Помогите с кодом для приемника и передатчика пожалуйста?
Втр, 19/07/2016 - 13:52
Привет всем разбирающимся. Помогите пожалуйста, код не компилируется, ошибка в 57 строке пункта СТАТУС. Но почему он ему не нравится японять не могу..
Приемник:
/******************************************************************************** * RC boat transmitter using nRF24L01+ * * * * * * The following links proved helpful in using the nrf24L01 * * NRF24L01 With Arduinios SPI Library http://www.elecfreaks.com/480.html * * NRF24L01 Module Demo For Arduino http://www.elecfreaks.com/203.html * * * * * * CS - Arduino digital pin 8, nRF24L01 pin 3 (CE) * * CSN - Arduino digital pin 9, nRF24L01 pin 4 (CSN) * * MOSI - Arduino digital pin 11, nRF24L01 pin 6 (MOSI) * * MISO - Arduino digital pin 12, nRF24L01 pin 7 (MISO) * * CLK - Arduino digital pin 13, nRF24L01 pin 5 (SCK) * * * /*******************************************************************************/ #include <SPI.h> #include "nRF24L01.h" #define TX_ADR_WIDTH 5 #define TX_PLOAD_WIDTH 9 #define CE 8 #define CSN 9 #define IRQ 10 int ledPin = 2; //LED int speed_x; int speed_y; int potPin_x = 0; //potentiometer to control the speed of motor 1 int potPin_y = 1; //potentiometer to control the speed of motor 2 // Define a static TX address unsigned char TX_ADDRESS[TX_ADR_WIDTH] = { 0x34, 0x43, 0x10, 0x10, 0x01 }; unsigned char rx_buf[TX_PLOAD_WIDTH] = { 0 }; // initialize value unsigned char tx_buf[TX_PLOAD_WIDTH] = "UUU/XY*$"; //************************************************** void setup() { Serial.begin( 9600 ); pinMode( ledPin, OUTPUT ); pinMode( CE, OUTPUT ); pinMode( CSN, OUTPUT ); pinMode( IRQ, INPUT ); pinMode(potPin_x, INPUT); pinMode(potPin_y, INPUT); SPI.begin(); delay( 50 ); init_io(); // Initialize IO port unsigned char status = SPI_Read( STATUS ); Serial.println( "*** Get Status ***" ); Serial.print( "status = " ); Serial.println( status, HEX ); // read the modes status register, //the default value should be 'E' Serial.println( "******************" ); TX_Mode(); // set TX mode /* String helloWorld = "hello world\n"; for ( int i = 0; i < helloWorld.length(); i++ ) tx_buf[i] = (unsigned char)helloWorld[i]; */ blink(ledPin, 10, 200); //indicate start/restart } //************************************************** void loop() { int k = 0; speed_x = analogRead(potPin_x)/4; speed_y = analogRead(potPin_y)/4; //if ( speed_x < 50 ) speed_x = 50; //if ( speed_y < 50 ) speed_y = 50; tx_buf[4] = speed_x; tx_buf[5] = speed_y; Serial.print("Speed: "); Serial.print(speed_x); Serial.print(", "); Serial.println(speed_y); /* Serial.print(" "); Serial.write(tx_buf, sizeof(tx_buf)); Serial.println(" |"); */ unsigned char status = SPI_Read( STATUS ); // read register STATUS's value // Data Sent TX FIFO interrupt, packet transmitted on TX, ACK received if( status & TX_DS ) { SPI_RW_Reg( FLUSH_TX, 0 ); // write playload to TX_FIFO SPI_Write_Buf( W_TX_PAYLOAD, tx_buf, TX_PLOAD_WIDTH ); } //Maximum number of TX retransmits occurred // if receive data ready (MAX_RT) interrupt, this is retransmit than SETUP_RETR if( status & MAX_RT ) { SPI_RW_Reg( FLUSH_TX, 0 ); SPI_Write_Buf( W_TX_PAYLOAD, tx_buf, TX_PLOAD_WIDTH ); // disable standy-mode } // clear RX_DR or TX_DS or MAX_RT interrupt flag SPI_RW_Reg( W_REGISTER + STATUS, status ); delay( 600 ); } //************************************************** void blink(int whatPin, int howManyTimes, int milliSecs) { for ( int i = 0; i < howManyTimes; i++) { digitalWrite(whatPin, LOW); delay(milliSecs/2); digitalWrite(whatPin, HIGH); delay(milliSecs/2); } } //************************************************** void