SD не работает с Ардуино про мини 328р 16Мгц 5в но при этом с Нано все работает отлично
Втр, 08/02/2022 - 17:49
Добрый день Всем!
Прошу помощи!
Исходные данные:
1. Есть Ардуино Нано 1 шт, Ардуино Про Мини 328р 16 Мгц 5в - 2 шт, Карта памяти на 1 Гиг и 8 Гиг, модуль Micro SD TF SPI для Ардуино - 2 шт
2. Подключаю SD шилд к Ардуино по стандартной схеме
MOSI - 11
MISO - 12
SCK - 13
CS - 10
Код из библиотеки SD.h - CardInfo
SD card test
This example shows how use the utility libraries on which the'
SD library is based in order to get info about your SD card.
Very useful for testing a card when you're not sure whether its working or not.
The circuit:
SD card attached to SPI bus as follows:
** MOSI - pin 11 on Arduino Uno/Duemilanove/Diecimila
** MISO - pin 12 on Arduino Uno/Duemilanove/Diecimila
** CLK - pin 13 on Arduino Uno/Duemilanove/Diecimila
** CS - depends on your SD card shield or module.
Pin 4 used here for consistency with other Arduino examples
created 28 Mar 2011
by Limor Fried
modified 9 Apr 2012
by Tom Igoe
// include the SD library:
#include <SPI.h>
#include <SD.h>
// set up variables using the SD utility library functions:
Sd2Card card;
SdVolume volume;
SdFile root;
// change this to match your SD shield or module;
// Arduino Ethernet shield: pin 4
// Adafruit SD shields and modules: pin 10
// Sparkfun SD shield: pin 8
// MKRZero SD: SDCARD_SS_PIN
const int chipSelect = 10;
// Open serial communications and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.print("\nInitializing SD card...");
// we'll use the initialization code from the utility libraries
// since we're just testing if the card is working!
if (!card.init(SPI_HALF_SPEED, chipSelect)) {
Serial.println("initialization failed. Things to check:");
Serial.println("* is a card inserted?");
Serial.println("* is your wiring correct?");
Serial.println("* did you change the chipSelect pin to match your shield or module?");
while (1);
} else {
Serial.println("Wiring is correct and a card is present.");
// print the type of card
Serial.println();
Serial.print("Card type: ");
switch (card.type()) {
case SD_CARD_TYPE_SD1:
Serial.println("SD1");
case SD_CARD_TYPE_SD2:
Serial.println("SD2");
case SD_CARD_TYPE_SDHC:
Serial.println("SDHC");
default:
Serial.println("Unknown");
// Now we will try to open the 'volume'/'partition' - it should be FAT16 or FAT32
if (!volume.init(card)) {
Serial.println("Could not find FAT16/FAT32 partition.\nMake sure you've formatted the card");
while (1);
Serial.print("Clusters: ");
Serial.println(volume.clusterCount());
Serial.print("Blocks x Cluster: ");
Serial.println(volume.blocksPerCluster());
Serial.print("Total Blocks: ");
Serial.println(volume.blocksPerCluster() * volume.clusterCount());
Serial.println();
// print the type and size of the first FAT-type volume
uint32_t volumesize;
Serial.print("Volume type is: FAT");
Serial.println(volume.fatType(), DEC);
volumesize = volume.blocksPerCluster(); // clusters are collections of blocks
volumesize *= volume.clusterCount(); // we'll have a lot of clusters
volumesize /= 2; // SD card blocks are always 512 bytes (2 blocks are 1KB)
Serial.print("Volume size (Kb): ");
Serial.println(volumesize);
Serial.print("Volume size (Mb): ");
volumesize /= 1024;
Serial.print("Volume size (Gb): ");
Serial.println((float)volumesize / 1024.0);
Serial.println("\nFiles found on the card (name, date and size in bytes): ");
root.openRoot(volume);
// list all files in the card with date and size
root.ls(LS_R | LS_DATE | LS_SIZE);
void loop(void) {
Проблема.
1. Подключаю к Ардуино Нано - все работает отлично, все примеры и т.д.
