RFID-модуль RC522
zsm@nxt.ru
Долго бился с этим модулем научился считывать записанные RFID карты , но как самому что либо залить на карту так и не понял... Может есть у кого примеры под эту библиотеку?
zsm@nxt.ru
Нашлась ещё одна библиотека с примерами, но как на зло пример с записью не работает...(остальные 2 карты читают)
* MFRC522 - Library to use ARDUINO RFID MODULE KIT 13.56 MHZ WITH TAGS SPI W AND R BY COOQROBOT.
 * The library file MFRC522.h has a wealth of useful info. Please read it.
 * The functions are documented in MFRC522.cpp.
 * Based on code Dr.Leong   ( WWW.B2CQSHOP.COM )
 * Created by Miguel Balboa (circuitito.com), Jan, 2012.
 * Rewritten by Søren Thing Andersen (access.thing.dk), fall of 2013 (Translation to English, refactored, comments, anti collision, cascade levels.)
 * Released into the public domain.
 * This sample shows how to setup a block on a MIFARE Classic PICC to be in "Value Block" mode.
 * In Value Block mode the operations Increment/Decrement/Restore and Transfer can be used.
 ----------------------------------------------------------------------------- empty_skull
 - Aggiunti pin per arduino Mega
 - Scritto semplice codice per la scrittura e lettura
 - add pin configuration for arduino mega
 - write simple read/write Code for new entry user
 http://mac86project.altervista.org/
 ----------------------------------------------------------------------------- Nicola Coppola
 * Pin layout should be as follows:
 * Signal     Pin              Pin               Pin
 *            Arduino Uno      Arduino Mega      MFRC522 board
 * Reset      9                5                 RST
 * SPI SS     10               53                SDA
 * SPI MOSI   11               52                MOSI
 * SPI MISO   12               51                MISO
 * SPI SCK    13               50                SCK
 * The reader can be found on eBay for around 5 dollars. Search for "mf-rc522" on ebay.com.
#include <SPI.h>
#include <MFRC522.h>
#define SS_PIN 53
#define RST_PIN 5
MFRC522 mfrc522(SS_PIN, RST_PIN);        // Create MFRC522 instance.
        Serial.begin(9600);        // Initialize serial communications with the PC
        SPI.begin();                // Init SPI bus
        mfrc522.PCD_Init();        // Init MFRC522 card
        //Serial.println("Scan a MIFARE Classic PICC to demonstrate Value Blocks.");
        // Prepare key - all keys are set to FFFFFFFFFFFFh at chip delivery from the factory.
        MFRC522::MIFARE_Key key;
        for (byte i = 0; i < 6; i++) {
                key.keyByte[i] = 0xFF;
        // Look for new cards
        if ( ! mfrc522.PICC_IsNewCardPresent()) {
                return;
        // Select one of the cards
        if ( ! mfrc522.PICC_ReadCardSerial()) {
                return;
        // Now a card is selected. The UID and SAK is in mfrc522.uid.
        // Dump UID
        Serial.print("Card UID:");
        for (byte i = 0; i < mfrc522.uid.size; i++) {
                Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
                Serial.print(mfrc522.uid.uidByte[i], HEX);
        Serial.println();
        // Dump PICC type
        byte piccType = mfrc522.PICC_GetType(mfrc522.uid.sak);
        Serial.print("PICC type: ");
        Serial.println(mfrc522.PICC_GetTypeName(piccType));
        if (        piccType != MFRC522::PICC_TYPE_MIFARE_MINI
                &&        piccType != MFRC522::PICC_TYPE_MIFARE_1K
                &&        piccType != MFRC522::PICC_TYPE_MIFARE_4K) {
                //Serial.println("This sample only works with MIFARE Classic cards.");
                return;
        // In this sample we use the second sector (ie block 4-7). the first sector is = 0
        // scegliere settore di lettura da 0 = primo settore
        byte sector         = 1;
        // block sector 0-3(sector0) 4-7(sector1) 8-11(sector2)
        // blocchi di scrittura da 0-3(sector0) 4-7(sector1) 8-11(sector2)
        byte valueBlockA    = 4;
        byte valueBlockB    = 5;
        byte valueBlockC    = 6;
        byte trailerBlock   = 7;
        byte status;
        // Authenticate using key A.
        // avvio l'autentificazione A
        //Serial.println("Authenticating using key A...");
        status = mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, trailerBlock, &key, &(mfrc522.uid));
        if (status != MFRC522::STATUS_OK) {
                Serial.print("PCD_Authenticate() failed: ");
                Serial.println(mfrc522.GetStatusCodeName(status));
                return;
        // Authenticate using key B.
