Подружить Arduino и OLED-дисплей Winstar 128x32
Tomasina
Tomasina аватар
Есть такой графический дисплей Winstar WEG010032B.
Аннотация к дисплею и даташит на контроллер WS0010.
Техподдержка на просьбу прислать демо-код для Arduino прислала пример на C++:
//          WINSTAR Display Co.,Ltd
//    LCM        :WEG10016
//    Contraller :
//    Author     :Brian lin 2010/12/13
//    history     :
#include  <reg51.h>
#include  <stdio.h>          // define I/O functions
#include  <INTRINS.H>        // KEIL FUNCTION
#define one   0x80 // DD RAM Address 第一行之起始位置0x00
// 所以設定DD RAM位址為0x80+0x00=0x80
#define two   0xc0 // DD RAM Address 第二行之起始位置0x40
// 所以設定DD RAM位址為0x80+0x40=0xc0
#define Data_BUS  P1
#define TOP   0
#define DOWN  1
#define LEFT    2
#define RIGHT 3
#define ALLCHIP 0x03
#define CHIP1 0x01
#define CHIP2 0x02
sbit    busy    = P1 ^ 7;
sbit    RS      = P2 ^ 4; //for new test board
sbit    RW      = P3 ^ 7;
sbit    Enable  = P3 ^ 4;
sbit    CS1  = P2 ^ 3; //for new test board
sbit    CS2  = P3 ^ 6;
char bdata  flag;
sbit busy_f  = flag ^ 0;
void CheckBusy(void);
void WriteIns(unsigned char);
void WriteData(unsigned char);
void WriteString(unsigned char, unsigned char *);
void Initial_ks0066();
void delay(unsigned char);
void WriteIns(unsigned char instruction)
  RS = 0;
  RW = 0;
  Data_BUS = instruction;
  Enable = 1;            //1us
  _nop_();   //1us
  Enable = 0;    //1us
  Data_BUS = 0xff; //訊號由high變為low比較容易,所以全部設為high.
  RS = 0;
  RW = 1;
  do
    Enable = 1;
    busy_f = busy;
    Enable = 0;
  } while (busy_f);
void WriteCmd(unsigned char instruction)
  RS = 0;
  RW = 0;
  Enable = 1;            //1us
  _nop_();   //1us
  Enable = 0;    //1us
  CheckBusy();
void WriteData(unsigned char data1)
  RS = 1;
  RW = 0;
  Data_BUS = data1;
  Enable = 1;
  _nop_();
  Enable = 0;
  CheckBusy();
/*void WriteString(unsigned char count,unsigned char * MSG)
  unsigned char i;
  for(i = 0; i<count;i++)
    WriteData(MSG[i]);
  void Clear(void)
  unsigned char i;
  //First line address
  WriteCmd(one);//X
  WriteCmd(0x40);//Y
  for(i = 0; i<100;i++)
      WriteData(0x00);
  //Second line address
  WriteCmd(one);//X
  WriteCmd(0x41);//Y
      WriteData(0x00);
  void Fullon(void)
  unsigned char i;
  CS1=1; //disable chip1
  CS2=0; //enable chip2
  WriteCmd(one);//X
  WriteCmd(0x40);//Y
    WriteData(0xff);
  WriteCmd(one);//X
  WriteCmd(0x41);//Y
    WriteData(0xff);
/*void ShowPic(void)
  unsigned char i,j;
  CS2=0;//enable chip2*/
/*  //First line address
  WriteIns(one);//X
  WriteIns(0x40);//Y
    WriteData(pic[0][i]);
  WriteIns(one);//X
  WriteIns(0x41);//Y
    WriteData(pic[1][i]);*/
  for (j=0;j<18;j++)
    WriteCmd(one);
    WriteCmd(0x40);//Y
    for(i = 0; i<16;i++)
      WriteData(pic[j][i]);
    WriteCmd(one);
    WriteCmd(0x41);//Y
    for(i = 16; i<32;i++)
    delay(1);
void Show_Light(unsigned char pic[][32], unsigned char size)
  unsigned char i;
  CS1 = 0; //enable chip1
  CS2 = 1; //disable chip2
  //first line
  WriteCmd(one);//X
  WriteCmd(0x40);//Y
  for (i = 0; i < size; i++)
  //second line
  WriteCmd(one);//X
  WriteCmd(0x41);//Y
void Show_Light2(unsigned char pic[][100], unsigned char size)
//void Show_Pic(unsigned char pic[][100],unsigned char size)
  unsigned char i;
  //first line
  WriteCmd(one);//X
  WriteCmd(0x40);//Y
  //second line
  WriteCmd(one);//X
  WriteCmd(0x41);//Y
void Show_Pic2(unsigned char pic[][100], unsigned char size)
  unsigned char i;
  //first line
  WriteCmd(one);//X
  WriteCmd(0x40);//Y
  //second line
  WriteCmd(one);//X
  WriteCmd(0x41);//Y
  delay(5);
  CS1 = 1; //disable chip1
  CS2 = 0; //enable chip2
  //first line
  WriteCmd(one);//X
  WriteCmd(0x40);//Y
    WriteData(pic[2][i]);
  //second line
  WriteCmd(one);//X
  WriteCmd(0x41);//Y
    WriteData(pic[3][i]);
void Show_Pic3(unsigned char pic[][32], unsigned char size, unsigned char order)
  unsigned char i, j, c = 0;
  if (order == 0)
    for (j = 0; j < 3; j++)
      //first line
      WriteCmd(one + 61); //X
      WriteCmd(0x40);//Y
        WriteData(pic[c + j][i]);
      //second line
      WriteCmd(0x41);//Y
        WriteData(pic[c + 1 + j][i]);
      delay(7);
      c++;
    c = 2;
    for (j = 3; j > 0; j--)
      //first line
      WriteCmd(one + 56); //X
      WriteCmd(0x40);//Y
        WriteData(pic[j + c - 1][i]);
      //second line
      WriteCmd(0x41);//Y
        WriteData(pic[j + c][i]);
      delay(7);
      c--;
