В Mega 2560 Не выводиться в монитор порта значения из serial.print, но на UNO все работает
perdmen
Здравствуйте! подскажите пожалуйста, стандартный скетч для управления гироскутером по UART, в ардуино UNO serial.print выводится в монитор нормально, а в Mega 2560 нет, в чем может быть дело?
//  Arduino Nano 5V example code
//  for   https://github.com/EmanuelFeru/hoverboard-firmware-hack-FOC
//  Copyright (C) 2019-2020 Emanuel FERU <aerdronix@gmail.com>
// INFO:
// • This sketch uses the the Serial Software interface to communicate and send commands to the hoverboard
// • The built-in (HW) Serial interface is used for debugging and visualization. In case the debugging is not needed,
//   it is recommended to use the built-in Serial interface for full speed perfomace.
// • The data packaging includes a Start Frame, checksum, and re-syncronization capability for reliable communication
// The code starts with zero speed and moves towards +
// CONFIGURATION on the hoverboard side in config.h:
// • Option 1: Serial on Right Sensor cable (short wired cable) - recommended, since the USART3 pins are 5V tolerant.
//   #define CONTROL_SERIAL_USART3
//   #define FEEDBACK_SERIAL_USART3
//   // #define DEBUG_SERIAL_USART3
// • Option 2: Serial on Left Sensor cable (long wired cable) - use only with 3.3V devices! The USART2 pins are not 5V tolerant!
//   #define CONTROL_SERIAL_USART2
//   #define FEEDBACK_SERIAL_USART2
//   // #define DEBUG_SERIAL_USART2
// ########################## DEFINES ##########################
#define HOVER_SERIAL_BAUD   115200      // [-] Baud rate for HoverSerial (used to communicate with the hoverboard)
#define SERIAL_BAUD         115200      // [-] Baud rate for built-in Serial (used for the Serial Monitor)
#define START_FRAME         0xABCD       // [-] Start frme definition for reliable serial communication
#define TIME_SEND           100         // [ms] Sending time interval
#define SPEED_MAX_TEST      300         // [-] Maximum speed for testing
#define SPEED_STEP          20          // [-] Speed step
// #define DEBUG_RX                        // [-] Debug received data. Prints all bytes to serial (comment-out to disable)
#include <SoftwareSerial.h>
SoftwareSerial HoverSerial(2,3);        // RX, TX
// Global variables
uint8_t idx = 0;                        // Index for new data pointer
uint16_t bufStartFrame;                 // Buffer Start Frame
byte *p;                                // Pointer declaration for the new received data
byte incomingByte;
byte incomingBytePrev;
typedef struct{
   uint16_t start;
   int16_t  steer;
   int16_t  speed;
   uint16_t checksum;
} SerialCommand;
SerialCommand Command;
typedef struct{
   uint16_t start;
   int16_t  cmd1;
   int16_t  cmd2;
   int16_t  speedR_meas;
   int16_t  speedL_meas;
   int16_t  batVoltage;
   int16_t  boardTemp;
   uint16_t cmdLed;
   uint16_t checksum;
} SerialFeedback;
SerialFeedback Feedback;
SerialFeedback NewFeedback;
// ########################## SETUP ##########################
  Serial.begin(SERIAL_BAUD);
  Serial.println("Hoverboard Serial v1.0");
  HoverSerial.begin(HOVER_SERIAL_BAUD);
  pinMode(LED_BUILTIN, OUTPUT);
// ########################## SEND ##########################
void Send(int16_t uSteer, int16_t uSpeed)
  // Create command
  Command.start    = (uint16_t)START_FRAME;
  Command.steer    = (int16_t)uSteer;
  Command.speed    = (int16_t)uSpeed;
  Command.checksum = (uint16_t)(Command.start ^ Command.steer ^ Command.speed);
  // Write to Serial
  HoverSerial.write((uint8_t *) &Command, sizeof(Command));
// ########################## RECEIVE ##########################
void Receive()
    // Check for new data availability in the Serial buffer
    if (HoverSerial.available()) {
        incomingByte    = HoverSerial.read();                                   // Read the incoming byte
