Выполнить некоторые команды только 1 раз.
Чт, 25/08/2016 - 07:15
Делаю тестер аккумуляторов.
Весь код выглядит вот так:
#include <LiquidCrystal.h>
int sensorPin = 0; // к пину Analog IN 0
int sensor2Pin = 2; // к пину Analog IN 2
int ledPin = 13; // пин к затвору транзистора
LiquidCrystal lcd(12, 11, 5, 4, 3, 2); // initialize the library with the numbers of the interface pins
int sensorValue = 0; // variable to store the value coming from the sensor
int sensor2Value = 0; // variable to store the value coming from the sensor
float LiMinThreshold = 2700; // Lithium Minimal Voltage for load removal
float LiMaxThreshold = 4200; // Lithium Max Voltage for load removal
float NmhMinThreshold = 950; // NMH Minimal Voltage for load removal
float NmhMaxThreshold = 1600; // NMH Max Voltage for load removal
float SelectedMinThreshold = 5000;
float current;
int i;
int BatVoltage = 5000;
int FetVoltage = 5000;
long TotalCurrent = 0;
boolean done = false;
unsigned long PrevMillis ;
unsigned long MillisPassed ;
void CL2(){
lcd.setCursor(0, 1);// Second line first char
lcd.print(" ");
void CL1(){
lcd.setCursor(0, 0);// First line first char
lcd.print(" ");
pinMode(ledPin, OUTPUT);//activation led and enable for FET
lcd.begin(16, 2);// set up the LCD's number of rows and columns:
lcd.print(" HELLO "); // Print a message to the LCD.
lcd.print("Detecting Bat"); // print voltage value
delay(2000);
lcd.print(" ");
digitalWrite(ledPin, HIGH); // set the LED on
sensorValue = analogRead(sensorPin); // read the value from the sensor:
digitalWrite(ledPin, LOW); // set the LED off
// Detecting battery type
BatVoltage = sensorValue*4.887;
if (BatVoltage > 4500){
lcd.print("Warning high-V! ");
done = true;}
else if (BatVoltage > LiMinThreshold){
lcd.print("Type:Li-Ion Bat ");
SelectedMinThreshold = LiMinThreshold;}
else if (BatVoltage > NmhMinThreshold){
lcd.print("Type:NiMH/Cd Bat ");
SelectedMinThreshold = NmhMinThreshold;}
else{
lcd.print("Unknown Bat V < 1");
done = true;}
lcd.print("V=");
lcd.print(sensorValue*4.887); // print voltage value
delay(3000);
CL2();
PrevMillis = millis();
int time = millis() / 1000;
if (BatVoltage > SelectedMinThreshold && !done) {
sensor2Value = analogRead(sensor2Pin); // read the value from the FET:
FetVoltage = (sensor2Value*4.887);
BatVoltage = (sensorValue*4.887);
current = (BatVoltage/3.3);
lcd.clear();
TotalCurrent=TotalCurrent+MillisPassed/1000*(BatVoltage-FetVoltage)/3.3/3.6;
lcd.print(" I=");
lcd.print(TotalCurrent/1000);
lcd.print("mAH");
lcd.print("V=");
lcd.print(BatVoltage/1000.0); // print voltage value
lcd.print("V ");
lcd.print("A=");
lcd.print(current/1000);
lcd.print("A");
MillisPassed = millis()- PrevMillis;
done=true;
digitalWrite(ledPin, LOW); // set the LED off - stop loading
CL2();
lcd.setCursor(4, 0);
if (time / 60 / 60 < 10) {
lcd.print ("0"); //часы
lcd.print (time / 60 / 60);
lcd.print (":");
if (time / 60 % 60 < 10) {
lcd.print ("0"); //минуты
lcd.print ((time / 60) % 60);
lcd.print (":");
if (time%60<10) { lcd.print ("0"); }//секунды
lcd.print (time%60);
lcd.print("V=");
lcd.print("V ");
lcd.print("I=");
lcd.print("mAH");
Когда тест заканчивается, выполняется все, что под:
done = true;
С самого начала теста у меня идет отсчет времени и в конце должно отображаться время, затраченное на тест(грубо говоря на "void loop()").
Но у меня время тикает после теста тоже.
Нужно выполнить этот кусок кода только один раз. Вывод сделан так:
lcd.print (":");
lcd.print (":");
вначале сделай какую нибудь булевую переменную, приравняй к ложь, сделай вывод при условии что это переменная ложь. когда сделаешь вывод проровняй ее к тру и больше этот вывод проводиться не будет.
После этого блока подожди до нажатия чего нибудь, потом перезапусти все сначала программным ресетом.
Я в ардуино совсем новичок. Пробовал много разных способов, в итоге у меня получилось!!. Не знаю правильно ли это, но зато работает))
while(i < 1) { i++; lcd.setCursor(4, 0); if (time / 60 / 60 < 10) { lcd.print ("0"); //часы } lcd.print (time / 60 / 60); lcd.print (":"); if (time / 60 % 60 < 10) { lcd.print ("0"); //минуты } lcd.print ((time / 60) % 60); lcd.print (":"); if (time%60<10) { lcd.print ("0"); }//секунды lcd.print (time%60); }ну можно и так а то про что я говорил в Вашем случае i должна быть булевой, то есть инициироваться она должна bool i=false;
в строке 1 пишем if(!i)//восклицательный знак перед переменной возвращает "инвертированное" ее значение, то есть в скобках у нас должно быть тру, так чтобы код в if фигурных скобках выполнялся,( тоже самое про while но это немного другое), а так как у нас i изначально равно false то !i=true. или можно было написать if(i==false). чем мне нравятся булевые переменные так это тем что не нужно под них писать равны они чему или нет, просто их указывать в скобках. if(i) или if(!i) или if(i&&y) или if(i&&!y)..
в строке 3 пишем i=true;
ПС если вы новичек то помогает обильные коментарии в скетче, берите готовые и читайте их, поймете как что делается...
булевая не булевая... лично мне на фелс и тру проверять не очень нравиться: в памяти мк ей отводиться байт, а используется только два значения... чуете к чему я? в переменную можно загнать не один флаг, а больше. каждый бит можно как флаг использовать. вместо 8 булевых, которые в памяти займут 8 байт - можно занять 1 байт.
Смотри.
void do_one_time(){ static uint8_t one= 0;// это переменая которая разрешает выполнить 1 раз if (one ) return; one = 1; // здесь код который надо выполнить 1 раз } void setup() { } void loop() { do_one_time();// вызывается много но делает 1 раз }булевая не булевая... лично мне на фелс и тру проверять не очень нравиться: в памяти мк ей отводиться байт, а используется только два значения... чуете к чему я? в переменную можно загнать не один флаг, а больше. каждый бит можно как флаг использовать. вместо 8 булевых, которые в памяти займут 8 байт - можно занять 1 байт.
Ну да, только новичка это еще больше запутает, и большенство наших скетчиков в память не упираются. Хотя лучьше измальства учиться экономить
