tft 1.8 st7735
Втр, 26/03/2019 - 20:17
Помогите вывести информацию с датчика bmp280 на дисплей
библиотека https://github.com/adafruit/Adafruit-ST7735-Library
в попытке вывода одного блока информации на дисплей, сократил скетч из примера до:
#include <Adafruit_GFX.h> // Core graphics library
#include <Adafruit_ST7735.h> // Hardware-specific library for ST7735
#include <Adafruit_ST7789.h> // Hardware-specific library for ST7789
#include <SPI.h>
#ifdef ADAFRUIT_HALLOWING
#define TFT_CS 39 // Hallowing display control pins: chip select
#define TFT_RST 37 // Display reset
#define TFT_DC 38 // Display data/command select
#define TFT_BACKLIGHT 7 // Display backlight pin
#else
// For the breakout board, you can use any 2 or 3 pins.
// These pins will also work for the 1.8" TFT shield.
#define TFT_CS 10
#define TFT_RST 9 // Or set to -1 and connect to Arduino RESET pin
#define TFT_DC 8
#endif
// OPTION 1 (recommended) is to use the HARDWARE SPI pins, which are unique
// to each board and not reassignable. For Arduino Uno: MOSI = pin 11 and
// SCLK = pin 13. This is the fastest mode of operation and is required if
// using the breakout board's microSD card.
// For 1.44" and 1.8" TFT with ST7735 (including HalloWing) use:
Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_RST);
// For 1.54" TFT with ST7789:
//Adafruit_ST7789 tft = Adafruit_ST7789(TFT_CS, TFT_DC, TFT_RST);
// OPTION 2 lets you interface the display using ANY TWO or THREE PINS,
// tradeoff being that performance is not as fast as hardware SPI above.
//#define TFT_MOSI 11 // Data out
//#define TFT_SCLK 13 // Clock out
//Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_MOSI, TFT_SCLK, TFT_RST);
float p = 3.1415926;
void setup(void) {
Serial.print(F("Hello! ST77xx TFT Test"));
tft.initR(INITR_HALLOWING); // Initialize HalloWing-oriented screen
pinMode(TFT_BACKLIGHT, OUTPUT);
digitalWrite(TFT_BACKLIGHT, HIGH); // Backlight on
#else
tft.initR(INITR_BLACKTAB); // Init ST7735S chip, black tab
#endif
Serial.println(F("Initialized"));
uint16_t time = millis();
tft.fillScreen(ST77XX_BLACK);
time = millis() - time;
Serial.println(time, DEC);
delay(500);
Serial.println("done");
tft.invertDisplay(true);
delay(500);
tft.invertDisplay(false);
delay(500);
void tftPrintTest() {
tft.setTextWrap(false);
tft.setCursor(0, 30);
tft.setTextColor(ST77XX_RED);
tft.setTextSize(1);
tft.println("Hello World!");
tft.setTextColor(ST77XX_YELLOW);
tft.setTextSize(2);
tft.setTextColor(ST77XX_GREEN);
tft.setTextSize(3);
tft.setTextColor(ST77XX_BLUE);
tft.setTextSize(4);
tft.print(1234.567);
delay(1500);
tft.setCursor(0, 0);
tft.setTextColor(ST77XX_WHITE);
tft.setTextSize(0);
tft.setTextSize(1);
tft.print(p, 6);
tft.println(" Want pi?");
tft.println(" ");
tft.print(8675309, HEX); // print 8,675,309 out in HEX!
tft.println(" Print HEX!");
tft.println(" ");
tft.println("Sketch has been");
tft.println("running for: ");
tft.setTextColor(ST77XX_MAGENTA);
tft.print(millis() / 1000);
tft.print(" seconds.");
но не работает, только белый экран(
Мне бы пример, вывода на экран одного слова, а дальше я бы сам.
Ну или вывод одного параметра из моего проекта:
#include <Adafruit_Sensor.h>
#include <Wire.h>
#include <CayenneMQTTESP8266.h>
#include <Adafruit_BMP280.h>
#include <SimpleTimer.h>
extern "C" {
#include "user_interface.h";
char ssid[] = "ASUS-CDC0" ;
char wifiPassword[] = "00000000" ;
SimpleTimer timer;
char username[] = "be69a3f0-5d168a516101" ;
char password[] = "3f6b82d32ed8fd523c5857b9" ;
char clientID[] = "ecff01c0-3ee3d2557533" ;
float in_216184383_1;
float in_216184383_2;
float Temperature_145241870_1;
float Pressure_145241870_1;
float Altitude_145241870_1;
#define SEALEVELPRESSURE_HPA_145241870_1 (1013.25)
Adafruit_BMP280 bmp_145241870_1; // I2C
float in_216184383_3;
int in_216184383_4;
int ESP8266_AnalogInputValue;
unsigned long ESP8266_AnalogInputValue_StR;
ESP8266_AnalogInputValue_StR = millis() + 500 ;
Cayenne.begin(username, password, clientID, ssid, wifiPassword);
timer.setInterval(5000L, sendUptime_216184383_1);
timer.setInterval(30000L, sendUptime_216184383_2);
if (!bmp_145241870_1.begin()) {
bmp_145241870_1.readTemperature();
while (1);
timer.setInterval(300000L, sendUptime_216184383_3);
timer.setInterval(1500L, sendUptime_216184383_4);
{if(_isTimer(ESP8266_AnalogInputValue_StR, 500))
ESP8266_AnalogInputValue_StR = millis();
ESP8266_AnalogInputValue = analogRead(A0);
//Плата:1
//Наименование:Esp
Cayenne.loop();
timer.run();
Temperature_145241870_1 = bmp_145241870_1.readTemperature();
Pressure_145241870_1 = bmp_145241870_1.readPressure() / 100.0F * 0.7500;
Altitude_145241870_1 = bmp_145241870_1.readAltitude(1032.4);
in_216184383_3 = Altitude_145241870_1;
in_216184383_2 = Pressure_145241870_1;
in_216184383_1 = Temperature_145241870_1;
in_216184383_4 = ESP8266_AnalogInputValue;
bool _isTimer(unsigned long startTime, unsigned long period )
unsigned long currentTime;
currentTime = millis();
if (currentTime>= startTime) {return (currentTime>=(startTime + period));} else {return (currentTime >=(4294967295-startTime+period));}
void sendUptime_216184383_1()
Cayenne.virtualWrite( 0 , in_216184383_1 );
void sendUptime_216184383_2()
Cayenne.virtualWrite( 1 , in_216184383_2 );
void sendUptime_216184383_3()
Cayenne.virtualWrite( 2 , in_216184383_3 );
void sendUptime_216184383_4()
Cayenne.virtualWrite( 3 , in_216184383_4 );
А "Hello word" на экран выводили? В примерах к библиотеке должно это быть.