void Show_Pic4(unsigned char pic[][100], unsigned char size)
  unsigned char i, j;
  for (j = 0; j < 4; j++)
    //first line
    WriteCmd(one);//X
    WriteCmd(0x40);//Y
      WriteData(pic[j * 4][i]);
    //second line
    WriteCmd(one);//X
    WriteCmd(0x41);//Y
      WriteData(pic[1 + j * 4][i]);
    //first line
    WriteCmd(one);//X
    WriteCmd(0x40);//Y
      WriteData(pic[2 + j * 4][i]);
    //second line
    WriteCmd(one);//X
    WriteCmd(0x41);//Y
      WriteData(pic[3 + j * 4][i]);
    delay(5);
void Show_Trigger(unsigned char pic[][8] , unsigned char size, unsigned char dir)
  unsigned char i;
  if (dir == LEFT)
    WriteCmd(one);
  if (dir == RIGHT)
    WriteCmd(one + 92);
  WriteCmd(0x40);//Y
  if (dir == LEFT)
    WriteCmd(one);
  if (dir == RIGHT)
    WriteCmd(one + 92);
  WriteIns(0x41);//Y
unsigned char Move_L(void)
  unsigned char i, j, m, value = 0;
  unsigned char nL = 84; //left
  for (m = 0; m < 5; m++)
    for (j = 0; j < 18; j++)
      //if ((nL-1)>=0)//nL-1=0表address為0x80
      if ((nL - 1) >= 8) //nL-1=8表address為0x88
        WriteCmd(one + nL - 1);
        WriteCmd(0x40);//Y
        for (i = 0; i < 16; i++)
        WriteCmd(0x41);//Y
        for (i = 16; i < 32; i++)
        delay(1);
        nL--;
  value = nL;
  return value;
unsigned char Move_R(void)
  unsigned char nR = 0; //right
      if (nR <= 75)
        WriteCmd(one + nR);
        WriteCmd(0x40);//Y
          WriteData(pic1[j][i]);
        WriteCmd(one + nR);
        WriteCmd(0x41);//Y
        delay(1);
        nR++;
  value = nR;
  return value;
void Scroll(unsigned char val)
  unsigned char i, tmp1 = 0, tmp2 = 0;
  for (i = 0; i < 100; i++)
    if (val == TOP)
      dat[i] = _iror_(dat[i], 1); //left circular shift one bit for int
    else if (val == DOWN)
      dat[i] = _irol_(dat[i], 1); //left circular shift one bit for int
  WriteIns(one);//X
  WriteIns(0x40);//Y
    tmp1 = dat[i] >> 8;
    WriteData(tmp1);
  WriteIns(one);//X
  WriteIns(0x41);//Y
    tmp2 = dat[i];
    WriteData(tmp2);
void Initial_ks0066(void)
  //Enable=0;
  WriteIns(0x38);//function set
  WriteCmd(0x08);//display off
  WriteCmd(0x06);//entry mode set
  /*WriteCmd(0x13,ALLCHIP);//Character mode
    WriteCmd(0x01,ALLCHIP);//clear display
    WriteCmd(0x02,ALLCHIP);*/
  WriteCmd(0x1f);//Graphic mode //80x16(seg=5x16=80,com=8x2=16)
  WriteCmd(0x01);//clear display
  WriteCmd(0x02);
  WriteCmd(0x0c);//display on
  delay(20);
void delay(unsigned char m)
  unsigned char i, j, k;
  for (j = 0; j < m; j++)
    for (k = 0; k < 200; k++)
void main(void)
  unsigned char i, j, k = 0;
  /*Enable=0;
    CS1=0; //enable chip1
    CS2=1;//disable chip2*/
  Initial_ks0066();
  /*Enable=0;
    Initial_ks0066();*/
  /*Fullon();
    delay(30);*/
  while (1)
    //show strings
    Show_Pic2(pic6, 100);
    delay(15);
    Show_Pic3(pic11, 32, 0);
    delay(30);
    Show_Light(pic2, 32);
    k = Move_L();
    Show_Trigger(pic3, 8, LEFT);
      WriteCmd(one + k);
      WriteCmd(0x40);//Y
        WriteData(pic[18 + j][i]);
      WriteCmd(one + k);
      WriteCmd(0x41);//Y
      delay(1);
    Show_Light(pic2_1, 32);
    delay(30);
    //delay(5);
    Show_Pic2(pic7, 100);
    delay(30);
      dat[i] = pic7[0][i];
      dat[i] = dat[i] << 8;
      dat[i] |= pic7[1][i];
      Scroll(TOP);
      delay(2);
    delay(10);
      dat[i] = pic7[2][i];
      dat[i] |= pic7[3][i];
      Scroll(TOP);
      delay(2);
    delay(30);
    Show_Pic2(pic8, 100);
    delay(15);
    Show_Pic3(pic11, 32, 1);
    delay(30);
    k = Move_R();
    Show_Trigger(pic5, 8, RIGHT);
      WriteCmd(one + k);
      WriteCmd(0x40);//Y
        WriteData(pic1[18 + j][i]);
      WriteCmd(one + k);
      WriteCmd(0x41);//Y
      delay(1);
    Show_Light2(pic4, 100);
    //Show_Pic(pic4,100);
    delay(30);
    //Show_Pic2(pic9,100);
    Show_Pic4(pic9, 100);
    delay(30);
    Show_Pic2(pic10, 100);
    delay(30);
      dat[i] = pic10[0][i];
      dat[i] |= pic10[1][i];
      Scroll(DOWN);
      delay(2);
    delay(10);
      dat[i] = pic10[2][i];
      dat[i] |= pic10[3][i];
      Scroll(DOWN);
      delay(2);
    delay(40);
unsigned int idata dat[100] = {0};
unsigned char code pic[22][32] = { //little green people
  0x00, 0x00, 0x00, 0x04, 0x8E, 0xFE, 0xF4, 0xE0,
  0x20, 0x40, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x21, 0x20, 0x10, 0x08, 0x07,
  0x03, 0x04, 0x09, 0x10, 0x60, 0x00, 0x00, 0x00,
  0x20, 0x40, 0x80, 0x80, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x61, 0x61, 0x50, 0x38, 0x07,
