Замена серво двигателя на эл. магнит
ifndef CONFIGURE_H #define CONFIGURE_H //------------------------------------------------------------------------------ // Makelangelo - supports raprapdiscount RUMBA controller // dan@marginallycelver.com 2013-12-26 // RUMBA should be treated like a MEGA 2560 Arduino. //------------------------------------------------------------------------------ // Copyright at end of file. Please see // http://www.github.com/MarginallyClever/Makelangelo for more information. //------------------------------------------------------------------------------ // CONSTANTS //------------------------------------------------------------------------------ //#define VERBOSE (1) // add to get a lot more serial output. #define HAS_SD // comment this out if there is no SD card #define HAS_LCD // comment this out if there is no SMART LCD controller //#define USE_LIMIT_SWITCH (1) // Comment out this line to disable findHome and limit switches // servo angles for pen control #define PEN_UP_ANGLE (80) #define PEN_DOWN_ANGLE (10) // Some steppers don't like 0 degrees #define PEN_DELAY (250) // in ms // for serial comms #define BAUD (57600) // How fast is the Arduino talking? #define MAX_BUF (64) // What is the longest message Arduino can store? #define MICROSTEPS (16.0) // microstepping on this microcontroller #define STEPS_PER_TURN (200 * MICROSTEPS) // default number of steps per turn * microsteps #define MAX_FEEDRATE (40000.0) // depends on timer interrupt & hardware #define MIN_FEEDRATE (1500) #define DEFAULT_FEEDRATE (7000.0) #define DEFAULT_ACCELERATION (8) #define STEP_DELAY (150) // delay between steps, in microseconds, when doing fixed tasks like homing #define NUM_AXIES (6) // x,y,z #define NUM_TOOLS (6) #define MAX_SEGMENTS (32) // number of line segments to buffer ahead // for arc directions #define ARC_CW (1) #define ARC_CCW (-1) #define MM_PER_SEGMENT (10) // Arcs are split into many line segments. How long are the segments? #ifdef HAS_LCD #define HAS_SD #endif // SD card settings #define SDPOWER -1 #define SDSS 53 #define SDCARDDETECT 49 // Smart controller settings #define BEEPER 44 #define LCD_PINS_RS 19 #define LCD_PINS_ENABLE 42 #define LCD_PINS_D4 18 #define LCD_PINS_D5 38 #define LCD_PINS_D6 41 #define LCD_PINS_D7 40 #define LCD_HEIGHT 4 #define LCD_WIDTH 20 // Encoder rotation values #define BTN_EN1 13 #define BTN_EN2 12 #define BTN_ENC 43 #define BLEN_C 2 #define BLEN_B 1 #define BLEN_A 0 #define encrot0 0 #define encrot1 2 #define encrot2 3 #define encrot3 1 #define NUM_SERVOS (1) #define SERVO0_PIN (11) #define SERVO1_PIN (4) //#define MOTHERBOARD 1 // RUMBA #define MOTHERBOARD 2 // RAMPS #if MOTHERBOARD == 1 #define MOTOR_0_DIR_PIN (16) #define MOTOR_0_STEP_PIN (17) #define MOTOR_0_ENABLE_PIN (48) #define MOTOR_1_DIR_PIN (46) #define MOTOR_1_STEP_PIN (48) #define MOTOR_1_ENABLE_PIN (62) #endif #if MOTHERBOARD == 2 #define MOTOR_0_DIR_PIN (60) #define MOTOR_0_STEP_PIN (61) #define MOTOR_0_ENABLE_PIN (56) #define MOTOR_1_DIR_PIN (46) #define MOTOR_1_STEP_PIN (48) #define MOTOR_1_ENABLE_PIN (62) #endif //------------------------------------------------------------------------------ // EEPROM MEMORY MAP //------------------------------------------------------------------------------ #define EEPROM_VERSION 4 // Increment EEPROM_VERSION when adding new variables #define ADDR_VERSION 0 // address of the version number (one byte) #define ADDR_UUID (ADDR_VERSION+1) // address of the UUID (long - 4 bytes) #define ADDR_SPOOL_DIA1 (ADDR_UUID+4) // address of the spool diameter (float - 4 bytes) #define ADDR_SPOOL_DIA2 (ADDR_SPOOL_DIA1+4) // address of the spool diameter (float - 4 bytes) //------------------------------------------------------------------------------ // TIMERS //------------------------------------------------------------------------------ // for timer interrupt control #define CLOCK_FREQ (16000000L) #define MAX_COUNTER (65536L) #define TIMER_PRESCALER_COUNT (5) // time passed with no instruction? Make sure PC knows we are waiting. #define TIMEOUT_OK (1000) // optimize code, please #define FORCE_INLINE __attribute__((always_inline)) inline #ifndef CRITICAL_SECTION_START #define CRITICAL_SECTION_START unsigned char _sreg = SREG; cli(); #define CRITICAL_SECTION_END SREG = _sreg; #endif //CRITICAL_SECTION_START //------------------------------------------------------------------------------ // STRUCTS //------------------------------------------------------------------------------ // for line() typedef struct { long step_count; long delta; // number of steps to move long absdelta; int dir; float delta_normalized; } Axis; typedef struct { int step_pin; int dir_pin; int enable_pin; int limit_switch_pin; int limit_switch_state; int reel_in; int reel_out; } Motor; typedef struct { Axis a[NUM_AXIES]; int steps_total; int steps_taken; int accel_until; int decel_after; float feed_rate_max; float feed_rate_start; float feed_rate_start_max; float feed_rate_end; char nominal_length_flag; char recalculate_flag; char busy; } Segment; //------------------------------------------------------------------------------ // METHODS //------------------------------------------------------------------------------ extern Segment line_segments[MAX_SEGMENTS]; extern Segment *working_seg; extern volatile int current_segment; extern volatile int last_segment; extern float acceleration; //------------------------------------------------------------------------------ // GLOBALS //------------------------------------------------------------------------------ extern Motor motors[NUM_AXIES]; #endif // CONFIGURE_H
Добрый день. Построил "рисовалку" состоящую из двух шаговых двигателей и сервопривода для подъема/опускания карандаша. Ардуино мега + рампс. (Полный комплект от 3 Д принтера).
Есть софт стандартный Микланджело называется от туда и прошивка. Хотелось бы внести в нее изменения..
В моей конструкции хочу заменить серву на эл. магнит.
Рисовалка работает на G кодах ЧПУ... X Y Z
Серва опускалась при изменении Z. А я хочу конструктивно изменить опускания карандаша - заменив привод на эл. магнит. Т.е. (к примеру) команда G01 Z10 - включит, команда G01 Z0 - выключит.
Эл. магнит желательно запитать от "стола горячего" (это на примере 3Д принтера)
Подскажите как это реализовать. Привел код Configure.h
Вот мож по следующему пути пойти:
M106 - код включает (замыкает) пины горячего стола
M107 - код выключает (размыкает) пины горячего стола
Пробывал с прошивкой Марлин (на 3 Д принтерах используется) Там все работает по кодам... Только вот кинематика несколько иная. А в Микеланджело кинематика нужная - но серва предусмотрена.
Может можно прям блоком с прошивки Марлина скопировать? функцию вкл/выкл "горячего стола"?
А может легче использовать пины сервы? На вкл и выкл... эл. магнит 6 в...
