Проблема с кодом
Xer0x_king
Добрый день, уважаемые форумчане. Сильно не пинайте за вопрос: искал в интернете.Так и не нашел
Изучаю ардуинку сравнительно недавно. Захотел собрать готовый проект погодной станции на базе ардуино мини.
Собрал, залил скетч
// eDOT: Versatile precision weather station and clock
//HISTORY
// 11/12/2105 Added measurement calibration coefficients
// 09/06/2016 Added automatic display brightness
// 09/06/2016 Added task scheduler
// 07/08/2016 Added eDOT splashscreen
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Max72xxPanel.h>
#include <Average.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
#include "RTClib.h"
#include <EasyScheduler.h>
Adafruit_BME280 bme; // I2C
RTC_DS3231 rtc;
int pinCS = 10; // Attach CS to this pin, DIN to MOSI and CLK to SCK (cf http://arduino.cc/en/Reference/SPI )
int numberOfHorizontalDisplays = 7;
int numberOfVerticalDisplays = 1;
Max72xxPanel matrix = Max72xxPanel(pinCS, numberOfHorizontalDisplays, numberOfVerticalDisplays);
#define TEMPERATURE 0
#define HUMIDITY    1
#define PRESSURE    2
#define TIME        3
#define DAY         4
#define DATE        5
float temp;
float tempavg;
char tempf[8];
float hum;
float humavg;
char humf[8];
float press;
float pressavg;
char pressf[8];
int screen = 0;                                                 // initial screen
long previousLEDMillis = 0;                                     // for LED display update
long LEDInterval = 5000;                                        // delay between screens
int screenMax = 5;                                              // maximum number of screen
bool screenChanged = true;                                     // screen status
float lightsens;
float screenBrt = 0;
float lightsensavg;
Average<float> avetemp(60);                                     //Average for temperature (80 samples)
Average<float> avehum(60);                                      //Average for humidity (80 samples)
Average<float> avepress(60);                                    //Average for pressure (80 samples)
Average<float> avelightsens(40);                                //Average for pressure (80 samples)
//Calibration coefficients
float temp_o = -1.70;
float temp_s = 1.0;
float temp_lin;
float hum_o = 2.45;
float hum_s = 1.0;
float hum_lin;
float press_o = 0.0;
float press_s = 1.0;
float press_lin;
//Brightness sensor correction
float brt_o = -4;
float brt_s = 1.35;
Schedular Task1;
Schedular Task2;
  Task1.start();
  Task2.start();
  Wire.begin();  // Start I2C
  bme.begin(0x76);
  matrix.setIntensity(screenBrt); // Use a value between 0 and 15 for brightness
// Adjust to your own needs
//  matrix.setPosition(0, 0, 0); // The first display is at <0, 0>
//  matrix.setPosition(1, 1, 0); // The second display is at <1, 0>
  matrix.setRotation(0, 1);                                      // Adjust display orientation
  matrix.setRotation(1, 1);                                      // Adjust display orientation
  matrix.setRotation(2, 1);                                      // Adjust display orientation
  matrix.setRotation(3, 1);                                      // Adjust display orientation
  matrix.setRotation(4, 1);                                      // Adjust display orientation
  matrix.setRotation(5, 1);                                      // Adjust display orientation
  matrix.setRotation(6, 1);                                      // Adjust display orientation
  matrix.setRotation(7, 1);                                      // Adjust display orientation
 matrix.setRotation(8, 1);                                       // Adjust display orientation
 matrix.setRotation(9, 1);                                       // Adjust display orientation
  rtc.begin();
//  matrix.setRotation(3, 2);    // The same hold for the last display
//  rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
// rtc.adjust(DateTime(2016, 02, 28, 16, 44, 0));
//Serial.begin(9600);
//eDOT SPLASHSCREEN
 matrix.fillScreen(0);
  matrix.write();
  matrix.setCursor(12,0);
  matrix.print("eDOT");
  for(screenBrt = 0; screenBrt <=15; screenBrt++){
delay(25);
  matrix.write();
delay(250);
  for(screenBrt = 15; screenBrt >= 0; screenBrt--){
delay(50);
  matrix.write();
delay(500);
  matrix.write();
    Task1.check(acq1,500);
    Task2.check(acq2,20);
  void acq1(){
// DATA ACQUISITION AND AVERAGING
  temp = bme.readTemperature();
  avetemp.push(temp);
  tempavg = avetemp.mean();
  hum = bme.readHumidity();
  avehum.push(hum);
  humavg = avehum.mean();
  press = bme.readPressure();
  avepress.push(press);
  pressavg = avepress.mean();
  DateTime now = rtc.now();
  outSec = now.second();
  outMin = now.minute();
  outHour = now.hour();
  outday = now.day();
  outmonth = now.month();
  outyear = now.year() - 2000;
  dow = now.dayOfTheWeek();
  void acq2(){
  lightsens = analogRead(A3);
  avelightsens.push(lightsens);
  lightsensavg = avelightsens.mean();
  screenBrt = constrain(((lightsensavg /1023 * 15 ) * brt_s + brt_o), 0 , 15);
// DATA LINEARISATION
  temp_lin = tempavg * temp_s + temp_o;
  hum_lin = humavg * hum_s + hum_o;
  press_lin = pressavg * press_s + press_o;
  unsigned long currentLEDMillis = millis();
 //Serial.println(screenBrt);
  if(currentLEDMillis - previousLEDMillis > LEDInterval)          // save the last time you changed the display
    previousLEDMillis = currentLEDMillis;
    screen++;
    if (screen > screenMax) screen = 0;                           // reset to initial screen once cycle is completed
//  if (screenChanged)                                            // update measurement upon screen change
