Помогите со скетчем пожалуйста!
Gapash
  Здравствуйте!
Вот скетч:
#define Btn_plus_minute   9
#define Btn_minus_minute  10
#define Btn_Start_minute  8
#define Provod_Stop       A3
#define ledPin 13
int timerFlag=0;
int duration=30;
int uskorenie=500;
boolean polovinaFlag=0;
#include "TM1637Display.h"
#define DISPLAY_CLK_PIN 11
#define DISPLAY_DIO_PIN 12
TM1637Display display(DISPLAY_CLK_PIN, DISPLAY_DIO_PIN);
unsigned char hour=0;
unsigned char minute=30;
unsigned char second=0;
unsigned char halfsecond=0;
unsigned long timeTimer=0;
unsigned long startTimer=0;
   display.set(7);
   display.init();
   //Serial.begin(9600);
  pinMode(Btn_plus_minute,   INPUT_PULLUP);
  pinMode(Btn_minus_minute,  INPUT_PULLUP);
  pinMode(Btn_Start_minute,  INPUT_PULLUP);
  pinMode(ledPin, OUTPUT);
  opros_knopok();
  timer();
  displey();
void opros_knopok() {
   if (digitalRead(Btn_plus_minute)==LOW) {delay (250), duration++;}
   if (digitalRead(Btn_minus_minute)==LOW){delay (250), duration--;
     if(duration==0){duration=60;}}
   if (digitalRead(Btn_Start_minute)==LOW){delay (250); timerFlag=1;
       uskorenie=500; polovinaFlag=0; startTimer=millis();}
   if (analogRead(Provod_Stop)>20)  {delay (150),timerFlag=0;}
void timer() {
  if (timerFlag==1){timeTimer = (millis()- startTimer);
     if (timeTimer>=uskorenie){
     halfsecond ++;
      if(halfsecond == 2){halfsecond = 0, second-- ;}
        if(second == 0){second = 59, duration--;
 if (timerFlag==1 && duration==-1){
   second = 0;
   startTimer=0;
   duration=0;
   timeTimer=0;
   timerFlag=0;
   digitalWrite(ledPin, HIGH);
   polovinaFlag=0;
void displey() {
   hour=duration/60;
   minute=duration-(hour*60);
 if (duration>=60){
   int8_t timeDisp[4];
   timeDisp[0] = hour / 10;
   timeDisp[1] = hour % 10;
   timeDisp[2] = minute / 10;
   timeDisp[3] = minute % 10;
   display.display(timeDisp);
   display.point(halfsecond ==1 ? POINT_OFF : POINT_ON);
 if (duration<60){
   int8_t timeDisp[4];
   timeDisp[0] = minute / 10;
   timeDisp[1] = minute % 10;
   timeDisp[2] = second / 10;
   timeDisp[3] = second % 10;
На этих строчках вылезает ошибка:
   display.set(7);
   display.init();
Тест ошибки:
'class TM1637Display' has no member named 'set'
Тест ошибки:
'class TM1637Display' has no member named 'init'
В чем проблема?
Скетч не мой. Плата ардуино нано.
mixail844
Gapash пишет:
   display.set(7);
   display.init();
Тест ошибки:
Тест ошибки:
В чем проблема?
проблема в том что , в классе ТМ1637Display нет члена с именем 'set'  и нет члена именем 'init'
Gapash
Да спасибо, уже разобрался. Оказалась библиотека не та. Библиотеку поменял на нужную, теперь не может загрузить скетч в нано, пишет:
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x81
Проблема загрузки в плату.
(таких строчек от 1 до 10)
Как думаете в чем может быть проблема?
Gapash
а все, вопрос решен. В настройказ надо было выбрать не ATMega 320P, a ATMega 320P (Old Bootloader)
Gapash пишет:
Там и такое есть? Чудны дела твои, Господи.
Gapash
Сарказм?
Oreshek
Oreshek аватар
Gapash пишет:
... ATMega 320P...
нИ когда нИ слышал про такой проц, китайцы наверно не давно изобрели? да? :-)
Gapash пишет:
Сарказм?
Почему? Просто, не знал, что такое бывает, а теперь буду знать. Спасибо, что сказали.
Gapash
ну с кем не бывает:(
Gapash
Только правильно товарищ сверху подметил- не 320 а 328Р :)
