare, etc.). When one is found
// 'uid' will be populated with the UID, and uidLength will indicate
// if the uid is 4 bytes (Mifare Classic) or 7 bytes (Mifare Ultralight)
success = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, uid, &uidLength);
if (success) {
// Display some basic information about the card
Serial.println("Found an ISO14443A card");
Serial.print(" UID Length: ");Serial.print(uidLength, DEC);Serial.println(" bytes");
Serial.print(" UID Value: ");
nfc.PrintHex(uid, uidLength);
Serial.println("");
if (uidLength == 4)
// We probably have a Mifare Classic card ...
Serial.println("Seems to be a Mifare Classic card (4 byte UID)");
// Now we need to try to authenticate it for read/write access
// Try with the factory default KeyA: 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF
Serial.println("Trying to authenticate block 4 with default KEYA value");
uint8_t keya[6] = { 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF };
// Start with block 4 (the first block of sector 1) since sector 0
// contains the manufacturer data and it's probably better just
// to leave it alone unless you know what you're doing
success = nfc.mifareclassic_AuthenticateBlock(uid, uidLength, 4, 0, keya);
if (success)
Serial.println("Sector 1 (Blocks 4..7) has been authenticated");
uint8_t data[16];
// If you want to write something to block 4 to test with, uncomment
// the following line and this text should be read back in a minute
// data = { 'a', 'd', 'a', 'f', 'r', 'u', 'i', 't', '.', 'c', 'o', 'm', 0, 0, 0, 0};
// success = nfc.mifareclassic_WriteDataBlock (4, data);
// Try to read the contents of block 4
success = nfc.mifareclassic_ReadDataBlock(4, data);
if (success)
// Data seems to have been read ... spit it out
Serial.println("Reading Block 4:");
nfc.PrintHexChar(data, 16);
Serial.println("");
// Wait a bit before reading the card again
Serial.println("Ooops ... unable to read the requested block. Try another key?");
Serial.println("Ooops ... authentication failed: Try another key?");
if (uidLength == 7)
// We probably have a Mifare Ultralight card ...
Serial.println("Seems to be a Mifare Ultralight tag (7 byte UID)");
// Try to read the first general-purpose user page (#4)
Serial.println("Reading page 4");
uint8_t data[32];
success = nfc.mifareultralight_ReadPage (4, data);
if (success)
nfc.PrintHexChar(data, 4);
Serial.println("");
Serial.println("Ooops ... unable to read the requested page!?");
ОШИБКА: Arduino: 1.8.4 (Linux), Плата:"Arduino Nano, ATmega328P"
Несколько библиотек найдено для "Wire.h"
Используется: /home/alexdelux/arduino-1.8.4/hardware/arduino/avr/libraries/Wire
Не используется: /home/alexdelux/arduino-1.8.4/libraries/nfcpn532
/tmp/arduino_modified_sketch_120435/readMifare.pde: In function 'void setup()':
readMifare:24: error: 'nfc' was not declared in this scope
nfc.begin();
/tmp/arduino_modified_sketch_120435/readMifare.pde: In function 'void loop()':
readMifare:51: error: 'nfc' was not declared in this scope
exit status 1
как решить проблему? должно работать вроде бы без колдовства
разберись вот с этим
#if 0002#include <SPI.h>003#include <PN532_SPI.h>004#include "PN532.h"005006PN532_SPI pn532spi(SPI, 10);007PN532 nfc(pn532spi);008#elif 0009#include <PN532_HSU.h>010#include <PN532.h>011012PN532_HSU pn532hsu(Serial1);013PN532 nfc(pn532hsu);014#else015#include <Wire.h>016#include <PN532_I2C.h>017#include <PN532.h>018#endifдо объявления nfc дело не доходит
не понял юмора, просто дописать PN532 nfc(pn532i2c) чтоли?
не понял юмора,
Понятно :(
Строки 6 и 7 перенесите вниз, после 18-ой
не пашет, вы могли бы в двух словах прокоментировать такое решение?
я в курсе что такое область видимости но не могу понять почему не пашет, вроде бы все описано
причем строки 6-7 есть мне надо по i2c работало шоб?
Что значит "не пашет"? Не компилируется или не работает? Если не компилируется, то скорее всего по другой причине. Когда говорите такие слова, публикуйте текущий скетч и сообщения об ошибках.
Что описано? Вам DetSimen, вроде же всё объяснил.
ЕСЛИ 0 равно 1, то компилировать строки 2-7 (а нет, так забить на них)
а в строках 15-17 нету обьявления nfc, хоть ты лопни.
#if 0 #include <SPI.h> #include <PN532_SPI.h> #include "PN532.h" PN532_SPI pn532spi(SPI, 10); PN532 nfc(pn532spi); #elif 0 #include <PN532_HSU.h> #include <PN532.h> PN532_HSU pn532hsu(Serial1); PN532 nfc(pn532hsu); #else #include <Wire.h> #include <PN532_I2C.h> #include <PN532.h> PN532_I2C pn532i2c(Wire); PN532 nfc(pn532i2c); #endifРабочий вариант
тогда, если строки с 1 по 14 выкинуть, и 20-ю заодно, то тоже будет рабочий вариант