init_io(void) { digitalWrite( IRQ, 0 ); digitalWrite( CE, 0 ); // chip enable digitalWrite( CSN, 1 ); // SPI disable } //************************************************** unsigned char SPI_Read( unsigned char reg ) { unsigned char reg_val; digitalWrite( CSN, 0 ); // CSN low, initialize SPI communication... SPI_RW( reg ); // Select register to read from.. reg_val = SPI_RW( 0 ); // ..then read register value digitalWrite( CSN, 1 ); // CSN high, terminate SPI communication return( reg_val ); // return register value } //************************************************** unsigned char SPI_RW( unsigned char Byte ) { return SPI.transfer( Byte ); } //************************************************** unsigned char SPI_Read_Buf( unsigned char reg, unsigned char *pBuf, unsigned char bytes ) { unsigned char status, i; digitalWrite( CSN, 0 ); // Set CSN low, init SPI tranaction status = SPI_RW( reg ); // Select register to write to and read status unsigned char for( i = 0; i < bytes; i++ ) { pBuf[i] = SPI_RW( 0 ); // Perform SPI_RW to read unsigned char from nRF24L01 } digitalWrite( CSN, 1 ); // Set CSN high again return( status ); // return nRF24L01 status unsigned char } //************************************************** unsigned char SPI_Write_Buf( unsigned char reg, unsigned char *pBuf, unsigned char bytes ) { unsigned char status, i; digitalWrite( CSN, 0 ); // Set CSN low, init SPI tranaction status = SPI_RW( reg ); // Select register to write to and read status unsigned char for( i = 0; i < bytes; i++ ) // then write all unsigned char in buffer(*pBuf) { SPI_RW( *pBuf++ ); } digitalWrite( CSN, 1 ); // Set CSN high again return( status ); // return nRF24L01 status unsigned char } //************************************************** unsigned char SPI_RW_Reg( unsigned char reg, unsigned char value ) { unsigned char status; digitalWrite( CSN, 0 ); // CSN low, init SPI transaction status = SPI_RW( reg ); // select register SPI_RW( value ); // ..and write value to it.. digitalWrite( CSN, 1 ); // CSN high again return( status ); // return nRF24L01 status unsigned char } //************************************************** void TX_Mode( void ) { digitalWrite( CE, 0 ); SPI_Write_Buf( W_REGISTER + TX_ADDR, TX_ADDRESS, TX_ADR_WIDTH ); // Writes TX_Address to nRF24L01 SPI_Write_Buf( W_REGISTER + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH ); // RX_Addr0 same as TX_Adr for Auto.Ack SPI_RW_Reg( W_REGISTER + EN_AA, 0x01 ); // Enable auto acknowledgement data pipe 0 SPI_RW_Reg( W_REGISTER + EN_RXADDR, 0x01 ); // Enable data pipe 0 SPI_RW_Reg( W_REGISTER + SETUP_RETR, 0x1a ); // auto retransmit delay = 500us, retransmit count = 10 SPI_RW_Reg( W_REGISTER + RF_CH, 40 ); // Select RF channel 40 SPI_RW_Reg( W_REGISTER + RF_SETUP, 0x07 ); // TX_PWR:0dBm, Datarate:2Mbps, LNA:HCURR SPI_RW_Reg( W_REGISTER + CONFIG, 0x0e ); // POWER UP, enable 2-byte CRC & PTX as RX/TX control // RX_DR, TX_DS & MAX_RT interrupts enabled SPI_Write_Buf( W_TX_PAYLOAD, tx_buf, TX_PLOAD_WIDTH ); digitalWrite( CE, 1 ); }
Передатчик:
/******************************************************************************** * RC Boat receiver using nRF24L01+ * * * * * * The following links proved helpful in using the nrf24L01 * * NRF24L01 With Arduinios SPI Library http://www.elecfreaks.com/480.html * * NRF24L01 Module Demo For Arduino http://www.elecfreaks.com/203.html * * * * * * CS - Arduino digital pin 8, nRF24L01 pin 3 (CE) * * CSN - Arduino digital pin 9, nRF24L01 pin 4 (CSN) * * MOSI - Arduino digital pin 11, nRF24L01 pin 6 (MOSI) * * MISO - Arduino digital pin 12, nRF24L01 pin 7 (MISO) * * CLK - Arduino digital pin 13, nRF24L01 pin 5 (SCK) * * * /*******************************************************************************/ #include <SPI.h> #include "nRF24L01.h" #define TX_ADR_WIDTH 5 #define TX_PLOAD_WIDTH 9 #define CE 8 #define CSN 9 #define IRQ 10 #define MOSI 11 #define MISO 12 int EN_A = 5; // to 1,2EN of L293D int EN_B = 6; // to 3,4EN of L293D int IN_A1 = 2; // to 1A of L293D int IN_A2 = 3; // to 2A of L293D int IN_B1 = 4; // to 3A of L293D int IN_B2 = 7; // to 4A of L293D int speed = 100; boolean dir = 1; // 1 (true) indicates forward, 0 indicates reverse // Define a static TX address unsigned char TX_ADDRESS[TX_ADR_WIDTH] = { 0x34, 0x43, 0x10, 0x10, 0x01 }; unsigned char rx_buf[TX_PLOAD_WIDTH] = { 0 }; // initialize value unsigned char tx_buf[TX_PLOAD_WIDTH] = { 0 }; int x_val = 0; int y_val = 0; int left_speed = 0; int right_speed = 0; unsigned long time = 0; //************************************************** void setup() { Serial.begin( 9600 ); init_motors(); pinMode( CE, OUTPUT ); pinMode( CSN, OUTPUT ); pinMode( IRQ, INPUT ); pinMode( MOSI, OUTPUT ); pinMode( MISO, INPUT ); SPI.begin(); delay( 50 ); init_io(); // Initialize IO port unsigned char status = SPI_Read( STATUS ); Serial.println( "*** Get Status ***" ); Serial.print( "status = " ); Serial.println( status, HEX ); // read the modes status register, // the default value should be 'E' Serial.println( "******************" ); RX_Mode(); // set RX mode } //************************************************** void loop() { int k = 0; int i = 0, j = 0, fail = 0, found = 0; int lim = TX_PLOAD_WIDTH; unsigned char value[lim]; for( i = 0; i < lim; i++ ) { rx_buf[i] = 0; } unsigned char status = SPI_Read( STATUS ); // read register STATUS's value if( status & RX_DR ) // if receive data ready (TX_DS) interrupt { SPI_Read_Buf( R_RX_PAYLOAD, rx_buf, TX_PLOAD_WIDTH ); // read playload to rx_buf SPI_RW_Reg( FLUSH_RX, 0 ); // clear RX_FIFO for ( i = 0; i < lim ; i++ ) value[i] = 0; i = 0; j = 0; while( (rx_buf[i++] != '/') && !fail ) { if ( i > lim ) { fail = 1; break; } if ( rx_buf[i] == '/' ) found = 1; } if ( found == 1 && !fail ) { while( (rx_buf[i] != '*') && !fail ) { if ( i > lim ) { fail = 1; break; } value[j++] = rx_buf[i++]; if ( rx_buf[i] == '*' ) found = 2; } if ( found == 2 && !fail ) { x_val = value[0]; y_val = value[1]; time = millis(); if ( y_val < 130 || y_val > 140 ) { if ( y_val < 130 ) { y_val = map( y_val, 130, 0, 0, 255 ); dir = 0; } else if ( y_val > 140 ) { y_val = map( y_val, 140, 255, 0, 255 ); dir = 1; } left_speed = y_val; right_speed = y_val; if ( x_val < 120 || x_val > 130 ) { if ( x_val < 120 ) { // turn left x_val = map( x_val, 120, 0, 0, y_val ); left_speed -= x_val; } else if ( x_val > 130 ) { // turn right x_val = map( x_val, 130, 255, 0, y_val ); right_speed -= x_val; } } } else { left_speed = 0; right_speed = 0; } set_left_motor(left_speed, dir); set_right_motor(right_speed, dir); Serial.print("speed: "); Serial.print(left_speed); Serial.print(", "); Serial.print(right_speed); Serial.print(", direction:"); Serial.println(dir); x_val = 0; y_val = 0; left_speed = right_speed = 0; } } if ( fail ) { Serial.println("FAIL"); stop_motors(); } /* for( i=0; i < strlen((char *)rx_buf); i++ ) { //Serial.print( rx_buf[i], HEX ); // print rx_buf as HEX Serial.write( rx_buf[i] ); // print rx_buf as Ascii Characters } //Serial.println( " " ); */ } SPI_RW_Reg( W_REGISTER+STATUS, status ); // clear RX_DR or TX_DS or MAX_RT interrupt flag if ( millis() - time > 2000 ) { // stop stop_motors(); //Serial.println("timeout"); } // delay( 1000 ); } //************************************************** void init_io (void ) { digitalWrite( IRQ, 0 ); digitalWrite( CE, 0 ); // chip enable digitalWrite( CSN, 1 ); // SPI disable } //************************************************** unsigned char SPI_Read( unsigned char reg ) { unsigned char reg_val; digitalWrite( CSN, 0 ); // CSN low, initialize SPI communication... SPI_RW( reg ); // Select register to read from.. reg_val = SPI_RW( 0 ); // ..then read register value digitalWrite( CSN, 1 ); // CSN high, terminate SPI communication return( reg_val ); // return register value } //************************************************** unsigned char SPI_RW( unsigned char Byte ) { return SPI.transfer( Byte ); } //************************************************** unsigned char SPI_Read_Buf( unsigned char reg, unsigned char *pBuf, unsigned char bytes ) { unsigned char status, i; digitalWrite( CSN, 0 ); // Set CSN low, init SPI tranaction status = SPI_RW( reg ); // Select register to write to and read status unsigned char for( i = 0; i < bytes; i++ ) { pBuf[i] = SPI_RW( 0 ); // Perform SPI_RW to read unsigned char from nRF24L01 } digitalWrite( CSN, 1 ); // Set CSN high again return( status ); // return nRF24L01 status unsigned char } //************************************************** unsigned char SPI_Write_Buf( unsigned char reg, unsigned char *pBuf, unsigned char bytes ) { unsigned char status, i; digitalWrite( CSN, 0 ); // Set CSN low, init SPI tranaction status = SPI_RW( reg ); // Select register to write to and read status unsigned char for( i = 0; i < bytes; i++ ) // then write all unsigned char in buffer(*pBuf) { SPI_RW( *pBuf++ ); } digitalWrite( CSN, 1 ); // Set CSN high again return( status ); // return nRF24L01 status unsigned char } //************************************************** unsigned char SPI_RW_Reg( unsigned char reg, unsigned char value ) { unsigned char status; digitalWrite( CSN, 0 ); // CSN low, init SPI transaction status = SPI_RW( reg ); // select register SPI_RW( value ); // ..and write value to it.. digitalWrite( CSN, 1 ); // CSN high again return( status ); // return nRF24L01 status unsigned char } //************************************************** void RX_Mode( void ) { digitalWrite( CE, 0 ); SPI_Write_Buf( W_REGISTER + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH ); // use same address as transmitting device SPI_RW_Reg( W_REGISTER + EN_AA, 0x01 ); // Enable auto acknowledgement data pipe 0 SPI_RW_Reg( W_REGISTER + EN_RXADDR, 0x01 ); // Enable data pipe 0 SPI_RW_Reg( W_REGISTER + RF_CH, 40 ); // Select RF channel 40 SPI_RW_Reg( W_REGISTER + RX_PW_P0, TX_PLOAD_WIDTH );// Select same RX payload width as TX Payload width SPI_RW_Reg( W_REGISTER + RF_SETUP, 0x07 ); // TX_PWR:0dBm, Datarate:2Mbps, LNA:HCURR SPI_RW_Reg( W_REGISTER + CONFIG, 0x0f ); // POWER UP, enable 2-byte CRC & PRX as RX/TX control // RX_DR, TX_DS & MAX_RT interrupts enabled digitalWrite( CE, 1 ); } void init_motors() { // set output modes pinMode(IN_A1, OUTPUT); pinMode(IN_A2, OUTPUT); pinMode(IN_B1, OUTPUT); pinMode(IN_B2, OUTPUT); pinMode(EN_A, OUTPUT); pinMode(EN_B, OUTPUT); // initialize ports to safely turn off the motors stop_motors(); } void stop_motors(){ set_left_motor( 0, dir); set_right_motor( 0, dir); } void set_left_motor(int speed, boolean dir) { speed = constrain(speed, 0, 255); analogWrite(EN_A, speed); // PWM on enable lines digitalWrite(IN_A1, dir); digitalWrite(IN_A2, ! dir); } void set_right_motor(int speed, boolean dir) { speed = constrain(speed, 0, 255); analogWrite(EN_B, speed); digitalWrite(IN_B1, dir); digitalWrite(IN_B2, ! dir); }
Не могу ничего сделать..
