Помогите новичку. Инкубатор
Пнд, 28/09/2015 - 08:16
Уважаемые форумчане доброго времени суток. Нашёл скетч инкубатора на просторах инета. Я новичок в програмировании и при работе со скетчем возникают всяческие ошибки компиляции. Прошу Вашей помощи разобратся с данным скетчем.
#include <Time.h>
// Egg Incubator Sketch
// Written by: Matt Schreiner <Arduino@MidnightFantasy.com>
// June 9th, 2014
// Version 1.0
#include <dht.h> // Temp and Humidity Sensor library
#include <LiquidCrystal.h> // LCD Display library
#include <Time.h>
#include <TimeAlarms.h> // Be SURE to modify the TimeAlarms.h to increment the dtNBR_ALARMS definition or alarms won't work correctly, if at all!
// Total needed are 3 + numer of egg turns (7 default) so set to a minimum of 10, 27 is the max for 24 egg turns per day.
// --- SET DEFAULT VALUES FOR CHICKEN OR DUCK INCUBATION AND HATCHING DAYS, TEMP, AND HUMITITY HERE --
// --- IF YOU CHANGE THESE VALUES HERE, BE SURE TO ALSO SET THEM IN THE updateDisplay EGG TYPE SECTION --
boolean duck = true; // Using default values for DUCK eggs, set to FALSE if you want to default to CHICKEN eggs
int incubationDays = 25; // Duck == 25, Chicken == 18
double incubationTemp = 99.5; // Chicken and Ducks are the same, 99.5 for incubation temp
double incubationHumidity = 86; // Duck == 86, Chicken == 50
double hatchingTemp = 98.5; // Chicken and Ducks are the same, 99.5 for hatching temp
double hatchingHumidity = 94; // Duck == 94, Chicken == 65
int turnsDaily = 7; // Set to (minimum) 3 turns, once every 8 hours, or it will turn the eggs 7 times daily.
// The value should be an odd numer (if not hourly) so yolk doesn't stick to embryo overnight.
#define DHTTYPE DHT22 // DHT 22 (AM2302)
// PIN definitions / assignments
//Open Pin 0 // RX Serial Pin
//Open Pin 1 // TX Serial Pin
#define LCDD7 2 // LCD D7 pin to digital pin 2
#define LCDD6 3 // LCD D6 pin to digital pin 3
#define LCDD5 4 // LCD D5 pin to digital pin 4
#define LCDD4 5 // LCD D4 pin to digital pin 5
#define DHT_PIN 6 // data wire for DHT environmental sensor
#define endstop1 7 // one end of travel for egg turner - wire with a pull DOWN resistor
#define endstop2 8 // opposite end of travel for egg turner - wire with a pull DOWN resistor
#define screenButton 9 // button1 for toggling the screenMode - wire with a pull DOWN resistor
#define settingsButton 10 // button2 for incrementing days, hours, and minutes - wire with a pull DOWN resistor
#define LCDEnable 11 // LCD Enable pin to digital pin 11
#define LCDRS 12 // LCD RS pin to digital pin 12
#define led 13 // LED status indicator to show in water, heater, fan, or egg relays are on
#define heaterRelay A0 // signal wire for heater relay
#define fanRelay A1 // signal wire for fan relay
#define waterRelay A2 // signal wire for water valve relay
#define eggRelay A3 // signal wire for egg turner relay
//Open Pin A4
//Open Pin A5
// -- NPN or PNP transistor type dictates if the base is set to HIGH or LOW to enable the relay --
// -- Set the off and on values for LOW and HIGH to set the correct behavior expected based on --
// -- on your electrical wiring. --
#define off HIGH // Set to LOW if NPN, HIGH for PNP
#define on LOW // Set to HIGH if NPN, LOW for PNP
// State Machine variables
boolean heat = false;
boolean fan = true;
boolean water = false;
boolean egg = false;
boolean eggSwitch1Status = LOW;
boolean eggSwitch2Status = LOW;
int chk; // Environment sensor status
int eggSwitchTarget = 0; // Endswitch destination
int currentSwitch = 0; // Which endswitch is currently active
int dayCount = 1; // Day in the incubation cycle
int screenMode = 1; // Which screen to show on the LCD for status or setting day, hour, and minute
int screenButtonState = LOW; // Button 1 for toggling the screen mode
int settingsButtonState = LOW; // Button 2 for incrementing day, hour, and minute
int debug = 1; // Enable (1) or Disable (0) debug output on serial line for tightest running loops - will have performance impact