        // avvio l'autentificazione B
        //Serial.println("Authenticating again using key B...");
        status = mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_B, trailerBlock, &key, &(mfrc522.uid));
                return;
        // Writing new value block A
        // Scrivo i valori per il settore A
        Serial.println("Writing new value block A(4) : the first of the sector TWO ");
                byte value1Block[] = { 1,2,3,4,  5,6,7,8, 9,10,255,12,  13,14,15,16,   valueBlockA,~valueBlockA,valueBlockA,~valueBlockA };
                status = mfrc522.MIFARE_Write(valueBlockA, value1Block, 16);
                        Serial.print("MIFARE_Write() failed: ");
        // Writing new value block B
        // Scrivo i valori per il settore B
        Serial.println("Writing new value block B");
                byte value2Block[] = { 255,255,255,255,  0,0,0,0, 0,0,0,0,  255,255,255,255,   valueBlockB,~valueBlockB,valueBlockB,~valueBlockB };
                status = mfrc522.MIFARE_Write(valueBlockB, value2Block, 16);
        // Writing new value block D
        // Scrivo i valori per il settore C
        Serial.println("Writing new value block C");
                byte value3Block[] = { 255,255,255,255,  0,0,0,0, 0,0,0,0,  255,255,255,255,   valueBlockC,~valueBlockC,valueBlockC,~valueBlockC };
                status = mfrc522.MIFARE_Write(valueBlockC, value3Block, 16);
        Serial.println("Read block A(4) : the first of the sector TWO");
        byte buffer[18];
        byte size = sizeof(buffer);
        // change this: valueBlockA , for read anather block
        // cambiate valueBlockA per leggere un altro blocco
        status = mfrc522.MIFARE_Read(valueBlockA, buffer, &size);
        Serial.print("Settore : 0 Valore :");
        Serial.println(buffer[0]);
        Serial.print("Settore : 1 Valore :");
        Serial.println(buffer[1]);
        Serial.print("Settore : 2 Valore :");
        Serial.println(buffer[2]);
        Serial.print("Settore : 3 Valore :");
        Serial.println(buffer[3]);
        Serial.print("Settore : 4 Valore :");
        Serial.println(buffer[4]);
        Serial.print("Settore : 5 Valore :");
        Serial.println(buffer[5]);
        Serial.print("Settore : 6 Valore :");
        Serial.println(buffer[6]);
        Serial.print("Settore : 7 Valore :");
        Serial.println(buffer[7]);
        Serial.print("Settore : 8 Valore :");
        Serial.println(buffer[8]);
        Serial.print("Settore : 9 Valore :");
        Serial.println(buffer[9]);
        Serial.print("Settore :10 Valore :");
        Serial.println(buffer[10]);
        Serial.print("Settore :11 Valore :");
        Serial.println(buffer[11]);
        Serial.print("Settore :12 Valore :");
        Serial.println(buffer[12]);
        Serial.print("Settore :13 Valore :");
        Serial.println(buffer[13]);
        Serial.print("Settore :14 Valore :");
        Serial.println(buffer[14]);
        Serial.print("Settore :15 Valore :");
        Serial.println(buffer[15]);
        //byte value1Block[] = { 1,2,3,4,  5,6,7,8, 9,10,255,12,  13,14,15,16,   valueBlockA,~valueBlockA,valueBlockA,~valueBlockA };
        if (
        buffer[0]  == 1   &&
        buffer[1]  == 2   &&
        buffer[2]  == 3   &&
        buffer[3]  == 4   &&
        buffer[4]  == 5   &&
        buffer[5]  == 6   &&
        buffer[6]  == 7   &&
        buffer[7]  == 8   &&
        buffer[8]  == 9   &&
        buffer[9]  == 10  &&
        buffer[10] == 255 &&
        buffer[11] == 12  &&
        buffer[12] == 13  &&
        buffer[13] == 14  &&
        buffer[14] == 15  &&
        buffer[15] == 16
        // sel a scrittura è uguale alla lettura allora e stato un successo !!
        Serial.println("Read block A(4) : the first of the sector TWO : success");
        Serial.println(":-)");
        }else{
         //  scrittura Fallita
        Serial.println("Read block A(4) : the first of the sector TWO : no match - write don't work fine ");
        Serial.println(":-( ");
        // risponde successo
        //Serial.println(mfrc522.GetStatusCodeName(status));
        // Dump the result
        //mfrc522.PICC_DumpMifareClassicSectorToSerial(&(mfrc522.uid), &key, sector);
        // Halt PICC
        mfrc522.PICC_HaltA();
        // Stop encryption on PCD
        mfrc522.PCD_StopCrypto1();
