Поправить код
Втр, 24/03/2015 - 00:28
Есть такой код
#include <Wire.h>
#include "DS1307.h"
#include "OasisLED.h"
#include <Arduino.h>
#include <IRremote.h>
#include <RCSwitch.h>
int RECV_PIN = 11;
uint8_t clockPin = 3;
uint8_t strobePin = 2;
uint8_t dataPin = 4;
OasisLED ledDisplay = OasisLED(clockPin, strobePin, dataPin);
IRrecv irrecv(RECV_PIN);
decode_results results;
uint8_t dout = 5;
int i=0;
int ky0, key1,key2,key3,key4,key5;
const static uint8_t READKEY = 0x42;
byte a,b,button1,button2,button3,button4,key11,key12;
byte incoming;
int wordd;
RCSwitch mySwitch = RCSwitch();
DS1307 clock;//define a object of DS1307 class
pinMode(dout, INPUT_PULLUP);
clock.begin();
ledDisplay.initialize();
// clock.fillByYMD(2015,3,9);//Jan 19,2013
// clock.fillByHMS(22,47,30);//15:28 30"
// clock.fillDayOfWeek(SUN);//Saturday
// clock.setTime();//write time to the RTC chip
irrecv.enableIRIn(); // Start the receiver
mySwitch.enableTransmit(10);
mySwitch.setPulseLength(251);
printTime();
digitalWrite(strobePin, LOW);
for (uint8_t i = 0; i < 8; i++) {
shiftOut(dataPin, clockPin, LSBFIRST, READKEY);
ky0=shiftIn(dout, clockPin, LSBFIRST);
key1 = shiftIn(dout, clockPin, LSBFIRST);
key2 = shiftIn(dout, clockPin, LSBFIRST);
key3 = shiftIn(dout, clockPin, LSBFIRST);
key4 = shiftIn(dout, clockPin, LSBFIRST);
key5 = shiftIn(dout, clockPin, LSBFIRST);
digitalWrite(strobePin, HIGH);
key11=key1;
key12=key2;
button1=key11&1;
button2=(key11&8)/8;
button3=key12&1;
button4=(key12&8)/8;
// wordd=button1*1+button2*10+button3*100+button4*1000;
// ledDisplay.setValue(wordd);
/*Function: Display time on the serial monitor*/
void printTime()
clock.getTime();
// Serial.print(clock.hour, DEC);
// Serial.print(":");
// Serial.print(clock.minute, DEC);
// Serial.print(clock.second, DEC);
// Serial.print(" ");
// Serial.print(clock.month, DEC);
// Serial.print("/");
// Serial.print(clock.dayOfMonth, DEC);
// Serial.print(clock.year+2000, DEC);
// Serial.print(clock.dayOfMonth);
// Serial.print("*");
ledDisplay.setValue(clock.hour*100+clock.minute);
if(irrecv.decode(&results))
Serial.println(results.value, HEX);
if ((results.value == 0x37) || (results.value == 0x10037))
mySwitch.send(836656,24); // если код код получен зажигаем зал
delay (500);
irrecv.resume();
Вывожу часы на 7 сегментный индикатор, а так же реализовано управление люстрой через ик порт. В переменной button храниться код кнопки - как реализовать такое: нажал кнопку (button1) - добавились часы, нажал button2 - добавились минуты ???
(как реализовать такое: нажал кнопку (button1) - добавились часы, нажал button2 - добавились минуты ???)
1)Определяем нажатали кнопка,
2)счиываем значение часов или минун в переменную,
3)Добавляем 1
4)Записываем назад
5) Добавляем паузу, чтобы успеть отпустить кнопку
В коде я вижу вот так, работоспособность проверял в Протеусе
// Подключаем все необходимые библиотеки и указываем пины подключения #include <Wire.h> #include <DS1307.h> //Подключение библиотеки для DS1307 byte chasA = 0; //Переменная для Часа byte minA = 0; //Переменная для minut // Следующие переменные нужны чтобы не сбить настройки byte denA = 0; // Переменная номера дня недели byte chisA = 0; // Переменная число byte mesA = 0; // Переменная месяц byte godA = 0; // Переменная год byte sekA = 0; // Переменная секунды void setup() { //Serial.begin(9600); } //Объявляем функцию установки даты и времени void ustanovkaChasov() { RTC.stop(); // останавливаем ход часов RTC.set(DS1307_SEC,sekA); // устанавливаем секунды RTC.set(DS1307_MIN,minA); // устанавливаем минуты RTC.set(DS1307_HR,chasA); // устанавливаем часы RTC.set(DS1307_DOW,denA); // устанавливаем номер дня недели RTC.set(DS1307_DATE,chisA); // устанавливаем число RTC.set(DS1307_MTH,mesA); // устанавливаем месяц RTC.set(DS1307_YR,godA); // устанавливаем год RTC.start(); // запускаем ход часов } //Объявляем функцию Читаем значения даты и времени void pokazChasov() { sekA = RTC.get(DS1307_SEC, true); // Читаем значения секунды minA = RTC.get(DS1307_MIN, true); // Читаем значения минуты chasA = RTC.get(DS1307_HR, true); // Читаем значения часы denA = RTC.get(DS1307_DOW, true); // Читаем значения номер дня недели chisA = RTC.get(DS1307_DATE, true); // Читаем значения число mesA = RTC.get(DS1307_MTH, true); // Читаем значения месяц godA = RTC.get(DS1307_YR, true); // Читаем значения год } void loop() { if (button1 == LOW) { pokazChasov(); chasA = chasA + 1; ustanovkaChasov(); delay(500); } if (button2 == LOW) { pokazChasov(); minA = minA + 1; ustanovkaChasov(); delay(500); } }