  0x03, 0x04, 0x09, 0x58, 0x60, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x04, 0x0E, 0xFE, 0xF4, 0xE0,
  0x20, 0x20, 0x40, 0x80, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x40, 0x41, 0x40, 0x38, 0x07,
  0x03, 0x04, 0x08, 0x48, 0x70, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x41, 0x58, 0x64, 0x03,
  0x03, 0x2C, 0x28, 0x19, 0x00, 0x00, 0x00, 0x00,
  0xA0, 0x60, 0xC0, 0x80, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x41, 0xF8, 0xE5, 0x07,
  0x07, 0x0D, 0x39, 0x39, 0x78, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x04, 0x0E, 0x7E, 0xF4, 0xA0,
  0x40, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0xB8, 0xE5, 0x07,
  0x0E, 0x11, 0x10, 0x60, 0x00, 0x00, 0x00, 0x00,
  0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x98, 0xA5, 0xE7, 0x0F,
  0x10, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x04, 0x0E, 0x7E, 0xF4, 0xE0,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x04, 0x03, 0x5F,
  0x17, 0x7C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x04, 0x8E, 0xBE, 0xF4, 0xE0,
  0xE0, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x20, 0x28, 0x37, 0x0F,
  0x5F, 0x90, 0xE0, 0x80, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x11, 0x10, 0x08, 0x04, 0x03,
  0x00, 0x00, 0x00, 0x41, 0x40, 0x40, 0x38, 0x07,
  0x03, 0x04, 0x08, 0x48, 0x30, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x01, 0x40, 0x58, 0x64, 0x03,
  0x03, 0x2C, 0x29, 0x18, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0xA8, 0xE5, 0x07,
  0x00, 0x00, 0x00, 0x00, 0x04, 0x7E, 0xFE, 0xF4,
  0x00, 0x00, 0x00, 0x00, 0x00, 0xB8, 0xE5, 0xE7,
  0x0F, 0x11, 0x70, 0x60, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0xB8, 0xA5, 0xE7, 0x0F,
  0x5F, 0x98, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00,
  0xE0, 0xC0, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x21, 0x20, 0x38, 0x3F, 0x0F,
  0x5F, 0x94, 0xE9, 0x90, 0x60, 0x00, 0x00, 0x00,
  //stop
  0x00, 0x00, 0x00, 0x44, 0x2E, 0xFE, 0xF4, 0xE0,
  0x00, 0x00, 0x00, 0x20, 0x20, 0x10, 0x08, 0x07,
  0x00, 0x00, 0x40, 0x44, 0x2E, 0xFE, 0xF4, 0xE0,
  0x03, 0x04, 0x09, 0x10, 0x60, 0x00, 0x00, 0x00 ,
  0x10, 0x20, 0x40, 0x44, 0x2E, 0xFE, 0xF4, 0xE0,
  0x00, 0x80, 0x40, 0x44, 0x2E, 0xFE, 0xF4, 0xE0,
  0x01, 0x00, 0x00, 0x20, 0x20, 0x10, 0x08, 0x07,
unsigned char code pic1[22][32] = { //reverse for little green people
  0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x40, 0x20,
  0xE0, 0xF4, 0xFE, 0x8E, 0x04, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x60, 0x10, 0x09, 0x04, 0x03,
  0x07, 0x08, 0x10, 0x20, 0x21, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x80, 0x80, 0x40, 0x20,
  0x00, 0x00, 0x00, 0x60, 0x58, 0x09, 0x04, 0x03,
  0x07, 0x38, 0x50, 0x61, 0x61, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x80, 0x40, 0x20, 0x20,
  0xE0, 0xF4, 0xFE, 0x0E, 0x04, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x70, 0x48, 0x08, 0x04, 0x03,
  0x07, 0x38, 0x40, 0x41, 0x40, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x19, 0x28, 0x2C, 0x03,
  0x03, 0x64, 0x58, 0x41, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x80, 0xC0, 0x60, 0xA0,
  0x00, 0x00, 0x00, 0x78, 0x39, 0x39, 0x0D, 0x07,
  0x07, 0xE5, 0xF8, 0x41, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x40,
  0xA0, 0xF4, 0x7E, 0x0E, 0x04, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x60, 0x10, 0x11, 0x0E,
  0x07, 0xE5, 0xB8, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x60, 0x10,
  0x0F, 0xE7, 0xA5, 0x98, 0x00, 0x00, 0x00, 0x00,
  0xE0, 0xF4, 0x7E, 0x0E, 0x04, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7C, 0x17,
  0x5F, 0x03, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC0, 0xE0,
  0xE0, 0xF4, 0xBE, 0x8E, 0x04, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x80, 0xE0, 0x90, 0x5F,
  0x0F, 0x37, 0x28, 0x20, 0x00, 0x00, 0x00, 0x00,
  0x03, 0x04, 0x08, 0x10, 0x11, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x30, 0x48, 0x08, 0x04, 0x03,
  0x07, 0x38, 0x40, 0x40, 0x41, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x18, 0x29, 0x2C, 0x03,
  0x03, 0x64, 0x58, 0x40, 0x01, 0x00, 0x00, 0x00,
  0x07, 0xE5, 0xA8, 0x00, 0x00, 0x00, 0x00, 0x00,
  0xF4, 0xFE, 0x7E, 0x04, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x60, 0x70, 0x11, 0x0F,
  0xE7, 0xE5, 0xB8, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x0F, 0xE7, 0xA5, 0xB8, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x60, 0x98, 0x5F,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0xC0, 0xE0,
