Помогите в скетч всроить очистку буфера
Сб, 23/01/2016 - 00:11
Помогите в в скетч всроить очистку буфера
/// drain the serial buffer
while(Serial.available()>0){ Serial.read(); }
////////// // Requires: https://github.com/FastLED/FastLED/releases/tag/3.0.3 // // Arduino interface for the use of ws2812 operated LEDs // Uses Adalight protocol and is compatible with Boblight, Prismatik etc // "Magic Word" for synchronisation is 'Ada' followed by LED High, Low and Checksum // #include <FastLED.h> ///// User definitions ///// // Define YOUR number of LEDs #define NUM_LEDS 111 // Define YOUR Input Pin #define PIN 6 // Baudrate, higher rate allows faster refresh rate and more LEDs (defined in /etc/boblight.conf) #define serialRate 115200 // Adalight sends a "Magic Word" (defined in /etc/boblight.conf) before sending the pixel data uint8_t prefix[] = {'A', 'd', 'a'}, hi, lo, chk, i; // initialise LED-array CRGB leds[NUM_LEDS]; void setup() { FastLED.addLeds<WS2812B, PIN, GRB>(leds, NUM_LEDS); FastLED.setBrightness(40); // initial RGB flash LEDS.showColor(CRGB(255, 0, 0)); delay(500); LEDS.showColor(CRGB(0, 255, 0)); delay(500); LEDS.showColor(CRGB(0, 0, 255)); delay(500); LEDS.showColor(CRGB(0, 0, 0)); Serial.begin(serialRate); Serial.print("Ada\n"); // Send "Magic Word" string to host } void loop() { // wait for first byte of Magic Word for(i = 0; i < sizeof prefix; ++i) { waitLoop: while (!Serial.available()) ;; // Check next byte in Magic Word if(prefix[i] == Serial.read()) continue; // otherwise, start over i = 0; goto waitLoop; } // Hi, Lo, Checksum while (!Serial.available()) ;; hi=Serial.read(); while (!Serial.available()) ;; lo=Serial.read(); while (!Serial.available()) ;; chk=Serial.read(); // if checksum does not match go back to wait if (chk != (hi ^ lo ^ 0x55)) { i=0; goto waitLoop; } memset(leds, 0, NUM_LEDS * sizeof(struct CRGB)); // read the transmission data and set LED values for (uint8_t i = 0; i < NUM_LEDS; i++) { byte r, g, b; while(!Serial.available()); r = Serial.read(); while(!Serial.available()); g = Serial.read(); while(!Serial.available()); b = Serial.read(); leds[i].r = r; leds[i].g = g; leds[i].b = b; } // shows new values FastLED.show(); }
А в чем собственно проблема? Как первые две строчки кода скопировать в остальные 90?
именно :)
не знаю куда их вставить в скетче. Я вообще не знаю C++
помогите пожалуйста , вы моя последняя надежда
