Прошивка bootloader в Mega2560 через UNO
Всем доброго времени суток! Пытаюсь прошить другой загрузчик в Мегу 2560 чтобы иметь возможность использовать ватчдог зависаний (wdt_). IDE 1.0, как программатор использую Duemilanove с 328 камнем и прошитым скетчем Arduino ISP, код ниже:
// this sketch turns the Arduino into a AVRISP // using the following pins: // 10: slave reset // 11: MOSI // 12: MISO // 13: SCK // Put an LED (with resistor) on the following pins: // 9: Heartbeat - shows the programmer is running // 8: Error - Lights up if something goes wrong (use red if that makes sense) // 7: Programming - In communication with the slave // // October 2009 by David A. Mellis // - Added support for the read signature command // // February 2009 by Randall Bohn // - Added support for writing to EEPROM (what took so long?) // Windows users should consider WinAVR's avrdude instead of the // avrdude included with Arduino software. // // January 2008 by Randall Bohn // - Thanks to Amplificar for helping me with the STK500 protocol // - The AVRISP/STK500 (mk I) protocol is used in the arduino bootloader // - The SPI functions herein were developed for the AVR910_ARD programmer // - More information at http://code.google.com/p/mega-isp #include "pins_arduino.h" // defines SS,MOSI,MISO,SCK #define RESET SS #define LED_HB 9 #define LED_ERR 8 #define LED_PMODE 7 #define HWVER 2 #define SWMAJ 1 #define SWMIN 18 // STK Definitions #define STK_OK 0x10 #define STK_FAILED 0x11 #define STK_UNKNOWN 0x12 #define STK_INSYNC 0x14 #define STK_NOSYNC 0x15 #define CRC_EOP 0x20 //ok it is a space... void pulse(int pin, int times); void setup() { Serial.begin(115200); pinMode(7, OUTPUT); pulse(7, 2); pinMode(8, OUTPUT); pulse(8, 2); pinMode(9, OUTPUT); pulse(9, 2); } int error=0; int pmode=0; // address for reading and writing, set by 'U' command int here; uint8_t buff[256]; // global block storage #define beget16(addr) (*addr * 256 + *(addr+1) ) typedef struct param { uint8_t devicecode; uint8_t revision; uint8_t progtype; uint8_t parmode; uint8_t polling; uint8_t selftimed; uint8_t lockbytes; uint8_t fusebytes; int flashpoll; int eeprompoll; int pagesize; int eepromsize; int flashsize; } parameter; parameter param; // this provides a heartbeat on pin 9, so you can tell the software is running. uint8_t hbval=128; int8_t hbdelta=8; void heartbeat() { if (hbval > 192) hbdelta = -hbdelta; if (hbval < 32) hbdelta = -hbdelta; hbval += hbdelta; analogWrite(LED_HB, hbval); delay(20); } void loop(void) { // is pmode active? if (pmode) digitalWrite(LED_PMODE, HIGH); else digitalWrite(LED_PMODE, LOW); // is there an error? if (error) digitalWrite(LED_ERR, HIGH); else digitalWrite(LED_ERR, LOW); // light the heartbeat LED heartbeat(); if (Serial.available()) { avrisp(); } } uint8_t getch() { while(!Serial.available()); return Serial.read(); } void readbytes(int n) { for (int x = 0; x < n; x++) { buff[x] = Serial.read(); } } #define PTIME 30 void pulse(int pin, int times) { do { digitalWrite(pin, HIGH); delay(PTIME); digitalWrite(pin, LOW); delay(PTIME); } while (times--); } void spi_init() { uint8_t x; SPCR = 0x53; x=SPSR; x=SPDR; } void spi_wait() { do { } while (!