  0x00, 0x00, 0x00, 0x60, 0x90, 0xE9, 0x94, 0x5F,
  0x0F, 0x3F, 0x38, 0x20, 0x21, 0x00, 0x00, 0x00,
  //stop
  0xE0, 0xF4, 0xFE, 0x2E, 0x44, 0x00, 0x00, 0x00,
  0x07, 0x08, 0x10, 0x20, 0x20, 0x00, 0x00, 0x00,
  0xE0, 0xF4, 0xFE, 0x2E, 0x44, 0x40, 0x00, 0x00,
  0xE0, 0xF4, 0xFE, 0x2E, 0x44, 0x40, 0x20, 0x10,
  0xE0, 0xF4, 0xFE, 0x2E, 0x44, 0x40, 0x80, 0x00,
  0x07, 0x08, 0x10, 0x20, 0x20, 0x00, 0x00, 0x01
unsigned char code pic2[2][32] = { //light
  0x00, 0x00, 0x40, 0x40, 0x40, 0x42, 0x44, 0x48,
  0x10, 0xC0, 0xE0, 0xF0, 0x7F, 0x7D, 0x3D, 0x05,
  0x05, 0x3D, 0x7D, 0x7F, 0xF0, 0xE0, 0xC0, 0x10,
  0x48, 0x44, 0x42, 0x40, 0x40, 0x40, 0x00, 0x00,
  0x00, 0x00, 0x05, 0x05, 0x05, 0x85, 0x45, 0x25,
  0x10, 0x07, 0x0F, 0x1F, 0x3C, 0x3C, 0x3F, 0x3F,
  0x3C, 0x3F, 0x3F, 0x3C, 0x1F, 0x0F, 0x07, 0x10,
  0x25, 0x45, 0x85, 0x05, 0x05, 0x05, 0x00, 0x00
unsigned char code pic2_1[2][32] = { //light
  //light-1
  0x00, 0xC0, 0x20, 0x90, 0x4F, 0x45, 0x3D, 0x05,
  0x05, 0x3D, 0x45, 0x4F, 0x90, 0x20, 0xC0, 0x00,
  0x00, 0x07, 0x08, 0x13, 0x24, 0x24, 0x23, 0x27,
  0x24, 0x23, 0x27, 0x24, 0x13, 0x08, 0x07, 0x00,
unsigned char code pic3[2][8] = { //trigger
  0xFF, 0xFF, 0xFF, 0xFF, 0xC0, 0xC0, 0xC0, 0xC0,
  0xFF, 0xFF, 0xFF, 0xFF, 0x01, 0x01, 0x01, 0x01
unsigned char code pic4[2][100] = { //light2
  0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x80, 0x84,
  0x88, 0x90, 0x21, 0x02, 0x04, 0xE0, 0x18, 0x04,
  0xC2, 0x22, 0x12, 0x12, 0x12, 0x12, 0x22, 0xC2,
  0x02, 0x12, 0xF2, 0x12, 0x02, 0x02, 0x02, 0x02,
  0x12, 0xF2, 0x12, 0x12, 0x92, 0x32, 0x02, 0x12,
  0xF2, 0x12, 0x12, 0x12, 0x12, 0x22, 0xC2, 0x04,
  0x18, 0xE0, 0x00, 0x04, 0x02, 0x21, 0x90, 0x88,
  0x84, 0x80, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x01, 0x01, 0x21, 0x11, 0x09, 0x84, 0x40,
  0x20, 0x07, 0x18, 0x20, 0x47, 0x48, 0x50, 0x50,
  0x50, 0x50, 0x48, 0x47, 0x40, 0x50, 0x5F, 0x50,
  0x50, 0x50, 0x50, 0x48, 0x50, 0x5F, 0x51, 0x51,
  0x53, 0x50, 0x48, 0x50, 0x5F, 0x50, 0x50, 0x50,
  0x50, 0x48, 0x47, 0x20, 0x18, 0x07, 0x00, 0x20,
  0x40, 0x84, 0x09, 0x11, 0x21, 0x01, 0x01, 0x00,
unsigned char code pic5[2][8] = { //trigger2
  0xC0, 0xC0, 0xC0, 0xC0, 0xFF, 0xFF, 0xFF, 0xFF,
  0x01, 0x01, 0x01, 0x01, 0xFF, 0xFF, 0xFF, 0xFF
//unsigned char code pic6[2][100]={ //think our earth
unsigned char code pic6[4][100] = {
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x18,
  0x08, 0x08, 0x08, 0xF8, 0x08, 0x08, 0x08, 0x18,
  0x00, 0x08, 0xF8, 0x88, 0x80, 0x80, 0x80, 0x88,
  0xF8, 0x08, 0x00, 0x00, 0x08, 0xF8, 0x08, 0x00,
  0x00, 0x08, 0xF8, 0x20, 0x40, 0x80, 0x00, 0x08,
  0xF8, 0x08, 0x00, 0x00, 0x08, 0xF8, 0x88, 0x80,
  0x40, 0x28, 0x18, 0x08, 0x08, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xE0, 0x10,
  0x08, 0x08, 0x08, 0x08, 0x08, 0x10, 0xE0, 0x00,
  0x00, 0x08, 0xF8, 0x08, 0x00, 0x00, 0x00, 0x08,
  0xF8, 0x08, 0x00, 0x00, 0x08, 0xF8, 0x88, 0x88,
  0x88, 0x88, 0x70, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x1F,
  0x10, 0x00, 0x00, 0x00, 0x00, 0x10, 0x1F, 0x10,
  0x00, 0x00, 0x00, 0x10, 0x1F, 0x10, 0x00, 0x00,
  0x10, 0x1F, 0x10, 0x00, 0x00, 0x10, 0x1F, 0x10,
  0x00, 0x01, 0x02, 0x04, 0x1F, 0x00, 0x00, 0x00,
  0x10, 0x1F, 0x10, 0x01, 0x02, 0x14, 0x18, 0x10,
  0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x07, 0x08, 0x10, 0x10, 0x10, 0x10,
  0x10, 0x08, 0x07, 0x00, 0x00, 0x00, 0x07, 0x08,
  0x10, 0x10, 0x10, 0x08, 0x07, 0x00, 0x00, 0x00,
  0x10, 0x1F, 0x10, 0x00, 0x01, 0x06, 0x18, 0x10,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08,
  0xF8, 0x88, 0x88, 0xC8, 0x08, 0x18, 0x00, 0x00,
  0x00, 0x00, 0x80, 0x60, 0x18, 0x60, 0x80, 0x00,
  0x00, 0x00, 0x00, 0x08, 0xF8, 0x88, 0x88, 0x88,
  0x88, 0x70, 0x00, 0x00, 0x18, 0x08, 0x08, 0x08,
  0xF8, 0x08, 0x08, 0x08, 0x18, 0x00, 0x08, 0xF8,
  0x88, 0x80, 0x80, 0x80, 0x88, 0xF8, 0x08, 0x00,
  0x00, 0x00, 0x00, 0x10, 0x1F, 0x10, 0x10, 0x11,
  0x10, 0x18, 0x04, 0x10, 0x10, 0x1C, 0x13, 0x02,
  0x02, 0x02, 0x13, 0x1C, 0x10, 0x10, 0x00, 0x10,
  0x1F, 0x10, 0x00, 0x01, 0x06, 0x18, 0x10, 0x10,
  0x00, 0x00, 0x10, 0x1F, 0x10, 0x00, 0x00, 0x00,
  0x10, 0x1F, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00,
unsigned char code pic7[4][100] = { //saving energy,carbon reduction
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x60,
  0x90, 0x10, 0x30, 0x00, 0x00, 0x00, 0xC0, 0x30,
  0xC0, 0x00, 0x00, 0x00, 0x10, 0x70, 0x90, 0x00,