// Tracking variables
double targetTemp = incubationTemp;
double targetHumidity = incubationHumidity;
double currentHumidity = 0;
double currentTemp = 0;
// Instantiate classes for temp/humidity sensor and LCD display
dht dht22;
LiquidCrystal lcd(LCDRS, LCDEnable, LCDD4, LCDD5, LCDD6, LCDD7);
setTime(9,4,30,6,1,14); // set time to 9:04:30am June 1 2014
Alarm.alarmRepeat(9,0,0, trackDays); // bump the daycount every morning at 9am
Alarm.timerRepeat(5, checkStateMachine); // every 5 seconds, check the state machine of the incubator environment
Alarm.timerRepeat(1, checkEggTurn); // every second, check to see if we need to turn, or stop turning, the eggs
if (turnsDaily == 3) {
Serial.println("Setting alarms to turn eggs 3 times daily");
Alarm.alarmRepeat(0,5,0, turnEggs); // 1am every day
Alarm.alarmRepeat(8,5,0, turnEggs); // 9am every day
Alarm.alarmRepeat(16,5,0, turnEggs); // 5pm every day
else {
Serial.println("Setting alarms to turn eggs 7 times daily");
// Alarm.alarmRepeat(0,5,0, turnEggs);
Alarm.alarmRepeat(1,5,0, turnEggs);
// Alarm.alarmRepeat(2,5,0, turnEggs);
// Alarm.alarmRepeat(3,5,0, turnEggs);
// Alarm.alarmRepeat(4,5,0, turnEggs);
Alarm.alarmRepeat(5,5,0, turnEggs);
// Alarm.alarmRepeat(6,5,0, turnEggs);
// Alarm.alarmRepeat(7,5,0, turnEggs);
// Alarm.alarmRepeat(8,5,0, turnEggs);
Alarm.alarmRepeat(9,5,0, turnEggs);
// Alarm.alarmRepeat(10,5,0, turnEggs);
// Alarm.alarmRepeat(11,5,0, turnEggs);
Alarm.alarmRepeat(12,5,0, turnEggs);
// Alarm.alarmRepeat(13,5,0, turnEggs);
// Alarm.alarmRepeat(14,5,0, turnEggs);
Alarm.alarmRepeat(15,5,0, turnEggs);
// Alarm.alarmRepeat(16,5,0, turnEggs);
// Alarm.alarmRepeat(17,5,0, turnEggs);
Alarm.alarmRepeat(18,5,0, turnEggs);
// Alarm.alarmRepeat(19,5,0, turnEggs);
// Alarm.alarmRepeat(20,5,0, turnEggs);
Alarm.alarmRepeat(21,5,0, turnEggs);
// Alarm.alarmRepeat(22,5,0, turnEggs);
// Alarm.alarmRepeat(23,5,0, turnEggs);
lcd.begin(16, 2);
lcd.clear();
// initialize the digital pin as an output.
pinMode(led, OUTPUT);
pinMode(heaterRelay, OUTPUT);
pinMode(fanRelay, OUTPUT);
pinMode(waterRelay, OUTPUT);
pinMode(eggRelay, OUTPUT);
pinMode(DHT_PIN, INPUT);
pinMode(endstop1, INPUT);
pinMode(endstop2, INPUT);
pinMode(screenButton, INPUT);
pinMode(settingsButton, INPUT);
digitalWrite(fanRelay, on);
checkStateMachine();
Serial.begin(115200);
Serial.println(DHT_LIB_VERSION);
Serial.println();
Serial.println("Type,\tstatus,\tHumidity (%),\tTemperature (C)");
// the loop routine runs over and over again forever:
updateDisplay(currentTemp, currentHumidity); // Update LCD display to show current state or update day, hour, or minutes
Alarm.delay(250);
void checkStateMachine() { // Alarm which fires every few seconds to check the state machine and see if anything has or needs to change
updateEnvironment(); // Check temperature and humidity - Do not fire more frequently than once every 2 seconds
void checkButtons() {
screenButtonState = digitalRead(screenButton); // BUGBUG: Implement Debounce method here
settingsButtonState = digitalRead(settingsButton); // BUGBUG: Implement Debounce method here
if (screenButtonState == HIGH) {
screenMode++;
Alarm.delay(250);
lcd.clear();
if (screenMode >=6) {
screenMode = 1;
if (settingsButtonState == HIGH) {
lcd.clear();
void turnEggs(){
if (debug) {
Serial.println("!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!");
Serial.println("!! Egg Turn Time Event Reached !!");
if ((dayCount <= incubationDays)) {
egg = true;
} else {
egg = false;
void checkEggTurn() {
eggSwitch1Status = digitalRead(endstop1); // BUGBUG: Implement Debounce method here
eggSwitch2Status = digitalRead(endstop2); // BUGBUG: Implement Debounce method here
// check to see if the egg carriage is touching either sensor, if not, turn until sensor 1 is reached
if ((eggSwitch1Status == 0) && (eggSwitch2Status == 0) && (eggSwitchTarget == 0) ) { // Initial startup and not at either endstop, move to initial position
egg = true;