2. Подключаю к Ардуино Про Мини (что к одной что к другой) - не работает. Все подключено корректно, в программе пин управления 10 прописан и подключено на 10.
(Initializing SD card...initialization failed. Things to check:
* did you change the chipSelect pin to match your shield or module?)
3. Мои действия и эксперименты после прочитки массы информации на просторах интернета:
3.1. Менял карты памяти (1 и 8 Гиг), форматировал их и в FAT16 и FAT32 и с разными размерами кластеров средством Виндовс и программой SD Card Formatter
3.2. По мимо библиотеки SD.h пробовал примеры с библиотеки SDFat.h (с нано работает, даже форматировал карточки с примера библиотеки SDFat.h) - c Про Мини не работает
3.3. Перезаписывал Бутлоадер в Про Мини и как Про Мини, так и Уно и Нано (пробовал даже в Про Мини загрузить Бутлоадер Optiboot on 32-pin cpus - но не получилось загрузить, выдало ошибку)
3.4. Менял шилды SD
Итог - ничего из перечисленного в п.3 не помогло завести работу SD с Про Мини (с Нано же все работает отлично) Такое впечатление что Про Мини аппаратно не работает с SD
Может кто помочь в том вопросе?
Чем промини отличается от Нано? - в первую очередь отсуствием USB
Поэтому начните с того, что расскажите ПОДРОБНО, с приложением схемы - как именно вы питаете свою Промини. Какой БП, какое напряжение и ток, и - ОЧЕНЬ ВАЖНО - схема соединений проводов питания
Нано прошиваю и питаю от USB ноутбука
Про Мини прошиваю и питаю через адаптер USB в TTL или как его называют UART переходник от USB порта ноутбука.
То бишь источник питания один и тот же, при этом Нано работает , а про мини нет в связке с SD
PS. Спасибо b707 за направление мыслей в нужную сторону!!!
Подключил внешний источник питания и Про Мини увидела SD.
PS2. Все равно в недоумении, получается Про Мини + UART переходник + SD более прожорливые по питанию чем Нано с встроенным UART переходником + SD. Как так то?
А если запитать от отдельного БП?
а обычный блинк работает?
Да не прожорливее, просто переходник в качестве питалки слабоват
Спасибо всем, подключение внешнего БП помогло, но по этой логике Нано тоже без БП не могла бы работать с SD, но работала же..
У нано другая схема подключения - напрямую от USB
Вообще-то SD карте, насколько я помню, нужно 3.3 В.
В общем, обсуждать что-либо без подробной схемы (именно схемы, а не ее словесного описания) бессмысленно.
Тут другая логика.
У Нано при подключении по USB никак не задействуются пины SPI (SCK, MOSI и MISO). А при питании через программатор к ним подключён программатор и он начинает реагировать на то, как Вы их дёргаете, работая с картой и своей реакцией портит работу с картой Потому (из-за его реакции) у Вас и не работает.
Хотите убедиться, что я прав? Запитайте Нано от того же программатора через её (нановский) ICSP разъём и увидите, что Нано также не будет работать.
Я это проходил с тинькой. Если питаю от программатора, а пины SPI используются, то сплошь и рядом ни хрена не работает. Это уже настолько общее место, что сделал специальный ISCP разъём в котором распаяно только питание и когда надо, питаю от него, а не от честного программатора.
andriano, на самом модуле SD стоит микросхема понижения питания с 5 до 3,3в и так же стоит микросхема с блоком резисторов для увязывания логики с 5 до 3,3в ;)
ЕвгенийП, немного не понял.
В моем (классическом) варианте подключения Про Мини подключается к конвертеру через RX-TX и далее к USB ноута. Код заливается через бутлоадер.
Возможно Вы имели в виду вариант заливки кода без бутлоадера напрямую используя Miso - Mosi? Я этот вариант пока не использую.
Да, я имел в виду именно это. Если у Вас не так, то моё сообщение мимо кассы.
на самом модуле SD стоит микросхема...
ну как мимо кассы - в копилку знаний, может даже тему такую открыть для новичков, "а знаете ли вы, что..."
