RFID 522
Yer
Здаравствуйте всем кто сталкивался RFID 522 ключами. Из примеров ардуино пробовал прочитать какой UID код написан на карточке или на брелках. Теперь хочу по пробовать поменять UID код на карточках но пока без резултатно
выкладывайте скетч. которым пробовали, проблемы конкретно описывайте.
Yer
Пробовал с примера в библиотеки MFRC522:
 * MFRC522 - Library to use ARDUINO RFID MODULE KIT 13.56 MHZ WITH TAGS SPI W AND R BY COOQROBOT.
 * The library file MFRC522.h has a wealth of useful info. Please read it.
 * The functions are documented in MFRC522.cpp.
 * Based on code Dr.Leong   ( WWW.B2CQSHOP.COM )
 * Created by Miguel Balboa (circuitito.com), Jan, 2012.
 * Rewritten by Søren Thing Andersen (access.thing.dk), fall of 2013 (Translation to English, refactored, comments, anti collision, cascade levels.)
 * Extended by Tom Clement with functionality to write to sector 0 of UID changeable Mifare cards.
 * Released into the public domain.
 * This sample shows how to set the UID on a UID changeable MIFARE card.
 ----------------------------------------------------------------------------- empty_skull
 - Aggiunti pin per arduino Mega
 - Scritto semplice codice per la scrittura e lettura
 - add pin configuration for arduino mega
 - write simple read/write Code for new entry user
 http://mac86project.altervista.org/
 ----------------------------------------------------------------------------- Nicola Coppola
 * Typical pin layout used:
 *             MFRC522      Arduino       Arduino   Arduino    Arduino          Arduino
 *             Reader/PCD   Uno           Mega      Nano v3    Leonardo/Micro   Pro Micro
 * Signal      Pin          Pin           Pin       Pin        Pin              Pin
 * RST/Reset   RST          9             5         D9         RESET/ICSP-5     RST
 * SPI SS      SDA(SS)      10            53        D10        10               10
 * SPI MOSI    MOSI         11 / ICSP-4   51        D11        ICSP-4           16
 * SPI MISO    MISO         12 / ICSP-1   50        D12        ICSP-1           14
 * SPI SCK     SCK          13 / ICSP-3   52        D13        ICSP-3           15
 * The reader can be found on eBay for around 5 dollars. Search for "mf-rc522" on ebay.com.
#include <SPI.h>
#include <MFRC522.h>
/* Set your new UID here! */
#define NEW_UID {0xDE, 0xAD, 0xBE, 0xEF}
#define SS_PIN 10
#define RST_PIN 9
MFRC522 mfrc522(SS_PIN, RST_PIN);        // Create MFRC522 instance.
MFRC522::MIFARE_Key key;
        Serial.begin(9600);        // Initialize serial communications with the PC
        while (!Serial);           // Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4)
        SPI.begin();               // Init SPI bus
        mfrc522.PCD_Init();        // Init MFRC522 card
        Serial.println(F("Warning: this example overwrites the UID of your UID changeable card, use with care!"));
        // Prepare key - all keys are set to FFFFFFFFFFFFh at chip delivery from the factory.
        for (byte i = 0; i < 6; i++) {
                key.keyByte[i] = 0xFF;
// Setting the UID can be as simple as this:
//void loop() {
//    byte newUid[] = NEW_UID;
//    if ( mfrc522.MIFARE_SetUid(newUid, (byte)4, true) ) {
//      Serial.println("Wrote new UID to card.");
//    delay(1000);
// But of course this is a more proper approach
        // Look for new cards, and select one if present
        if ( ! mfrc522.PICC_IsNewCardPresent() || ! mfrc522.PICC_ReadCardSerial() ) {
            delay(50);
            return;
        // Now a card is selected. The UID and SAK is in mfrc522.uid.
        // Dump UID
        Serial.print(F("Card UID:"));
        for (byte i = 0; i < mfrc522.uid.size; i++) {
                Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
                Serial.print(mfrc522.uid.uidByte[i], HEX);
        Serial.println();
        // Dump PICC type
//        byte piccType = mfrc522.PICC_GetType(mfrc522.uid.sak);
//        Serial.print(F("PICC type: "));
//        Serial.print(mfrc522.PICC_GetTypeName(piccType));
//        Serial.print(F(" (SAK "));
//        Serial.print(mfrc522.uid.sak);
//        Serial.print(")\r\n");
//        if (        piccType != MFRC522::PICC_TYPE_MIFARE_MINI
//                &&        piccType != MFRC522::PICC_TYPE_MIFARE_1K
//                &&        piccType != MFRC522::PICC_TYPE_MIFARE_4K) {
//                Serial.println(F("This sample only works with MIFARE Classic cards."));
//                return;
        // Set new UID
            Serial.println(F("Wrote new UID to card."));
        // Halt PICC and re-select it so DumpToSerial doesn't get confused
        mfrc522.PICC_HaltA();
                return;
        // Dump the new memory contents
        Serial.println(F("New UID and contents:"));
        mfrc522.PICC_DumpToSerial(&(mfrc522.uid));
        delay(2000);
повторяю - проблему описывайте конкретно.
Что не работает, или работает не так?
Yer
Загрузил скетч в ардуино который указал на форуме.Не изменилось UID код брелка
Yer пишет:
Послушайте, уважаемый! Кому это надо - форуму или вам? Почему из вас надо все клещами вытаскивать? Давайте просыпайтесь. Будете дальше тупить - решайте тогда проблемы сами.
Какие сообщения выводит скетч? Предупреждение о перезаписи есть? Старый UID карты читает? Ошибки какие-нибудь есть?
Yer
Никаких ошибок нету. Показывает старый UID код не записывает новый
Yer
У меня походу карты не прошиваются UID коды
