'TouchScreen' does not name a type
Втр, 23/09/2014 - 22:47
Здравствуйте, написал программку, но при проверкке и компиляции выскакивают следующие ошибки:
vibrocli_15:33: error: 'TouchScreen' does not name a type
vibrocli_15.ino: In function 'void setup()':
vibrocli_15:99: error: 'printf_begin' was not declared in this scope
vibrocli_15.ino: In function 'void loop()':
vibrocli_15:126: error: 'Point' was not declared in this scope
vibrocli_15:126: error: expected `;' before 'p'
vibrocli_15:129: error: 'p' was not declared in this scope
Вот сама прога:
#include <SPI.h>
#include <digitalWriteFast.h>
#include <iBoardRF24.h>
#include <printf.h>
#include <Adafruit_GFX.h> // Core graphics library
#include <SWTFT.h> // Hardware-specific library
#include <TouchScreen.h>
#define YP A1 // must be an analog pin, use "An" notation!
#define XM A2 // must be an analog pin, use "An" notation!
#define YM 7 // can be a digital pin
#define XP 6 // can be a digital pin
#define TS_MINX 150
#define TS_MINY 120
#define TS_MAXX 920
#define TS_MAXY 940
#define BOXSIZE 40
#define PENRADIUS 3
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
SWTFT tft;
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
iBoardRF24 radio(18,20,19,16,17,21);
//iBoardRF24(cepin, cspin, mosi_pin, miso_pin, sck_pin, irq_pin):
const uint64_t pipes[2] = { 0xF0F0F0F0E1LL, 0xF0F0F0F0D2LL };
typedef struct{
unsigned long ms;
unsigned long avgvalues;
unsigned long nchanges;
// unsigned long nscan;
unsigned long n;
RFMsg;
typedef struct{
unsigned int y;
int value;
GPoint;
unsigned long testTriangles();
unsigned long prevMicro=0;
unsigned long prevN=0;
unsigned long currentMillis;
unsigned long textInterval = 1000;
unsigned long prevtextMills = 0;
unsigned long statsec_N=0;
unsigned long statsec_SumVal=0;
unsigned long statsec_NAct=0;
unsigned long stat_MaxNValues=0;
unsigned long stat_scrMaxNValues=0;
unsigned long stat_avgCnt=0;
int w = 0;
int h = 0;
float curpos = 0;
float prevpos = 0;
unsigned long maxvalue = 1024;
float ko = 0;
unsigned int topline = 1;
unsigned int bottomline = 15;
int viewType = 2;
//GPoint scr[320];
void DrawCountAmp(RFMsg msg);
void DrawG(int y);
void DrawAmpOnly(RFMsg msg,int ystart,int ystop);
void DrawCountOnly(RFMsg msg,int ystart,int ystop);
void setup(void)
tft.reset();
uint16_t identifier = tft.readID();
tft.begin(identifier);
tft.setRotation(3);
w = tft.width(),
h = tft.height();
delay(100);
Serial.begin(57600);
delay(100);
printf_begin();
printf("\n\rRF24/examples/GettingStarted/\n\r");
delay(100);
printf("*** \n\r");
radio.begin();
// optionally, increase the delay between retries & # of retries
radio.setRetries(15,15);
// optionally, reduce the payload size. seems to
// improve reliability
radio.setPayloadSize(sizeof(RFMsg));
radio.openWritingPipe(pipes[1]);
radio.openReadingPipe(1,pipes[0]);
radio.startListening();
radio.printDetails();
//radio.setAutoAck(false);
//testTriangles();
tft.fillScreen(BLACK);
unsigned long start = micros();
ko = ((float)h-(float)bottomline) / (float)maxvalue;
void loop(void)
Point p = ts.getPoint();
pinMode(XM, OUTPUT);
pinMode(YP, OUTPUT);
if (p.z>0) {
viewType++;
if (viewType>2) viewType=0;
curpos=0;
delay(200);
if ( radio.available() )
// Dump the payloads until we've gotten everything
RFMsg msg;
bool done = false;
//1 мксек= 1 / 1 000 000 сек
while (!done)
currentMillis = micros();
// Fetch the payload, and see if this was the last one.
