Помогите с кодом.
Сб, 25/03/2017 - 22:47
Сильно не пинайте) пока постигаю.
#include <TimeAlarms.h>
#include <DHT.h>
#define DHTPIN 12
#define DHTTYPE DHT22
#define S_ON 0
#define S_OFF 1
#define NO_ACTION 0
#define IN_RANGE 1
#define OUT_RANGE 2
typedef struct RunCondition {
int socketPin;
float tempBegin;
float tempEnd;
int tempMode;
float humBegin;
float humEnd;
int humMode;
#define NUM_SOCKETS 3
RunCondition sockets[NUM_SOCKETS] = {
2,
26.0,
100.0,
IN_RANGE,
0.0,
0.0,
NO_ACTION
3,
20.0,
IN_RANGE,
0.0,
0.0,
NO_ACTION
4,
20.0,
100.0,
IN_RANGE,
0.0,
70.0,
IN_RANGE
int socketStatus[NUM_SOCKETS]; // S_OFF - выключено, S_ON - включено.
DHT dht(DHTPIN, DHTTYPE);
float temp = 0;
float hum = 0;
int displayMode = 0;
void setSockets() {
for (int i = 0; i < NUM_SOCKETS; i++) {
digitalWrite(sockets[i].socketPin, socketStatus[i]);
void printSensors() {
Serial.print("[ >> ] Temperature: "); Serial.print(temp); Serial.print(" C;\tHumidity: "); Serial.print(hum); Serial.println("%");
Serial.begin(115200);
Serial.println("[ ++ ] v.1.1.d");
dht.begin();
socketStatus[i] = S_OFF;
pinMode(sockets[i].socketPin, OUTPUT);
setSockets();
Alarm.timerRepeat(5, printSensors);
displayInfo();
void displayInfo() {
Alarm.delay(1000);
temp = dht.readTemperature();
hum = dht.readHumidity();
if (isnan(temp) || isnan(hum)) {
for (int i = 0; i < NUM_SOCKETS; i++) socketStatus[i] = S_OFF;
setSockets();
Serial.println("[FAIL] Can't read sensor data! Turn everithing OFF!");
return;
for (int s = 0; s < NUM_SOCKETS; s++) {
int tempStatus = S_OFF;
switch (sockets[s].tempMode) {
case NO_ACTION:
tempStatus = S_ON;
case IN_RANGE:
if ((temp >= sockets[s].tempBegin) && (temp <= sockets[s].tempEnd)) tempStatus = S_ON;
case OUT_RANGE:
if ((temp <= sockets[s].tempBegin) || (temp >= sockets[s].tempEnd)) tempStatus = S_ON;
int humStatus = S_OFF;
switch (sockets[s].humMode) {
case NO_ACTION:
humStatus = S_ON;
case IN_RANGE:
if ((hum >= sockets[s].humBegin) && (hum <= sockets[s].humEnd)) humStatus = S_ON;
case OUT_RANGE:
if ((hum <= sockets[s].humBegin) || (hum >= sockets[s].humEnd)) humStatus = S_ON;
int newStatus = S_OFF;
if ((tempStatus == S_ON) && (humStatus == S_ON)) newStatus = S_ON;
if (socketStatus[s] != newStatus) {
Serial.print("[ OK ] Socket #"); Serial.print(s); Serial.print(" status has changed to "); Serial.println(newStatus);
socketStatus[s] = newStatus;
setSockets();
при проверке выдает ошибку (warning: 'typedef' was ignored in this declaration)
Извините, но я не понял зачем такая пляска(смешение) в коде.
Где вы увидели ошибку? ворнинг - это предупреждение. Уберите typedef и ворнинг пропадёт...