  0x90, 0x70, 0x10, 0x10, 0xF0, 0x10, 0x00, 0x10,
  0xF0, 0x40, 0x80, 0x10, 0xF0, 0x10, 0x00, 0xC0,
  0x20, 0x10, 0x10, 0x10, 0x30, 0x00, 0x00, 0x00,
  0x00, 0x10, 0xF0, 0x90, 0xD0, 0x10, 0x30, 0x00,
  0x10, 0xF0, 0x40, 0x80, 0x10, 0xF0, 0x10, 0x00,
  0x10, 0xF0, 0x90, 0xD0, 0x10, 0x30, 0x00, 0x10,
  0xF0, 0x90, 0x90, 0x90, 0x60, 0x00, 0xC0, 0x20,
  0x10, 0x10, 0x10, 0x30, 0x00, 0x10, 0x30, 0xD0,
  0x00, 0xD0, 0x30, 0x10, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x0C, 0x08, 0x09, 0x06, 0x00,
  0x08, 0x0E, 0x0B, 0x02, 0x0B, 0x0E, 0x08, 0x00,
  0x00, 0x00, 0x03, 0x0C, 0x03, 0x00, 0x00, 0x08,
  0x0F, 0x08, 0x00, 0x08, 0x0F, 0x08, 0x01, 0x02,
  0x0F, 0x00, 0x00, 0x03, 0x04, 0x08, 0x08, 0x09,
  0x07, 0x01, 0x00, 0x00, 0x00, 0x08, 0x0F, 0x08,
  0x09, 0x08, 0x0C, 0x00, 0x08, 0x0F, 0x08, 0x01,
  0x02, 0x0F, 0x00, 0x00, 0x08, 0x0F, 0x08, 0x09,
  0x08, 0x0C, 0x00, 0x08, 0x0F, 0x08, 0x01, 0x06,
  0x08, 0x08, 0x03, 0x04, 0x08, 0x08, 0x09, 0x07,
  0x01, 0x00, 0x00, 0x08, 0x0F, 0x08, 0x00, 0x00,
  0xE0, 0x10, 0x10, 0x30, 0x00, 0x00, 0x00, 0xC0,
  0x30, 0xC0, 0x00, 0x00, 0x00, 0x10, 0xF0, 0x90,
  0x90, 0x60, 0x00, 0x00, 0x10, 0xF0, 0x90, 0x90,
  0x60, 0x00, 0xE0, 0x10, 0x10, 0x10, 0xE0, 0x00,
  0x00, 0x00, 0x00, 0x10, 0xF0, 0x90, 0x90, 0x60,
  0x00, 0x00, 0x10, 0xF0, 0x90, 0xD0, 0x10, 0x30,
  0x00, 0x10, 0xF0, 0x10, 0x10, 0x20, 0xC0, 0x00,
  0x10, 0xF0, 0x10, 0x00, 0x10, 0xF0, 0x10, 0x00,
  0xE0, 0x10, 0x10, 0x30, 0x00, 0x30, 0x10, 0xF0,
  0x10, 0x30, 0x00, 0x10, 0xF0, 0x10, 0x00, 0xE0,
  0x10, 0x10, 0x10, 0xE0, 0x00, 0x10, 0xF0, 0x40,
  0x80, 0x10, 0xF0, 0x10, 0x03, 0x04, 0x04, 0x02,
  0x00, 0x04, 0x06, 0x01, 0x01, 0x01, 0x06, 0x04,
  0x00, 0x04, 0x07, 0x04, 0x01, 0x06, 0x04, 0x00,
  0x04, 0x07, 0x04, 0x04, 0x03, 0x00, 0x03, 0x04,
  0x04, 0x04, 0x03, 0x00, 0x04, 0x07, 0x04, 0x00,
  0x01, 0x07, 0x04, 0x00, 0x00, 0x00, 0x00, 0x04,
  0x07, 0x04, 0x01, 0x06, 0x04, 0x00, 0x04, 0x07,
  0x04, 0x05, 0x04, 0x06, 0x00, 0x04, 0x07, 0x04,
  0x04, 0x02, 0x01, 0x00, 0x00, 0x03, 0x04, 0x04,
  0x04, 0x03, 0x00, 0x00, 0x03, 0x04, 0x04, 0x02,
  0x00, 0x00, 0x04, 0x07, 0x04, 0x00, 0x00, 0x04,
  0x07, 0x04, 0x00, 0x03, 0x04, 0x04, 0x04, 0x03,
  0x00, 0x04, 0x07, 0x04, 0x00, 0x01, 0x07, 0x04
//unsigned char code pic8[2][100]={ //come with us
unsigned char code pic8[4][100] = { //come with us
  0x08, 0x08, 0x08, 0x08, 0x10, 0x38, 0x00, 0x00,
  0xE0, 0x10, 0x08, 0x08, 0x08, 0x08, 0x08, 0x10,
  0xE0, 0x00, 0x00, 0x08, 0xF8, 0x18, 0xE0, 0x00,
  0x00, 0x00, 0xE0, 0x18, 0xF8, 0x08, 0x00, 0x00,
  0x08, 0xF8, 0x88, 0x88, 0xC8, 0x08, 0x18, 0x00,
  0x08, 0x78, 0x88, 0x00, 0x08, 0xC8, 0x78, 0x88,
  0x00, 0x08, 0xE8, 0x18, 0x08, 0x00, 0x08, 0xF8,
  0x08, 0x00, 0x18, 0x08, 0x08, 0x08, 0xF8, 0x08,
  0x08, 0x08, 0x18, 0x00, 0x08, 0xF8, 0x88, 0x80,
  0x80, 0x80, 0x88, 0xF8, 0x08, 0x00, 0x00, 0x00,
  0x08, 0x04, 0x00, 0x00, 0x07, 0x08, 0x10, 0x10,
  0x10, 0x10, 0x10, 0x08, 0x07, 0x00, 0x00, 0x10,
  0x1F, 0x10, 0x00, 0x07, 0x18, 0x07, 0x00, 0x10,
  0x1F, 0x10, 0x00, 0x00, 0x10, 0x1F, 0x10, 0x10,
  0x11, 0x10, 0x18, 0x04, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x18,
  0x07, 0x00, 0x00, 0x07, 0x18, 0x07, 0x00, 0x00,
  0x00, 0x10, 0x1F, 0x10, 0x00, 0x00, 0x00, 0x00,
  0x10, 0x1F, 0x10, 0x00, 0x00, 0x00, 0x10, 0x1F,
  0x00, 0x00, 0x08, 0xF8, 0x08, 0x00, 0x00, 0x00,
  0x08, 0xF8, 0x08, 0x00, 0x00, 0x70, 0x88, 0x88,
  0x08, 0x10, 0x38, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07,
  0x08, 0x10, 0x10, 0x10, 0x08, 0x07, 0x00, 0x00,
  0x00, 0x1C, 0x08, 0x10, 0x11, 0x11, 0x0E, 0x00,
//unsigned char code pic9[2][100]={ //OLED
//unsigned char code pic9[4][100]={ //OLED
unsigned char code pic9[16][100] = { //OLED
  //oled1
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xE0,
  0x70, 0x08, 0xF0, 0x18, 0x04, 0x02, 0x02, 0x02,
  0x02, 0x02, 0x04, 0x1C, 0xF0, 0x08, 0x70, 0xE0,
  0x00, 0x02, 0x06, 0xFE, 0x00, 0xFE, 0x06, 0x02,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02,
  0x02, 0xFE, 0x00, 0xFE, 0x82, 0x82, 0x82, 0x82,
  0x82, 0xE2, 0x0E, 0x00, 0x00, 0x02, 0x02, 0xFE,
  0x00, 0xFE, 0x02, 0x02, 0x02, 0x02, 0x06, 0x04,
  0x18, 0xF8, 0x08, 0x70, 0xC0, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x07, 0x0E, 0x10, 0x0F, 0x38,
  0x20, 0x40, 0x40, 0x40, 0x40, 0x40, 0x20, 0x18,
  0x0F, 0x10, 0x0E, 0x07, 0x00, 0x40, 0x40, 0x7F,
  0x00, 0x7F, 0x40, 0x40, 0x40, 0x40, 0x40, 0x40,
  0x60, 0x30, 0x00, 0x40, 0x40, 0x7F, 0x00, 0x7F,
  0x40, 0x40, 0x40, 0x40, 0x40, 0x43, 0x60, 0x10,