//    screenChanged = false;                                      // reset for next iteration
switch(screen){
case TEMPERATURE:
  dtostrf(temp_lin,4, 2, tempf);                                   // format to five digits with two decimals
  matrix.setCursor(6,0);
  matrix.setTextSize(1);
  matrix.setTextColor(255);
  matrix.print(tempf);                                            // print current temperature
  matrix.drawRect(37,0,2,2,255);                                  // draw grade symbol
  matrix.setCursor(40,0);
  matrix.print("C");
  matrix.write();                                                 // write current data to display
  matrix.fillScreen(0);                                           // clear display
case HUMIDITY:
  dtostrf(hum_lin,4, 2, humf);                                     // format to five digits with two decimals
  matrix.print(humf);                                             // print current temperature
  matrix.setCursor(37,0);
  matrix.print("%");
case PRESSURE:
  dtostrf(press_lin,6, 0, pressf);                                 // format to five digits with two decimals
  matrix.setCursor(0,0);
  matrix.print(pressf);                                           // print current temperature
  matrix.print("Pa");
case TIME:
//  dtostrf(press_lin,6, 0, pressf);                                 // format to five digits with two decimals
   if (outHour < 10){
   matrix.print("0");
  matrix.print(outHour,0);                                           // print current hours
  matrix.print(":");
   if (outMin < 10){
   matrix.print("0");
  matrix.print(outMin,0);                                           // print current minutes
  matrix.print(":");
   if (outSec < 10){
   matrix.print("0");
  matrix.print(outSec,0);                                           // print current seconds
case DATE:
   if (outday < 10){
   matrix.print("0");
  matrix.print(outday,0);                                           // print current hours
  matrix.print("/");
     if (outmonth < 10){
   matrix.print("0");
  matrix.print(outmonth,0);                                           // print current minutes
  matrix.print("/");
  matrix.print(outyear,0);                                           // print current seconds
case DAY:
  matrix.setCursor(15,0);
  matrix.print(daysOfTheWeek[dow]);
Но проект не идет. Ругается, аки собака. на отсутствие переменных.
D:\РґСѓСЂРґСѓРёРЅРѕ\edot__versatile_precision_weather_station_and_clock\edot__versatile_precision_weather_station_and_clock.ino: In function 'void acq1()':
edot__versatile_precision_weather_station_and_clock:161: error: 'outyear' was not declared in this scope
edot__versatile_precision_weather_station_and_clock:162: error: 'outmonth' was not declared in this scope
edot__versatile_precision_weather_station_and_clock:163: error: 'outday' was not declared in this scope
edot__versatile_precision_weather_station_and_clock:164: error: 'dow' was not declared in this scope
edot__versatile_precision_weather_station_and_clock:165: error: 'outHour' was not declared in this scope
edot__versatile_precision_weather_station_and_clock:166: error: 'outMin' was not declared in this scope
edot__versatile_precision_weather_station_and_clock:167: error: 'outSec' was not declared in this scope
D:\РґСѓСЂРґСѓРёРЅРѕ\edot__versatile_precision_weather_station_and_clock\edot__versatile_precision_weather_station_and_clock.ino: In function 'void acq2()':
edot__versatile_precision_weather_station_and_clock:244: error: 'outHour' was not declared in this scope
edot__versatile_precision_weather_station_and_clock:247: error: 'outHour' was not declared in this scope
edot__versatile_precision_weather_station_and_clock:249: error: 'outMin' was not declared in this scope
edot__versatile_precision_weather_station_and_clock:252: error: 'outMin' was not declared in this scope
edot__versatile_precision_weather_station_and_clock:254: error: 'outSec' was not declared in this scope
edot__versatile_precision_weather_station_and_clock:257: error: 'outSec' was not declared in this scope
edot__versatile_precision_weather_station_and_clock:267: error: 'outday' was not declared in this scope
edot__versatile_precision_weather_station_and_clock:270: error: 'outday' was not declared in this scope
edot__versatile_precision_weather_station_and_clock:272: error: 'outmonth' was not declared in this scope
edot__versatile_precision_weather_station_and_clock:275: error: 'outmonth' was not declared in this scope
edot__versatile_precision_weather_station_and_clock:277: error: 'outyear' was not declared in this scope
edot__versatile_precision_weather_station_and_clock:287: error: 'daysOfTheWeek' was not declared in this scope
edot__versatile_precision_weather_station_and_clock:287: error: 'dow' was not declared in this scope
exit status 1
'outyear' was not declared in this scope.
Помогите разобраться. Что изменить. Ночь просидел - так и не смог понять
Jeka_M
Jeka_M аватар
В строках 011 - 017 подключены сторонние библиотеки. Вам нужно их найти и установить.
okta
Просто объявите эти переменные (глобально). Про отсутсвие библиотек не вижу ошибок.
Xer0x_king
Доброго времени суток. Помогло простое решение, описанное выше: объявил переменную и все...
Все равно проект не пошел, как надо. Ищу нормальный проект метеостанции
zibazon
еще может помочь объявление не глобально а в функции
что то по типу
int outyear=чему-то;
Xer0x_king пишет:
Пишите свой. это проще, чем искать готовый
Xer0x_king
Спасибо за совет. Но пока мои каляки - маляки не компилируются нормально. Нашел более менее нормальный, но его нужно обработать напилиником и обпилить ножовкой. свое конечно лучше, но пока как то не получается