done = radio.read( &msg, sizeof(RFMsg) );
//curpos++;
curpos = curpos + (float)msg.ms / 100000;
if (curpos>=w) {
curpos=0;
if (stat_scrMaxNValues>stat_MaxNValues*2) {
stat_scrMaxNValues=stat_MaxNValues+(stat_MaxNValues%4);
stat_MaxNValues=0;
//stat_MaxNValues = stat_AllMaxNValues;
//tft.drawLine(curpos, h-bottomline, curpos, 0, BLUE);
if (msg.nchanges>stat_MaxNValues)
stat_MaxNValues = msg.nchanges;
if (currentMillis - prevtextMills > textInterval*1000) {
tft.drawFastVLine(curpos, topline, h-topline-bottomline, 0x0007);
if (viewType==0) {
DrawAmpOnly(msg, topline,h-bottomline);
if (viewType==1) {
DrawCountOnly(msg, topline,h-bottomline);
if (viewType==2) {
int seredina = (h-topline-bottomline)/2;
DrawAmpOnly(msg, topline,seredina);
DrawCountOnly(msg, seredina+1,h-bottomline);
statsec_N++;
statsec_SumVal=statsec_SumVal+msg.avgvalues;
statsec_NAct=statsec_NAct+msg.nchanges;
//stat_MaxNValues=statsec_NAct+msg.nchanges;
tft.setCursor(10, h-bottomline+4);
if ( msg.n-prevN>1 ) {
tft.fillRect(0, h-bottomline, w, bottomline, MAGENTA);
tft.print("E:");
tft.print(msg.n-prevN);
tft.print(" ");
} else {
tft.fillRect(0, h-bottomline, w, bottomline, BLUE);
tft.setTextColor(WHITE);
tft.setTextSize(1);
tft.print("INT:");
tft.setTextColor(YELLOW);
tft.print(msg.ms);
tft.print(" VAL:");
tft.print(msg.avgvalues);
tft.print(" CNT:");
tft.print(statsec_NAct%statsec_N);
tft.print(" MAX:");
tft.print(stat_MaxNValues);
tft.print(" Y:");
tft.print(p.y);
tft.print(" X:");
tft.print(p.x);
tft.print(" Z:");
tft.print(p.z);
prevtextMills = currentMillis;
statsec_N=0;
statsec_SumVal=0;
statsec_NAct=0;
prevpos = curpos;
prevN = msg.n;
//tft.drawLine(curpos+1, h-bottomline, curpos+1, 0, BLUE);
//tft.drawLine(curpos, h-bottomline, curpos, y, YELLOW);
//printf("MS:%lu RV: %i Y:%f KO:%f H:%i MAX:%i",msg.ms,msg.value,y,h / maxvalue,h,maxvalue);
//printf("\n\r");
//radio.stopListening();
// Send the final one back.
//radio.write( &got_time, sizeof(unsigned long) );
//printf("Sent response.\n\r");
//radio.startListening();
unsigned long testTriangles() {
unsigned long start;
int n, i, cx = tft.width() / 2 - 1,
cy = tft.height() / 2 - 1;
n = min(cx, cy);
start = micros();
for(i=0; i<n; i+=5) {
tft.drawTriangle(
cx , cy - i, // peak
cx - i, cy + i, // bottom left
cx + i, cy + i, // bottom right
tft.color565(0, 0, i));
return micros() - start;
void DrawAmpOnly(RFMsg msg,int ystart,int ystop) {
float ko = ((float)ystop-(float)ystart) / (float)maxvalue;
float y = msg.avgvalues * ko; //(float)(msg.value * ko);
int he = ystop-ystart;
DrawCursor(ystart,ystop);
tft.drawFastVLine(curpos, ystart+(he-y), y, GREEN);
if (msg.nchanges>stat_scrMaxNValues)
stat_scrMaxNValues = msg.nchanges+ (msg.nchanges%3);
tft.drawFastVLine(curpos-1, ystart, he, YELLOW);
float ko = ((float)ystop-(float)ystart) / (float)stat_scrMaxNValues;
float y = msg.nchanges * ko; //(float)(msg.value * ko);
tft.drawFastVLine(curpos, ystart+(he-y), y, RED);
void DrawCursor(int ystart,int ystop) {
tft.drawFastVLine(curpos+1, ystart, he, BLACK);
tft.drawFastVLine(curpos+2, ystart, he, MAGENTA);
tft.drawFastVLine(curpos+3, ystart, he, BLACK);
Надеюсь кто-нибудь поможет разобраться с ошибками, заранее спасибо!
Протирая хрустальный шар, тихо напевает песню про зайцев.
так все ж написано черным по белому, на старом добром англицком, том самом, который известен каждому второму китайцу! :)
судя по всему в файлике
TouchScreen.hидет определение типов, среда его не видит и ругается. сprintf.hтакая же фигня. могу предположить, что не туда скопировали хидеры. если вообще копировали.а если с английским вообще никак, то тут где-то в соседней ветке какой-то патриот раздаёт иде с русским хелпом, вам к нему
Ну вы уважаемый можете протирать свои шары сколько угодно, а за сарказмом или шутками я мог бы обратиться в другое место. Если вам что-то непонятно, или я выразил проблемы нечетко, так вы укажите на это, а поерничать или пошутить я и сам могу с превеликим удовольствием.
С уважением
Ну во-первых я не каждый второй китаец, и даже не первый, да и в конце концов к расе желтолицых никак по родословной не отношусь :-)
А во-вторых за подсказку что на что ругается спасибо, буду исправлять,
Тоесть было не очевидно что на что-то ругается? Круто.
да ты зря на новичков не гони! видишь, есть уважительная причина - товарищ ни разу не китаец, поэтому английский может смело игнорировать
Да как то упустил я это. Буду ждать второго китайца новичка.
У меня такая же ошибка! Ты не решил проблему с ней?
Тоесть обьяснения вы сразу пропустили. Прально. Какого фига не выложили пошаговое решение проблемы.