  0x00, 0x40, 0x40, 0x7F, 0x00, 0x7F, 0x40, 0x40,
  0x40, 0x40, 0x40, 0x20, 0x38, 0x2F, 0x10, 0x0E,
  0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  //oled 2
  0x00, 0x00, 0x80, 0x80, 0xC0, 0xC0, 0xC0, 0xC0,
  0xC0, 0xC0, 0x80, 0x80, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x60, 0x60, 0xE0, 0xE0,
  0xE0, 0xE0, 0xE0, 0xC0, 0x00, 0x00, 0x00, 0x00,
  0xE0, 0xE0, 0xE0, 0xE0, 0x60, 0x40, 0x40, 0xC0,
  0x80, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF0,
  0xF0, 0xF0, 0xF0, 0x30, 0x20, 0x60, 0x60, 0xE0,
  0xC0, 0xC0, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0xE0, 0xF8, 0xFE, 0xFF, 0x7F, 0xDF,
  0x8F, 0x07, 0x07, 0x3F, 0x07, 0x07, 0x67, 0x3F,
  0x1F, 0xFE, 0xF8, 0xE0, 0x00, 0x00, 0x00, 0x00,
  0x8C, 0x8C, 0xFF, 0xFF, 0xFF, 0xFF, 0x1F, 0x00,
  0x00, 0x00, 0x00, 0xD2, 0xD2, 0xFF, 0xFF, 0x0F,
  0x10, 0x38, 0x3C, 0x00, 0x00, 0x07, 0x0E, 0x00,
  0x00, 0x00, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0x00,
  0x00, 0xF0, 0x00, 0x03, 0x27, 0x27, 0xFF, 0xFF,
  0xFE, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x7F,
  0xFF, 0xFF, 0xC8, 0x88, 0x41, 0x00, 0x00, 0x00,
  0x00, 0x40, 0x80, 0x11, 0xB1, 0xF1, 0x7F, 0x0F,
  0x00, 0x00, 0x00, 0x00, 0x01, 0xC1, 0xFF, 0xFF,
  0x7F, 0x03, 0x00, 0x00, 0x00, 0x0E, 0x0E, 0x0E,
  0x00, 0x00, 0xE0, 0xC0, 0x00, 0x00, 0xE0, 0xFF,
  0xFF, 0xFF, 0x07, 0x07, 0x07, 0x0F, 0x0F, 0x0F,
  0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0xFF,
  0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x07, 0x00, 0x00,
  0xFB, 0xFB, 0x7F, 0x3F, 0x1F, 0x07, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x03, 0x07,
  0x06, 0x0C, 0x0E, 0x0F, 0x0C, 0x0C, 0x07, 0x07,
  0x03, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x0F, 0x0F, 0x0F, 0x0C, 0x0C, 0x0C, 0x0C,
  0x0C, 0x0C, 0x0C, 0x0C, 0x0C, 0x06, 0x07, 0x03,
  0x00, 0x00, 0x1F, 0x1F, 0x1F, 0x10, 0x10, 0x10,
  0x10, 0x10, 0x1C, 0x1E, 0x1E, 0x1E, 0x00, 0x00,
  0x00, 0x00, 0x0F, 0x0F, 0x0F, 0x07, 0x07, 0x04,
  0x04, 0x02, 0x02, 0x01, 0x01, 0x00, 0x00, 0x00,
  //oled 3
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x80,
  0x40, 0x80, 0x80, 0x80, 0x80, 0x80, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x40, 0x40, 0xC0, 0xC0,
  0x40, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x80, 0x80, 0x80, 0x80, 0x40, 0x40,
  0x40, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0xE0, 0xE0, 0x80, 0x80, 0x80, 0x80, 0x80,
  0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0xFC,
  0x0E, 0x03, 0x01, 0x0E, 0x11, 0x17, 0x0E, 0x00,
  0x00, 0x00, 0x01, 0x03, 0x0E, 0xFC, 0xF0, 0x00,
  0x00, 0x00, 0x03, 0xFF, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1F,
  0xFF, 0x00, 0x00, 0x00, 0x00, 0x83, 0x00, 0x00,
  0x00, 0x0C, 0x12, 0x15, 0x0D, 0x00, 0x0F, 0xFF,
  0xC0, 0x00, 0x00, 0x00, 0x01, 0x01, 0x03, 0x06,
  0x0E, 0xFC, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x03, 0x0F, 0x1C, 0x30, 0x60, 0x40,
  0x80, 0x80, 0x80, 0x80, 0x80, 0x40, 0x40, 0x30,
  0x1C, 0x0F, 0x03, 0x00, 0x00, 0x80, 0x80, 0xFF,
  0x80, 0x80, 0x00, 0x00, 0x30, 0x48, 0xB8, 0xF0,
  0x00, 0x00, 0x80, 0x80, 0xFF, 0x81, 0x81, 0x81,
  0x81, 0x80, 0xB8, 0xB4, 0x44, 0x38, 0x00, 0x00,
  0x00, 0x00, 0x80, 0x83, 0xFF, 0x80, 0x40, 0x40,
  0x40, 0x20, 0x30, 0x18, 0x0C, 0x07, 0x01, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x01,
  0x01, 0x01, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00,
  //oled 4
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0xC0,
  0xC0, 0xC0, 0xC0, 0xC0, 0x80, 0x80, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xE0, 0xE0,
  0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x80, 0xC0, 0xC0, 0xC0, 0xC0,
  0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0,
  0xC0, 0xC0, 0x40, 0x00, 0x00, 0x00, 0x00, 0x80,
  0x80, 0x80, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0,
  0xC0, 0xC0, 0xC0, 0x80, 0x80, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80,
  0xC0, 0xF0, 0x78, 0x18, 0x0C, 0x04, 0xF4, 0xFC,
  0x0E, 0x03, 0x03, 0x01, 0x01, 0x01, 0x03, 0x03,
  0x0F, 0xFF, 0xFF, 0xFC, 0x00, 0x00, 0x00, 0x00,
  0x80, 0xFC, 0xFF, 0x3F, 0x01, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x81,
  0x80, 0x80, 0xF8, 0xFF, 0xFF, 0x83, 0x80, 0x80,
  0x80, 0x80, 0x80, 0x40, 0x00, 0x00, 0x00, 0x18,
  0x0E, 0x06, 0x03, 0x83, 0xF9, 0xFD, 0x3D, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x01, 0x03,
  0x07, 0x1F, 0xFF, 0xFE, 0xF8, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x1F, 0x7F, 0xFF, 0xF0, 0xC0,