(SPSR & (1 << SPIF))); } uint8_t spi_send(uint8_t b) { uint8_t reply; SPDR=b; spi_wait(); reply = SPDR; return reply; } uint8_t spi_transaction(uint8_t a, uint8_t b, uint8_t c, uint8_t d) { uint8_t n; spi_send(a); n=spi_send(b); //if (n != a) error = -1; n=spi_send(c); return spi_send(d); } void empty_reply() { if (CRC_EOP == getch()) { Serial.print((char)STK_INSYNC); Serial.print((char)STK_OK); } else { Serial.print((char)STK_NOSYNC); } } void breply(uint8_t b) { if (CRC_EOP == getch()) { Serial.print((char)STK_INSYNC); Serial.print((char)b); Serial.print((char)STK_OK); } else { Serial.print((char)STK_NOSYNC); } } void get_version(uint8_t c) { switch(c) { case 0x80: breply(HWVER); break; case 0x81: breply(SWMAJ); break; case 0x82: breply(SWMIN); break; case 0x93: breply('S'); // serial programmer break; default: breply(0); } } void set_parameters() { // call this after reading paramter packet into buff[] param.devicecode = buff[0]; param.revision = buff[1]; param.progtype = buff[2]; param.parmode = buff[3]; param.polling = buff[4]; param.selftimed = buff[5]; param.lockbytes = buff[6]; param.fusebytes = buff[7]; param.flashpoll = buff[8]; // ignore buff[9] (= buff[8]) //getch(); // discard second value // WARNING: not sure about the byte order of the following // following are 16 bits (big endian) param.eeprompoll = beget16(&buff[10]); param.pagesize = beget16(&buff[12]); param.eepromsize = beget16(&buff[14]); // 32 bits flashsize (big endian) param.flashsize = buff[16] * 0x01000000 + buff[17] * 0x00010000 + buff[18] * 0x00000100 + buff[19]; } void start_pmode() { spi_init(); // following delays may not work on all targets... pinMode(RESET, OUTPUT); digitalWrite(RESET, HIGH); pinMode(SCK, OUTPUT); digitalWrite(SCK, LOW); delay(50); digitalWrite(RESET, LOW); delay(50); pinMode(MISO, INPUT); pinMode(MOSI, OUTPUT); spi_transaction(0xAC, 0x53, 0x00, 0x00); pmode = 1; } void end_pmode() { pinMode(MISO, INPUT); pinMode(MOSI, INPUT); pinMode(SCK, INPUT); pinMode(RESET, INPUT); pmode = 0; } void universal() { int w; uint8_t ch; for (w = 0; w < 4; w++) { buff[w] = getch(); } ch = spi_transaction(buff[0], buff[1], buff[2], buff[3]); breply(ch); } void flash(uint8_t hilo, int addr, uint8_t data) { spi_transaction(0x40+8*hilo, addr>>8 & 0xFF, addr & 0xFF, data); } void commit(int addr) { spi_transaction(0x4C, (addr >> 8) & 0xFF, addr & 0xFF, 0); } //#define _current_page(x) (here & 0xFFFFE0) int current_page(int addr) { if (param.pagesize == 32) return here & 0xFFFFFFF0; if (param.pagesize == 64) return here & 0xFFFFFFE0; if (param.pagesize == 128) return here & 0xFFFFFFC0; if (param.pagesize == 256) return here & 0xFFFFFF80; return here; } uint8_t write_flash(int length) { if (param.pagesize < 1) return STK_FAILED; //if (param.pagesize != 64) return STK_FAILED; int page = current_page(here); int x = 0; while (x < length) { if (page != current_page(here)) { commit(page); page = current_page(here); } flash(LOW, here, buff[x++]); flash(HIGH, here, buff[x++]); here++; } commit(page); return STK_OK; } uint8_t write_eeprom(int length) { // here is a word address, so we use here*2 // this writes byte-by-byte, // page writing may be faster (4 bytes at a time) for (int x = 0; x < length; x++) { spi_transaction(0xC0, 0x00, here*2+x, buff[x]); delay(45); } return STK_OK; } void program_page() { char result = (char) STK_FAILED; int length = 256 * getch() + getch(); if (length > 256) { Serial.print((char) STK_FAILED); return; } char memtype = getch(); for (int x = 0; x < length; x++) { buff[x] = getch(); } if (CRC_EOP == getch()) { Serial.print((char) STK_INSYNC); if (memtype == 'F') result = (char)write_flash(length); if (memtype == 'E') result = (char)write_eeprom(length); Serial.print(result); } else { Serial.print((char) STK_NOSYNC); } } uint8_t flash_read(uint8_t hilo, int addr) { return spi_transaction(0x20 + hilo * 8, (addr >> 8) & 0xFF, addr & 0xFF, 0); } char flash_read_page(int length) { for (int x = 0; x < length; x+=2) { uint8_t low = flash_read(LOW, here); Serial.print((char) low); uint8_t high = flash_read(HIGH, here); Serial.print((char) high); here++; } return STK_OK; } char eeprom_read_page(int length) { // here again we have a word