        bufStartFrame = ((uint16_t)(incomingByte) << 8) | incomingBytePrev;       // Construct the start frame
    else {
        return;
  // If DEBUG_RX is defined print all incoming bytes
  #ifdef DEBUG_RX
        Serial.print(incomingByte);
        return;
    #endif
    // Copy received data
    if (bufStartFrame == START_FRAME) {                     // Initialize if new data is detected
        p       = (byte *)&NewFeedback;
        *p++    = incomingBytePrev;
        *p++    = incomingByte;
        idx     = 2;
    } else if (idx >= 2 && idx < sizeof(SerialFeedback)) {  // Save the new received data
        idx++;
    // Check if we reached the end of the package
    if (idx == sizeof(SerialFeedback)) {
        uint16_t checksum;
        checksum = (uint16_t)(NewFeedback.start ^ NewFeedback.cmd1 ^ NewFeedback.cmd2 ^ NewFeedback.speedR_meas ^ NewFeedback.speedL_meas
                            ^ NewFeedback.batVoltage ^ NewFeedback.boardTemp ^ NewFeedback.cmdLed);
        // Check validity of the new data
        if (NewFeedback.start == START_FRAME && checksum == NewFeedback.checksum) {
            // Copy the new data
            memcpy(&Feedback, &NewFeedback, sizeof(SerialFeedback));
            // Print data to built-in Serial
            Serial.print("1: ");   Serial.print(Feedback.cmd1);
            Serial.print(" 2: ");  Serial.print(Feedback.cmd2);
            Serial.print(" 3: ");  Serial.print(Feedback.speedR_meas);
            Serial.print(" 4: ");  Serial.print(Feedback.speedL_meas);
            Serial.print(" 5: ");  Serial.print(Feedback.batVoltage);
            Serial.print(" 6: ");  Serial.print(Feedback.boardTemp);
            Serial.print(" 7: ");  Serial.println(Feedback.cmdLed);
        } else {
          Serial.println("Non-valid data skipped");
        idx = 0;    // Reset the index (it prevents to enter in this if condition in the next cycle)
    // Update previous states
    incomingBytePrev = incomingByte;
// ########################## LOOP ##########################
unsigned long iTimeSend = 0;
int iTest = 0;
int iStep = SPEED_STEP;
void loop(void)
  unsigned long timeNow = millis();
  // Check for new received data
  Receive();
  // Send commands
  if (iTimeSend > timeNow) return;
  iTimeSend = timeNow + TIME_SEND;
  Send(0, iTest);
  // Calculate test command signal
  iTest += iStep;
  // invert step if reaching limit
  if (iTest >= SPEED_MAX_TEST || iTest <= -SPEED_MAX_TEST)
    iStep = -iStep;
  // Blink the LED
  digitalWrite(LED_BUILTIN, (timeNow%2000)<1000);
// ########################## END ##########################
Не увидел в исходнике ни одного serial.print. Может, поэтому и не выводит?
И еще: кто Вам сказал, что на Меге работает SoftwareSerial?
perdmen
TX точно работает, колеса крутят как надо.
Выводить должен вот это:
133             Serial.print(" 2: ");  Serial.print(Feedback.cmd2);
134             Serial.print(" 3: ");  Serial.print(Feedback.speedR_meas);
135             Serial.print(" 4: ");  Serial.print(Feedback.speedL_meas);
136             Serial.print(" 5: ");  Serial.print(Feedback.batVoltage);
137             Serial.print(" 6: ");  Serial.print(Feedback.boardTemp);
138             Serial.print(" 7: ");  Serial.println(Feedback.cmdLed);
139         } else {
140           Serial.println("Non-valid data skipped");
Upper
Пишут, что SoftwareSerial работает на прием не на всех ногах Mega 2560
https://www.arduino.cc/en/Reference/softwareSerial
Ну, во-первых, serial и Serial - это разные вещи.
А потом, чтобы дойти до строки 133, нужно еще преодолеть строки 99-100, 121 и 127. Поставьте там диагностическую печать и, возможно, что-то прояснится.
kalapanga
Вопрос уже становится традиционным - на кой чёрт на Меге SoftwareSerial при наличии кучи аппаратных?
А! Это же "стандартный скетч управления гироскутером"! Стандарт нарушать нельзя? :)
perdmen
Всем спасибо! нафиг SoftwareSerial....
