простое обращение к датчику температуры DS18B20
Alex_
Тема конечно избитая, но как то не получается просто изменив код указав адрес обратится к конкретному датчику из двух.
Подскажите в чем проблема?
Делаю:
  // assign address manually.  the addresses below will beed to be changed
  // to valid device addresses on your bus.  device address can be retrieved
  // by using either oneWire.search(deviceAddress) or individually via
  //insideThermometer = { 0x28, 0x1D, 0x39, 0x31, 0x2, 0x0, 0x0, 0xF0 };
  //outsideThermometer   = { 28, 0x3F, 0x1C, 0x31, 0x2, 0x0, 0x0, 0x2 };
  insideThermometer    = { 0x28, 0x71, 0xF0, 0xB1, 0x06, 0x00, 0x00, 0xD8 };
  outsideThermometer   = { 0x28, 0x07, 0x5F, 0x59, 0x07, 0x00, 0x00, 0x50 };
//oneWire.search(deviceAddress)
  // search for devices on the bus and assign based on an index.  ideally,
  // you would do this to initially discover addresses on the bus and then
  // use those addresses and manually assign them (see above) once you know
  // the devices on your bus (and assuming they don't change).
  // method 1: by index
  //if (!sensors.getAddress(insideThermometer, 0)) Serial.println("Unable to find address for Device 0");
  //if (!sensors.getAddress(outsideThermometer, 1)) Serial.println("Unable to find address for Device 1");
  // method 2: search()
  // search() looks for the next device. Returns 1 if a new address has been
  // returned. A zero might mean that the bus is shorted, there are no devices,
  // or you have already retrieved all of them.  It might be a good idea to
  // check the CRC to make sure you didn't get garbage.  The order is
  // deterministic. You will always get the same devices in the same order
  // Must be called before search()
  //oneWire.reset_search();
  // assigns the first address found to insideThermometer
  //if (!oneWire.search(insideThermometer)) Serial.println("Unable to find address for insideThermometer");
  // assigns the seconds address found to outsideThermometer
  //if (!oneWire.search(outsideThermometer)) Serial.println("Unable to find address for outsideThermometer");
из :
#include <OneWire.h>
// Data wire is plugged into port 2 on the Arduino
#define ONE_WIRE_BUS 2
#define TEMPERATURE_PRECISION 9
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
// Pass our oneWire reference to Dallas Temperature.
// arrays to hold device addresses
DeviceAddress insideThermometer, outsideThermometer;
void setup(void)
  // start serial port
  Serial.println("Dallas Temperature IC Control Library Demo");
  // Start up the library
  sensors.begin();
  // locate devices on the bus
  Serial.print("Locating devices...");
  Serial.print("Found ");
  Serial.print(sensors.getDeviceCount(), DEC);
  Serial.println(" devices.");
  // report parasite power requirements
  Serial.print("Parasite power is: ");
  if (sensors.isParasitePowerMode()) Serial.println("ON");
  else Serial.println("OFF");
  // sensors.getAddress(deviceAddress, index)
  //outsideThermometer   = { 0x28, 0x3F, 0x1C, 0x31, 0x2, 0x0, 0x0, 0x2 };
  // show the addresses we found on the bus
  Serial.print("Device 0 Address: ");
  printAddress(insideThermometer);
  Serial.println();
  Serial.print("Device 1 Address: ");
  printAddress(outsideThermometer);
  Serial.println();
  // set the resolution to 9 bit
  sensors.setResolution(insideThermometer, TEMPERATURE_PRECISION);
  sensors.setResolution(outsideThermometer, TEMPERATURE_PRECISION);
  Serial.print("Device 0 Resolution: ");
  Serial.print(sensors.getResolution(insideThermometer), DEC);
  Serial.println();
  Serial.print("Device 1 Resolution: ");
  Serial.print(sensors.getResolution(outsideThermometer), DEC);
  Serial.println();
// function to print a device address
void printAddress(DeviceAddress deviceAddress)
  for (uint8_t i = 0; i < 8; i++)
    // zero pad the address if necessary
    if (deviceAddress[i] < 16) Serial.print("0");
    Serial.print(deviceAddress[i], HEX);
// function to print the temperature for a device
void printTemperature(DeviceAddress deviceAddress)
  float tempC = sensors.getTempC(deviceAddress);
  Serial.print("Temp C: ");
  Serial.print(tempC);
  Serial.print(" Temp F: ");
  Serial.print(DallasTemperature::toFahrenheit(tempC));
// function to print a device's resolution
void printResolution(DeviceAddress deviceAddress)
  Serial.print("Resolution: ");
  Serial.print(sensors.getResolution(deviceAddress));
  Serial.println();
// main function to print information about a device
void printData(DeviceAddress deviceAddress)
  Serial.print("Device Address: ");
  printAddress(deviceAddress);
  Serial.print(" ");
  printTemperature(deviceAddress);
  Serial.println();
void loop(void)
  // call sensors.requestTemperatures() to issue a global temperature
  // request to all devices on the bus
  Serial.print("Requesting temperatures...");
  Serial.println("DONE");
  // print the device information
  printData(insideThermometer);
  printData(outsideThermometer);
и не работает.
