Программирование nodemCU в Arduino IDE
vit2ska
Есть код:
#define IP_FORWARD 1
#include <ESP8266WiFi.h>
#include <WiFiUDP.h>
// Set these to your desired credentials for ESP8266 AP.
const char *ssid = "ESPap";
const char *password = "";
IPAddress apIP(192, 168, 4, 1);
//const char* ssidExt = "dlink";
//const char* passwordExt = "";
// Setup credentials for original WiFi, that we plan to repeat
const char* ssidExt = "Ptech 208";
const char* passwordExt = ""; //TEJ8Pod2DE2pk
const byte DNS_PORT = 53;
int cb;
int noBytes;
WiFiUDP Udp;
byte packetBuffer[512];
WiFiUDP Udp8;
IPAddress ip(192, 168, 0, 13);
IPAddress gateway(10, 254, 20, 1);
IPAddress subnet(255, 255, 254, 0);
  Serial.begin(115200);
  Serial.println();
   WiFi.mode(WIFI_AP_STA);
   //WiFi.mode(WIFI_AP);
  Serial.println(" ");
  WiFi.begin(ssidExt, passwordExt);
  WiFi.config(ip, gateway, subnet);
    delay(500);
    Serial.print(".");
  Serial.println("");
  Serial.print("Подключено к ");
  Serial.println(ssidExt);
  Serial.print("IP адрес: ");
  Serial.println(WiFi.localIP());
  Serial.print("dnsIP адрес: ");
  Serial.println(WiFi.dnsIP());
  Serial.print("gatewayIP адрес: ");
  Serial.println(WiFi.gatewayIP());
  Serial.print("subnetMask адрес: ");
  Serial.println(WiFi.subnetMask());
  Serial.println("");
  Serial.println("Настройки точки доступа...");
  WiFi.softAPConfig(apIP, apIP, IPAddress(255, 255, 255, 0));
  WiFi.softAP(ssid, password);
  IPAddress myIP = WiFi.softAPIP();
  Serial.print("AP IP адрес: ");
  Serial.println(myIP);
  Udp.begin(DNS_PORT);
  Udp8.begin(DNS_PORT);
  noBytes = Udp.parsePacket();
  if ( noBytes ) {
        Serial.print(millis() / 1000);
        Serial.print(":Пакет ");
        Serial.print(noBytes);
        Serial.print(" получен от ");
        Serial.print(Udp.remoteIP());
        Serial.print(":");
        Serial.println(Udp.remotePort());
    Udp.read(packetBuffer, noBytes);
        for (int i = 1; i <= noBytes; i++) {
          Serial.print(packetBuffer[i - 1], HEX);
          if (i % 32 == 0) {
            Serial.println();
          else Serial.print(' ');
        Serial.println();
    IPAddress ip8(192, 168, 1, 1);
    Udp8.beginPacket(ip8, 53);
    Udp8.write(packetBuffer, noBytes);
    Udp8.endPacket();
    delay(100);
    cb = Udp8.parsePacket();
    if (!cb) {
      Serial.print("пакета нет, длина= ");
      Serial.println(cb);
    else {
            Serial.print("пакет получен, длина=");
            Serial.println(cb);
      byte packetBuffer8[cb];
      Udp8.read(packetBuffer8, cb);
      Udp.beginPacket(Udp.remoteIP(), Udp.remotePort());
      Udp.write(packetBuffer8, cb);
      Udp.endPacket();
  } // end if
Он должен работать как повторитель. Модуль должен подключаться к точке доступа Wifi, потом создается точка доступа. Подключаюсь с устройства, пошли пакеты, но нет пакетов ответа.
Проблемма с загрузкой картинки: https://ibb.co/fO10sG
Penni
Penni аватар
В строке номер 100 что за айпишник?
