STM32F103 - Правим примеры
Чт, 01/11/2018 - 22:01
Столкнулся с тем, что примеры из аддона STM32 на процессоре STM32F103 не работают.
Добавлю исправленные примеры:
BLINK
/* Blink Turns on an LED on for one second, then off for one second, repeatedly. Most Arduinos have an on-board LED you can control. On the Uno and Leonardo, it is attached to digital pin 13. If you're unsure what pin the on-board LED is connected to on your Arduino model, check the documentation at http://arduino.cc This example code is in the public domain. modified 8 May 2014 by Scott Fitzgerald Modified by Roger Clark. www.rogerclark.net for Maple mini 25th April 2015 , where the LED is on PB1 */ // the setup function runs once when you press reset or power the board void setup() { // initialize digital pin PB1 (PC13) as an output. pinMode(PC13, OUTPUT); } // the loop function runs over and over again forever void loop() { digitalWrite(PC13, HIGH); // turn the LED on (HIGH is the voltage level) delay(1000); // wait for a second digitalWrite(PC13, LOW); // turn the LED off by making the voltage LOW delay(1000); // wait for a second }
AnalogInOutSerial
Analog input, analog output, serial output
Reads an analog input pin, maps the result to a range from 0 to
65535 and uses the result to set the pulse width modulation (PWM) of
an output pin. Also prints the results to the serial monitor.
(You may need to change the pin numbers analogInPin and analogOutPin
if you're not using a Maple).
The circuit:
* Potentiometer connected to analog pin 15.
Center pin of the potentiometer goes to the analog pin.
Side pins of the potentiometer go to +3.3V and ground.
* LED connected from digital pin 9 to ground
created 29 Dec. 2008
by Tom Igoe
ported to Maple
by LeafLabs
// These constants won't change. They're used to give names
// to the pins used:
const int analogInPin = PA0; // Analog input pin that the potentiometer
// is attached to
const int pwmOutPin = 9; // PWM pin that the LED is attached to
// These variables will change:
int sensorValue = 0; // value read from the pot
int outputValue = 0; // value output to the PWM
// Configure the ADC pin
pinMode(analogInPin, INPUT_ANALOG);
// Configure LED pin
pinMode(pwmOutPin, PWM);
Serial.begin(115200); // Ignored by Maple. But needed by boards using Hardware serial via a USB to Serial Adaptor
// read the analog in value:
sensorValue = analogRead(analogInPin);
// map it to the range of the analog out:
outputValue = map(sensorValue, 0, 4096, 0, 65535);
// change the analog out value:
pwmWrite(pwmOutPin, outputValue);
// print the results to the serial monitor:
Serial.print("sensor = " );
Serial.print(sensorValue);
Serial.print("\t output = ");
Serial.println(outputValue);
Analog input, serial output
Reads an analog input pin, prints the results to the serial monitor.
The circuit:
* Potentiometer connected to analog pin 15 (на пин A0).
* Center pin of the potentiometer goes to the analog pin.
* Side pins of the potentiometer go to +3.3V (VCC) and ground
created over and over again
by Tom Igoe and everyone who's ever used Arduino
Ported to Maple 27 May, 2010 by Bryan Newbold
// Analog input pin. You may need to change this number if your board
// can't do analog input on pin PA0.
const int analogInputPin = PA0;
// Declare analogInputPin as INPUT_ANALOG:
pinMode(analogInputPin, INPUT_ANALOG);
// Read the analog input into a variable:
int analogValue = analogRead(analogInputPin);
// print the result:
Serial.println(analogValue);
Пример работы с сервой, подправил для проверки работы двух функций, перемещение по углу и отработка по длительности импульса ШИМ (из-за нелинейности вычисления получилась простая игрушка - найдите точку бифуркации)
ua6em - если хотите, что топик был полезным - в каждом случае пишите что именно поправили и почему. Прямо-таки теряюсь в догадках, что можно было поправитьв Блинке - номер пина? :)))
И про другие примеры тоже интересно
Действительно!
1. Блинк - изменен номер пина с 33 на номер пина к которому подключен светодиод на плате - PC13
2. AnalogInOutSerial - исправлена строка 48, приведена в соответствии с разрешающей способностью АЦП
3. AnalogInputSerialOutput - исправлены строки 19,20 порты обозначены в соответствии с маркировкой платы
4. Пример работы с сервой - исправлены строки 20,25, добавлены строки 30-34 для проверки отработки фунции позиционирования по передаваемому значению длительности импульса в микросекундах.