eggSwitchTarget = 1; //set target point for next turning to other switch
if ((egg == true) && (dayCount <= incubationDays)) {
if ((eggSwitch1Status == true) && (eggSwitchTarget == 1)) { // Arrived at target endstop 1, stop turning, set target to endstop 2 for next turn
if (debug) { Serial.println("Reached egg turning point position 1\t"); }
egg = false;
eggSwitchTarget = 2; //set target point for next turning to other switch
if ((eggSwitch1Status == false) && (eggSwitchTarget == 1)) { // Trying to stop at endstop 1, not reached yet, keep turning
if (debug) { Serial.println("Keep turning eggs until endstop 1 reached\t"); }
egg = true;
if ((eggSwitch2Status == true) && (eggSwitchTarget == 2)) { // Arrived at target endstop 2, stop turning, set target to endstop 1 for next turn
if (debug) { Serial.println("Reached turning point position 2\t"); }
egg = false;
if ((eggSwitch2Status == false) && (eggSwitchTarget == 2)) { // Trying to stop at endstop 2, not reached yet, keep turning
if (debug) { Serial.println("Keep turning eggs until endstop 2 reached\t"); }
egg = true;
else {
if (dayCount > incubationDays) {
if (debug) { Serial.println("Hatching"); }
egg = false;
if (debug) { Serial.println("Incubating"); }
if ((egg) && (dayCount <= incubationDays)) {
if (debug) { Serial.println("Turning Eggs"); }
digitalWrite(eggRelay, on);
} else {
digitalWrite(eggRelay, off);
void updateEnvironment() {
Serial.print("Environment Sensor, \t");
chk = dht.read22(DHT_PIN); // Fetch data from sensor - Can only be read once every 2 seoncds, max.
switch (chk)
case DHTLIB_OK:
Serial.print("OK,\t"); // If sensor is working:
checkTemp(); // Do we need to make changes for temperature
checkHumidity(); // Do we need to make changes for humidity level
checkFan();
case DHTLIB_ERROR_CHECKSUM:
Serial.print("Checksum error,\t");
heat = false;
fan = false;
water = false;
case DHTLIB_ERROR_TIMEOUT:
Serial.print("Time out error,\t");
heat = false;
fan = false;
water = false;
default:
Serial.print("Unknown error,\t");
heat = false;
fan = false;
water = false;
void checkTemp() {
currentTemp = c2f(dht.temperature); // Fetch Temp data
if (currentTemp < targetTemp) {
heat = true;
digitalWrite(heaterRelay, on);
else {
heat = false;
digitalWrite(heaterRelay, off);
void checkHumidity() {
currentHumidity = dht.humidity; // Fetch Humidity data
if (currentHumidity < targetHumidity) {
water = true;
digitalWrite(waterRelay, on);
else {
water = false;
digitalWrite(waterRelay, off);
void checkFan() {
fan = true;
digitalWrite(fanRelay, on); // Is there any reason we would ever want to turn the fan off?
void trackDays() {
if (debug) {
Serial.println("!! Day Increment !!");
dayCount++;
checkIncubation();
void checkIncubation() {
if (dayCount <= incubationDays) {
else {
targetHumidity = hatchingHumidity;
targetTemp = hatchingTemp;
egg = false;
double c2f(double temp) { // °C to °F Multiply by 9, then divide by 5, then add 32
temp = ((dht.temperature * 9) / 5) + 32;
return temp;
void updateDisplay(int temp, int humid) {
checkButtons();
if (heat || water || egg) { // Switch LED on if temp or humidity is low
digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level)
} else {
digitalWrite(led, LOW);
switch (screenMode) {
case 1: // Standard Runmode
lcd.setCursor(0, 0);
lcd.print("T");
lcd.setCursor(1, 0);
lcd.print(temp);
lcd.setCursor(5, 0);
lcd.print("H");
lcd.setCursor(6, 0);
lcd.print(humid);
if (debug) {
Serial.print("Temp: ");
Serial.print(currentTemp, 1);
Serial.print("Humidity: ");
Serial.println(currentHumidity, 1);
lcd.setCursor(9, 0); // Update status for Egg Type of D(uck) or C(hicken)
if (duck) {
lcd.print("D");
Serial.println("Incubation Egg Mode: Duck");
} else {
lcd.print("C");
Serial.println("Incubation Egg Mode: Chicken");
lcd.setCursor(10, 0); // Update status for relays and endstops
lcd.print(eggSwitch1Status);
lcd.setCursor(11, 0);
lcd.print(eggSwitch2Status);
lcd.setCursor(12, 0); // Update status for Heater
if (heat) {