  0x80, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80,
  0x80, 0xC0, 0x60, 0x38, 0x1E, 0x0F, 0x07, 0x00,
  0x00, 0x00, 0x00, 0xF0, 0xFF, 0xFF, 0x87, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x80, 0x40,
  0x00, 0x00, 0x02, 0x01, 0xE1, 0xFF, 0xFF, 0x8F,
  0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x81, 0x80,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xE0, 0xFF,
  0xFF, 0x0F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x80, 0xC0, 0xE0, 0x70, 0x3C, 0x1F, 0x07,
  0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x01, 0x01, 0x03, 0x03, 0x03, 0x03,
  0x03, 0x03, 0x01, 0x01, 0x01, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
  0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03,
  0x01, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x01, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03,
  0x03, 0x01, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x03, 0x07, 0x07, 0x06, 0x06, 0x06,
  0x06, 0x02, 0x02, 0x03, 0x01, 0x01, 0x00, 0x00,
unsigned char code pic10[4][100] = { //save you 50% of power
  0x00, 0x00, 0x60, 0x90, 0x10, 0x30, 0x00, 0x00,
  0x00, 0xC0, 0x30, 0xC0, 0x00, 0x00, 0x00, 0x10,
  0x70, 0x90, 0x00, 0x90, 0x70, 0x10, 0x00, 0x10,
  0xF0, 0x90, 0xD0, 0x10, 0x30, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10,
  0x30, 0xD0, 0x00, 0xD0, 0x30, 0x10, 0x00, 0xC0,
  0x20, 0x10, 0x10, 0x10, 0x20, 0xC0, 0x00, 0x10,
  0xF0, 0x10, 0x00, 0x10, 0xF0, 0x10, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0C, 0x08,
  0x09, 0x06, 0x00, 0x08, 0x0E, 0x0B, 0x02, 0x0B,
  0x0E, 0x08, 0x00, 0x00, 0x00, 0x03, 0x0C, 0x03,
  0x00, 0x00, 0x00, 0x08, 0x0F, 0x08, 0x09, 0x08,
  0x0C, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0x0F, 0x08,
  0x00, 0x00, 0x00, 0x03, 0x04, 0x08, 0x08, 0x08,
  0x04, 0x03, 0x00, 0x00, 0x07, 0x08, 0x08, 0x08,
  0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x60, 0x50, 0x90,
  0x10, 0x00, 0xE0, 0x10, 0x10, 0x10, 0xE0, 0x00,
  0x60, 0x90, 0x60, 0x00, 0x80, 0x40, 0x20, 0x10,
  0x00, 0xC0, 0x20, 0x10, 0x10, 0x10, 0x20, 0xC0,
  0xF0, 0x10, 0x10, 0x10, 0xE0, 0x00, 0xC0, 0x20,
  0x10, 0x10, 0x10, 0x20, 0xC0, 0x00, 0x10, 0x70,
  0x90, 0x00, 0x10, 0xF0, 0x10, 0x00, 0x90, 0x70,
  0x10, 0x00, 0x10, 0xF0, 0x90, 0xD0, 0x10, 0x30,
  0x00, 0x10, 0xF0, 0x90, 0x90, 0x90, 0x60, 0x00,
  0x08, 0x08, 0x08, 0x08, 0x07, 0x00, 0x07, 0x08,
  0x08, 0x08, 0x07, 0x00, 0x00, 0x08, 0x04, 0x02,
  0x01, 0x00, 0x06, 0x09, 0x06, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x04, 0x08,
  0x08, 0x08, 0x04, 0x03, 0x00, 0x08, 0x0F, 0x08,
  0x00, 0x00, 0x00, 0x08, 0x0F, 0x09, 0x01, 0x01,
  0x00, 0x00, 0x03, 0x04, 0x08, 0x08, 0x08, 0x04,
  0x03, 0x00, 0x00, 0x00, 0x03, 0x0C, 0x03, 0x00,
  0x03, 0x0C, 0x03, 0x00, 0x00, 0x00, 0x08, 0x0F,
  0x08, 0x09, 0x08, 0x0C, 0x00, 0x08, 0x0F, 0x08,
  0x01, 0x06, 0x08, 0x08, 0x00, 0x00, 0x00, 0x00
//unsigned char code pic11[2][32]={
unsigned char code pic11[6][32] = {
  //pic1
  0x00, 0xC0, 0x60, 0x70, 0xD8, 0x18, 0x08, 0x80,
  0xC0, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x80, 0x60, 0x10, 0x08, 0x88, 0x84, 0x84,
  0x04, 0x04, 0x04, 0x88, 0x88, 0x10, 0x60, 0x80,
  0x00, 0xFF, 0x80, 0x80, 0xFF, 0x82, 0x83, 0xFE,
  0x00, 0x07, 0x18, 0x20, 0x41, 0x48, 0x90, 0x90,
  0x91, 0x90, 0x91, 0x48, 0x40, 0x21, 0x18, 0x07,
  //pic2
  0x00, 0xC0, 0x60, 0x70, 0xD8, 0x18, 0x1C, 0x9C,
  0xDE, 0xDE, 0xEE, 0x64, 0x60, 0x00, 0x00, 0x00,
  0x00, 0xC0, 0x30, 0x08, 0x84, 0x04, 0x02, 0x02,
  0x82, 0x02, 0x82, 0x04, 0x04, 0x88, 0x30, 0xC0,
  0x00, 0x07, 0x18, 0x20, 0x40, 0x51, 0x89, 0x85,
  0x84, 0x84, 0x84, 0x49, 0x51, 0x20, 0x18, 0x07,
  //pic3
  0xDE, 0xDE, 0xFF, 0xEF, 0xEF, 0xF6, 0xF0, 0x60,
  0x00, 0xC0, 0x30, 0x38, 0xBC, 0x3C, 0x1A, 0x02,
  0x82, 0x02, 0x82, 0x04, 0x74, 0xF8, 0xF0, 0xC0,
  0x00, 0x07, 0x1C, 0x3C, 0x78, 0x51, 0x89, 0x85,
  0x84, 0x84, 0xE4, 0x69, 0x71, 0x38, 0x19, 0x07
Разница невелика, преобразуем код для Arduino:
#define Data_BUS  P1
#define TOP   0
#define DOWN  1
#define LEFT    2
#define RIGHT 3
#define CHIP1 0x01
#define CHIP2 0x02
sbit    busy    = P1 ^ 7;
sbit    RW      = P3 ^ 7;
sbit    CS2  = P3 ^ 6;
char bdata  flag;
  RS = 0;
  RW = 0;
  Enable = 1;            //1us
  _nop_();   //1us
  Enable = 0;    //1us
  RS = 0;
  RW = 1;
  do
    Enable = 1;
    busy_f = busy;
    Enable = 0;
  } while (busy_f);
  RS = 0;
  RW = 0;
  Enable = 1;            //1us
  _nop_();   //1us
  Enable = 0;    //1us
  CheckBusy();
  RS = 1;
  RW = 0;
  Data_BUS = data1;
