После этой ошибки все удалилось!
Чт, 10/09/2015 - 10:58
Exception in thread "AWT-EventQueue-0" java.lang.ArrayIndexOutOfBoundsException: 0
at processing.app.Sketch.setCurrentCode(Sketch.java:1182)
at processing.app.Sketch.load(Sketch.java:220)
at processing.app.Sketch.<init>(Sketch.java:142)
at processing.app.Editor.handleOpenInternal(Editor.java:2157)
at processing.app.Editor.<init>(Editor.java:304)
at processing.app.Base.handleOpen(Base.java:704)
at processing.app.Base.handleOpen(Base.java:669)
at processing.app.Base.handleOpenPrompt(Base.java:658)
at processing.app.Editor$4.actionPerformed(Editor.java:497)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1995)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2318)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:387)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:242)
at javax.swing.AbstractButton.doClick(AbstractButton.java:357)
at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:1225)
at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:1266)
at java.awt.Component.processMouseEvent(Component.java:6263)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3267)
at java.awt.Component.processEvent(Component.java:6028)
at java.awt.Container.processEvent(Container.java:2041)
at java.awt.Component.dispatchEventImpl(Component.java:4630)
at java.awt.Container.dispatchEventImpl(Container.java:2099)
at java.awt.Component.dispatchEvent(Component.java:4460)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4574)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4238)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4168)
at java.awt.Container.dispatchEventImpl(Container.java:2085)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:599)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
Можно ли восстановить код?
Насколько я понимаю, у Вас "упало" Arduino IDE, и в редакторе в этот момент был несохраненный код ? Боюсь, у меня плохие новости...
+1
У меня привычка нажимать периодически Ctrl+S в любом редакторе давно выработалась, руки сами машинально нажимают :) Чтобы потом не возникало вот таких неприятных моментов. Всяким автосохранениям раз в 5 минут не доверяю.
Не угадали... Ардуина у меня вообще не была подключена! Я дописал код, нажал сохранить, после сохранения, кода нет, и эта ошибка.
Хорошо хоть исходники остались! Тоесть его уже никак не восстановишь. Н спасибо...
F3 на дисках *.ino пробовали?
Зачем Вам "код", если есть исходники? Arduino_IDE компилит код из исходников и заливает его сразу в чип. Отдельно этот код нужен в очень экзотических случаях...
Да вы не поняли, у меня есть исходники, в смысле куски скетча, которые еще дорабатывать нужно....