Вообще-то в ошибке как раз и написано, что ему не нравится. Или Вы думаете, что английские буковки (из которых состоят слова и предложения) там просто так написаны? Предлагаете нам самостоятельно угадывать, какое сообщение об ошибке выдал компилятор?
[/quote]
[/quote]
нет тут ошибки
написано по англ мол идет чтение регистра СТАТУС
нет тут ошибки
Серъезно? А это что? - error: 'STATUS' was not declared in this scope
Это Вы сами придумали, там написано совсем другое. Хоть бы гугл переводчиком воспользовались, он бы Вам перевёл - Ошибка: "СТАТУС" не был объявлен в этой области.
Чувствую, там подобных ошибок много будет. У Вас установлена библиотека nRF24L01? Догадываюсь, что нет. Качаете zip архив, распаковываете оттуда папку "RF24-master". Переименовываете, убираете из названия слово master, чтобы получилось просто "RF24". Перемещаете эту папку в "Мои документы\Arduino\libraries\". Перезагружаете Arduino IDE. Строку 19 меняете с #include "nRF24L01.h" на #include <nRF24L01.h> После этого код должен скомпилироваться без ошибок.
Жека! Там проблема глубже. ТС библиотеку nRF24L01.h подключает в кавычках. Константа STATUS определена там. Следовательно библиотека не подключена.
Но ТС этого не заметил, что любопытно....
ТС, уважаемый! Разберись с подключением библиотек!
И запомни - в "кавычках" подключение файла из текущего каталога. в <уголках> - из стандартых каталогов библиотек. Используя библиотеку, сперва подключи ее в систему - прямо в среде есть пункт "подключить библиотеку".
пока писал, опоздал, но стирать не стану! ;)
спасибо сейчас попробую
извените, мы не правильно поняли друг друга. ошибка то есть, просто я перевел то, что написано в коменте а не в ошибке
Подключил все и исправил все пункты. Все равно он ругается на статус..
Чудес не бывает. Я проверил у себя - установил библиотеку и скомпировал Ваш код - у меня всё скомпилировалось без единой ошибки. Проверил на двух версиях Arduino IDE - 1.0.5-r2 и 1.6.6
Ещё раз внимательно прочитайте сообщение #5 и в точности выполните все рекомендации. Библиотеку подключать рекомендую всё же вручную, а не через пункт "подключить библиотеку" в среде. Убедитесь, что в папке с библиотеками только одна RF24 и других больше нет (типа RF24-master и т.д.)
Сделал в точности как вы сказали, попробывал так и попробывал без 4 верхних строчек..
и в ручную подключил и через "подключить библиотеку, ничего не выходит
может в моих кривых руках дело?
Я не уверен, но попробуйте STATUS заменить на NRF_STATUS.
STATUS был в более старой версии библиотеки
4 верхних строчки точно не нужны. Да же не знаю, в чём проблема, вроде всё правильно сделали. Попробуйте скачать более старую версию Arduino IDE, например 1.6.6 - https://www.arduino.cc/en/Main/OldSoftwareReleases
Выше я давал ссылку на гитхаб. Не знаю, какая там версия, но у меня нормально скомпилировалось со STATUS.
Zip оттуда не качается. С библиотекой по первой ссылке не компилируется. с NRF_STATUS все нормально.
У Вас походу более старая версия. Она в архивах лежит.
Странно, у меня качается. ОК, вот страница проекта - https://github.com/maniacbug/RF24
В файле nRF24L01.h в строке 33: #define STATUS 0x07
Вот нашел другую библиотеку, тоже на гитхабе - https://github.com/tmrh20/RF24
Здесь в файле nRF24L01.h в строке 34: #define NRF_STATUS 0x07
Да, так что Вы правы, проблема из-за разных версий библиотеки.
спасибо всем, скомпилировалось. но реакции 0. возможно дело в том что у меня не просто джойстик а шилд от ROBODYN и выходы не подходят