address for (int x = 0; x < length; x++) { uint8_t ee = spi_transaction(0xA0, 0x00, here*2+x, 0xFF); Serial.print((char) ee); } return STK_OK; } void read_page() { char result = (char)STK_FAILED; int length = 256 * getch() + getch(); char memtype = getch(); if (CRC_EOP != getch()) { Serial.print((char) STK_NOSYNC); return; } Serial.print((char) STK_INSYNC); if (memtype == 'F') result = flash_read_page(length); if (memtype == 'E') result = eeprom_read_page(length); Serial.print(result); return; } void read_signature() { if (CRC_EOP != getch()) { Serial.print((char) STK_NOSYNC); return; } Serial.print((char) STK_INSYNC); uint8_t high = spi_transaction(0x30, 0x00, 0x00, 0x00); Serial.print((char) high); uint8_t middle = spi_transaction(0x30, 0x00, 0x01, 0x00); Serial.print((char) middle); uint8_t low = spi_transaction(0x30, 0x00, 0x02, 0x00); Serial.print((char) low); Serial.print((char) STK_OK); } ////////////////////////////////////////// ////////////////////////////////////////// //////////////////////////////////// //////////////////////////////////// int avrisp() { uint8_t data, low, high; uint8_t ch = getch(); switch (ch) { case '0': // signon empty_reply(); break; case '1': if (getch() == CRC_EOP) { Serial.print((char) STK_INSYNC); Serial.print("AVR ISP"); Serial.print((char) STK_OK); } break; case 'A': get_version(getch()); break; case 'B': readbytes(20); set_parameters(); empty_reply(); break; case 'E': // extended parameters - ignore for now readbytes(5); empty_reply(); break; case 'P': start_pmode(); empty_reply(); break; case 'U': here = getch() + 256 * getch(); empty_reply(); break; case 0x60: //STK_PROG_FLASH low = getch(); high = getch(); empty_reply(); break; case 0x61: //STK_PROG_DATA data = getch(); empty_reply(); break; case 0x64: //STK_PROG_PAGE program_page(); break; case 0x74: //STK_READ_PAGE read_page(); break; case 'V': universal(); break; case 'Q': error=0; end_pmode(); empty_reply(); break; case 0x75: //STK_READ_SIGN read_signature(); break; // expecting a command, not CRC_EOP // this is how we can get back in sync case CRC_EOP: Serial.print((char) STK_NOSYNC); break; // anything else we will return STK_UNKNOWN default: if (CRC_EOP == getch()) Serial.print((char)STK_UNKNOWN); else Serial.print((char)STK_NOSYNC); } }
Подключено по схеме:
Дуе ------> Мега(ICSP коннектор)
10 5
11 4
12 1
13 3
5V 2
GND 6
При прошивке высталяю в настройках плату Мега 2560 или Мега АДК, порграмматор Arduino as ISP, жмакаю Burn bootloader, он тупит немного помигивая Rx Tx на ДУЕ и выдает ошибку avrdude: stk500_getsync(): not in sync: resp=0xff
Есть идеи как это победить? Ставил конденсатор 10мкФ 50В между ресетом и + на ДУЕ, эффекта ноль =(
HEX модифицированного загрузчика и файл boards.txt
При использовании УНЫ вместо ДУЕ - результат полностью идентичен:
гавно из светодиодов убери нахрен и больше так никогда не делай
Убрал, как и ожидалось - эффекта нет :( они типо для отслеживания состояния программатора, хэртбит кстати исправно мигает, а вот статус и ошибки только при инициализации мыргают.
Светодиоды без резюков - жесть.
При прошивке загрузчика плату какую выбираешь?
Мегу конечно. Без резиков, потому что на коленке :)
А кондер зачем там стоит?
внезапно липиздричество пропадёт - кондёр будет питать халабуду 0,01 сек.
кстати, куда кондёр подключен?
Во многих инструкциях сказано ставить 10 мкФ межу ресетом и землей, для избежания автоматической перезагрузки программатора. Что с ним, что без - одинаково не работает. :(
IDE 1.0 - ты издеваешься?
Пробывал на 1.0.4 и на 1.6.x, везде одинаково, шестая висит подольше правда..
Тоесть вариантов больше нет? =(
варианты есть - у всех всё работает, перепроверяй правильность подключения у себя.