Alex_
Есть, кто может помочь в вопросе обращения к датчику по заранее известному адрессу?
Без использования языка С и ему подобных.
Или ссылку на материал укажите, пожалуйста!
Alex_ пишет:
Какой же прикажете использовать - армейский матерный?
Alex_
А есть способ используя эти строки
08   insideThermometer    = { 0x28, 0x71, 0xF0, 0xB1, 0x06, 0x00, 0x00, 0xD8 };
09   outsideThermometer   = { 0x28, 0x07, 0x5F, 0x59, 0x07, 0x00, 0x00, 0x50 };
и не углублясь в С
обращаться к датчикам.
Почему не работает обращение как сделано выше. Что не хватает?
Alex_ пишет:
а где там вообще скетч для обращения по адресу? там какие-то обрывки. приведите полный код
Нет такого способа. То, что вы написали - это ID-датчика. Он должен передаваться в функцию считывания. Это всё описывается на языке Wiring, Wiring есть обсахаренный C++. Круг замкнулся.
Alex_
полный код это второй. он рабочий.
В него вставляем строки 01-034 вместо строк 037-065 и получаем полный код но не рабтающий.
Alex_
Может можете код набрасать или сложно будет?
Вон оно чего...
Ну, тада, наверное надо так - 050-051 закомментировать, в районе 015 изобразить следующее:
//DeviceAddress insideThermometer, outsideThermometer;
DeviceAddress insideThermometer    = { 0x28, 0x71, 0xF0, 0xB1, 0x06, 0x00, 0x00, 0xD8 },
Alex_
1 //DeviceAddress insideThermometer, outsideThermometer;
2 DeviceAddress insideThermometer    = { 0x28, 0x71, 0xF0, 0xB1, 0x06, 0x00, 0x00, 0xD8 },
3               outsideThermometer   = { 0x28, 0x07, 0x5F, 0x59, 0x07, 0x00, 0x00, 0x50 };
ругается и не компилирует
3 DeviceAddress outsideThermometer   = { 0x28, 0x07, 0x5F, 0x59, 0x07, 0x00, 0x00, 0x50 };
компилирует но не работает
вот так сделайте:
DeviceAddress insideThermometer    = { 0x28, 0x71, 0xF0, 0xB1, 0x06, 0x00, 0x00, 0xD8 };
но работать от этого не начнет - ошибка я вно не в этом.
"Не работает" - в чем это выражается? Адреса датчиков печатает? Разрешение данных?
У меня всё отлично компилируется. А датчиков под рукой нет, так что проверять нечем.
Alex_
Адреса датчиков печатает.
Но
"Locating devices... 0
Device 0 Resolution 0
Device 1 Resolution 0
и температуры 0С и 32F
Резистор-то поставили на шину?
Alex_
Конечно.
Ведь 1й полный код работает корректно.
то есть в вашем коде не работает чуть ли не первый же запрос к датчикам, а в исходном коде - все работает? значит накосячили, когда переделывали код.
Выложите именно тот код, на котором пробуете - и который не работает, не надо этих ребусов в стиле "вот в этом коде заменяем строки 32-34 на строки 45-66"....
Alex_
этот код работает корректно:
#define ONE_WIRE_BUS 4
void setup(void)
  sensors.begin();
  else Serial.println("off");
//   sensors.getAddress(deviceAddress, 1 )
//  insideThermometer    = { 0x28, 0x71, 0xF0, 0xB1, 0x06, 0x00, 0x00, 0xD8 };
//  outsideThermometer   = { 0x28, 0x07, 0x5F, 0x59, 0x07, 0x00, 0x00, 0x50 };
  Serial.println();
  Serial.println();
  Serial.print("Device 9 Resolution: ");
  Serial.println();
  Serial.println();
  Serial.println();
  Serial.print(" ");
  Serial.println();
void loop(void)
    delay(5000); // Пауза между измерениями
Alex_
переделываем в этот:
void setup(void)
  sensors.begin();
// if (!sensors.getAddress(insideThermometer, 0)) Serial.println("Unable to find address for Device 0");
// if (!sensors.getAddress(outsideThermometer, 1)) Serial.println("Unable to find address for Device 1");
  Serial.println();
  Serial.println();
  Serial.println();
  Serial.println();
  Serial.println();
  Serial.print(" ");
  Serial.println();
void loop(void)
и он вроде как работает....
Alex_
Точно работает
Если изменить адресс - то не находит датчик.
СПАСИБО за помощь
