Поделитесь библиотекой util/parity.h
Втр, 20/06/2017 - 00:41
Поделитесь, пожалуйста,библиотекой util/parity.h. Пол дня ищу и немогу найти в инете.
библиотека называется parity.h и лежит в папке util
/* Copyright (c) 2002, Marek Michalkiewicz Copyright (c) 2004,2005,2007 Joerg Wunsch All rights reserved. Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met: * Redistributions of source code must retain the above copyright notice, this list of conditions and the following disclaimer. * Redistributions in binary form must reproduce the above copyright notice, this list of conditions and the following disclaimer in the documentation and/or other materials provided with the distribution. * Neither the name of the copyright holders nor the names of contributors may be used to endorse or promote products derived from this software without specific prior written permission. THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */ /* $Id$ */ #ifndef _UTIL_PARITY_H_ #define _UTIL_PARITY_H_ /** \file */ /** \defgroup util_parity <util/parity.h>: Parity bit generation \code #include <util/parity.h> \endcode This header file contains optimized assembler code to calculate the parity bit for a byte. */ /** \def parity_even_bit \ingroup util_parity \returns 1 if \c val has an odd number of bits set. */ #define parity_even_bit(val) \ (__extension__({ \ unsigned char __t; \ __asm__ ( \ "mov __tmp_reg__,%0" "\n\t" \ "swap %0" "\n\t" \ "eor %0,__tmp_reg__" "\n\t" \ "mov __tmp_reg__,%0" "\n\t" \ "lsr %0" "\n\t" \ "lsr %0" "\n\t" \ "eor %0,__tmp_reg__" \ : "=r" (__t) \ : "0" ((unsigned char)(val)) \ : "r0" \ ); \ (((__t + 1) >> 1) & 1); \ })) #endif /* _UTIL_PARITY_H_ */Так нету у меня такой папки util и файла parity.h
Не звизди.
Эта библиотека уже есть в Arduino IDE, ничего искать не надо (arduino\hardware\tools\avr\avr\include\util\parity.h)
Просто пишешь #include <util/parity.h> и всё, библиотека подключается.