lcd.print("H");
if (debug) { Serial.println("Heater: ON"); }
else {
lcd.print("_");
if (debug) { Serial.println("Heater: OFF"); }
lcd.setCursor(13, 0); // Update status for Fan
if (fan) {
lcd.print("F");
if (debug) { Serial.println("Fan: ON"); }
else {
lcd.print("_");
if (debug) { Serial.println("Fan: OFF"); }
lcd.setCursor(14, 0); // Update status for Water
if (water) {
lcd.print("W");
if (debug) { Serial.println("Water: ON"); }
else {
lcd.print("_");
if (debug) { Serial.println("Water: OFF"); }
lcd.setCursor(15, 0); // Update status for Egg turning
if (egg) {
lcd.print("E");
else {
lcd.print("_");
if (debug) { Serial.println("Do NOT Turn Eggs"); }
digitalClockDisplay();
Alarm.delay(100);
case 2: // Set HOUR
while (screenButtonState == LOW) {
checkButtons();
lcd.setCursor(0,0);
lcd.print("Set Hour: ");
lcd.setCursor(10,0);
lcd.print(hour());
lcd.clear();
// increment hour +1
int currentHour = hour();
int currentMinute = minute();
currentHour++;
if (currentHour >= 24) {
currentHour = 0;
setTime(currentHour,currentMinute,0,6,1,14); // set time to time +1 hour
Alarm.delay(100);
case 3: // Set MINUTE
checkButtons();
lcd.setCursor(0,0);
lcd.print("Set Minute: ");
lcd.setCursor(12,0);
lcd.print(minute());
lcd.clear(); // increment minute +1
currentMinute++;
if (currentMinute >= 60) {
currentMinute = 0;
setTime(currentHour,currentMinute,0,6,1,14); // set time to time +1 minute
Alarm.delay(100);
case 4: // Set DAY
checkButtons();
lcd.setCursor(0,0);
lcd.print("Set Day: ");
lcd.setCursor(9,0);
lcd.print(dayCount);
lcd.clear();
dayCount++;
if (dayCount >= (incubationDays + 3)) {
dayCount = 1;
Alarm.delay(100);
case 5: // Toggle between Duck and Chicken incubation modes
checkButtons();
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Set Egg Type:");
lcd.setCursor(0,1);
duck = !duck; // Toggle value between duck and chicken
// --- VALUES TO USE FOR CHICKEN OR DUCK INCUBATION AND HATCHING DAYS, TEMP, AND HUMITITY ---
// DUCKS
// Phase: Incubation Hatching
// Days: 1-25 26-28
// Temperature: 99.5 98.5
// Humidity: 86 94
// Turns Per Day: 3-7 0
// CHICKENS
// Days: 1-18 19-21
// Humidity: 50 65
if (duck) {
lcd.print("Ducks ");
} else { // If not DUCK Eggs, then we must be incubating CHICKEN Eggs
lcd.print("Chickens");
incubationDays = 18;
incubationHumidity = 50;
hatchingHumidity = 65;
checkIncubation();
Alarm.delay(100);
default: // ERROR - SCRAM the Incubator
Serial.println ("ERROR: Unknown State for Display! SHUTDOWN!");
lcd.setCursor(0,0);
lcd.print("ERR Display Mode");
lcd.setCursor(0,1);
lcd.print("SCRAM Incubator!");
egg = false;
heat = false;
fan = false;
water = false;
Alarm.delay(100);
void digitalClockDisplay(){ // digital clock display of the time
lcd.setCursor(0, 1);
lcd.print("D");
Serial.print("Day: ");
lcd.setCursor(1,1);
if (dayCount > 9) {
else {
lcd.print("0");
Serial.print(dayCount);
Serial.print(" ");
lcd.setCursor(4,1);
if (hour() < 10) {
lcd.print("0");
Serial.print("0");
lcd.print(hour());
Serial.print(hour());
lcd.setCursor(6,1);
lcd.print(":");
Serial.print(":");
lcd.setCursor(7,1);
if (minute() < 10) {
lcd.print("0");
Serial.print("0");
Serial.print(minute());
lcd.setCursor(9,1);
lcd.print(":");
Serial.print(":");
lcd.setCursor(10,1);
if (second() < 10) {
lcd.print("0");
Serial.print("0");
lcd.print(second());
Serial.println(second());
lcd.setCursor(13,1);
lcd.print("Inc");
Serial.print("Incubation Mode");
else {
lcd.print("Hat");
Serial.print("Hatching Mode");
Serial.println();
Какаие это "всяческие"? Сообщения компилятора сов. секретны?
библиотеки не стоят
#include <dht.h>
#include <Time.h>
При попытке установить библиотеки:
https://github.com/adafruit/DHT-sensor-library
http://www.pjrc.com/teensy/td_libs_Time.html
http://www.pjrc.com/teensy/td_libs_TimeAlarms.html
программа Arduino Software 1.0.6 выдаёт сообщение:
a library named DHT already exists
a library named Time already exists
a library named TimeAlarms already exists
Андрей,
из каких соображений строка