  Enable = 1;
  _nop_();
  Enable = 0;
  CheckBusy();
  unsigned char i;
    WriteData(MSG[i]);
  void Clear(void)
  unsigned char i;
  WriteCmd(one);//X
  WriteCmd(0x40);//Y
      WriteData(0x00);
  WriteCmd(one);//X
  WriteCmd(0x41);//Y
      WriteData(0x00);
  void Fullon(void)
  unsigned char i;
  WriteCmd(one);//X
  WriteCmd(0x40);//Y
    WriteData(0xff);
  WriteCmd(one);//X
  WriteCmd(0x41);//Y
    WriteData(0xff);
  unsigned char i,j;
  WriteIns(one);//X
  WriteIns(0x40);//Y
  WriteIns(one);//X
  WriteIns(0x41);//Y
  for (j=0;j<18;j++)
    WriteCmd(one);
    WriteCmd(0x40);//Y
    WriteCmd(one);
    WriteCmd(0x41);//Y
    delay(1);
  unsigned char i;
  //first line
  WriteCmd(one);//X
  WriteCmd(0x40);//Y
  //second line
  WriteCmd(one);//X
  WriteCmd(0x41);//Y
  unsigned char i;
  //first line
  WriteCmd(one);//X
  WriteCmd(0x40);//Y
  //second line
  WriteCmd(one);//X
  WriteCmd(0x41);//Y
  unsigned char i;
  //first line
  WriteCmd(one);//X
  WriteCmd(0x40);//Y
  //second line
  WriteCmd(one);//X
  WriteCmd(0x41);//Y
  delay(5);
  //first line
  WriteCmd(one);//X
  WriteCmd(0x40);//Y
  //second line
  WriteCmd(one);//X
  WriteCmd(0x41);//Y
  if (order == 0)
      //first line
      WriteCmd(0x40);//Y
      //second line
      WriteCmd(0x41);//Y
      delay(7);
      c++;
    c = 2;
      //first line
      WriteCmd(0x40);//Y
      //second line
      WriteCmd(0x41);//Y
      delay(7);
      c--;
  unsigned char i, j;
    //first line
    WriteCmd(one);//X
    WriteCmd(0x40);//Y
    //second line
    WriteCmd(one);//X
    WriteCmd(0x41);//Y
    //first line
    WriteCmd(one);//X
    WriteCmd(0x40);//Y
    //second line
    WriteCmd(one);//X
    WriteCmd(0x41);//Y
    delay(5);
  unsigned char i;
  if (dir == LEFT)
    WriteCmd(one);
  if (dir == RIGHT)
    WriteCmd(one + 92);
  WriteCmd(0x40);//Y
  if (dir == LEFT)
    WriteCmd(one);
  if (dir == RIGHT)
    WriteCmd(one + 92);
  WriteIns(0x41);//Y
        WriteCmd(0x40);//Y
        WriteCmd(0x41);//Y
        delay(1);
        nL--;
  value = nL;
  return value;
      if (nR <= 75)
        WriteCmd(one + nR);
        WriteCmd(0x40);//Y
        WriteCmd(one + nR);
        WriteCmd(0x41);//Y
        delay(1);
        nR++;
  value = nR;
  return value;
    if (val == TOP)
  WriteIns(one);//X
  WriteIns(0x40);//Y
    tmp1 = dat[i] >> 8;
    WriteData(tmp1);
  WriteIns(one);//X
  WriteIns(0x41);//Y
    tmp2 = dat[i];
    WriteData(tmp2);
  //Enable=0;
  WriteCmd(0x02);
  delay(20);
  /*Enable=0;
  Initial_ks0066();
  /*Enable=0;
    Initial_ks0066();*/
  /*Fullon();
    delay(30);*/
  //show strings
  delay(15);
  delay(30);
  k = Move_L();
    WriteCmd(one + k);
    WriteCmd(0x40);//Y
    WriteCmd(one + k);
    WriteCmd(0x41);//Y
    delay(1);
  delay(30);
  //delay(5);
  delay(30);
    Scroll(TOP);
    delay(2);
  delay(10);
    Scroll(TOP);
    delay(2);
  delay(30);
  delay(15);
  delay(30);
  k = Move_R();
    WriteCmd(one + k);
    WriteCmd(0x40);//Y
    WriteCmd(one + k);
    WriteCmd(0x41);//Y
    delay(1);
  delay(30);
  delay(30);
  delay(30);
    Scroll(DOWN);
    delay(2);
  delay(10);
    Scroll(DOWN);
    delay(2);
  delay(40);
  //stop
  //stop
  //light-1
  //oled1
  //oled 2
  //oled 3
  //oled 4
  //pic1
  //pic2
  //pic3
Но не компилируется, т.к. в коде есть непонятные sbit busy_f  = flag ^ 0;
Гугл дал только эти ссылки из адекватных:
https://github.com/rimksky/WinstarOLED
http://we.easyelectronics.ru/lcd_gfx/rabota-s-indikatorami-weg005016-kontroller-ws0010.html
http://radiokot.ru/forum/viewtopic.php?f=20&t=85323
http://we.easyelectronics.ru/lcd_gfx/osobennosti-raboty-s-kontrollerom-ws0010-indikator-weh000802.html
https://gist.github.com/lardconcepts/4947360
http://avr.myluna.de/doku.php?id=en:lib-ws0010
Куда дальше двигаться?
Tomasina
Tomasina аватар
насколько я понимаю, sbit и bdata  - это описание подключения пинов, а P1 - P3 - это порты ввода-вывода, и их надо переопределить через #define?
Jeka_M
Jeka_M аватар
Судя по хедерам reg51.h (sbit) и INTRINS.H ( _nop_ ), это код для микроконтроллеров семейства 8051, который писали в среде KEIL. Описание sbit - http://www.keil.com/support/man/docs/c51/c51_le_sbit.htm
MacSim
представьте их друг-другу для начала...
смотрите на каком он контролере, под них библиотек куча в нете
а,да фруут покапайте :-)
Tomasina
Tomasina аватар
написано же, на контроллере WS0010, и библиотек к нему всего две, с обеими пока не удалось завести.
