здрастуите памагите немножка
Чт, 25/01/2018 - 19:07
здрастуите памагите немножка ест вот такои код и б него нужно добавит ишчио адну кнопку и адины лампацку
int ledPin = 10; // LED is connected to digital pin 13
int switchPin = 5; // switch connected to digital pin 2
int switchValue; // a variable to keep track of when switch is pressed
int counter = 0;
pinMode(ledPin, OUTPUT); // sets the ledPin to be an output
pinMode(switchPin, INPUT); // sets the switchPin to be an input
digitalWrite(switchPin, HIGH); // sets the default (unpressed) state of switchPin to HIGH
void loop() // run over and over again
switchValue = digitalRead(switchPin); // check to see if the switch is pressed
if ((switchValue == LOW) && (counter <= 1)) { // if the switch is pressed then,
for(int ii = 0; ii <= 5; ii++)
digitalWrite(ledPin, !digitalRead(ledPin));
delay(900);
counter++;
if (switchValue == HIGH)
//if ((switchValue == HIGH) && (counter > 2))
counter = 0;
delay(100);
знать бы еще что должная делать вторая кнопка и вторая лампочка....
http://arduino.ru/forum/obshchii/vstavka-programmnogo-koda-v-temukomment...
[quote=andriux26]
int ledPin = 10; // LED is connected to digital pin 13 int switchPin = 5; // switch connected to digital pin 2 int switchValue; // a variable to keep track of when switch is pressed int counter = 0; void setup() { pinMode(ledPin, OUTPUT); // sets the ledPin to be an output pinMode(switchPin, INPUT); // sets the switchPin to be an input digitalWrite(switchPin, HIGH); // sets the default (unpressed) state of switchPin to HIGH } void loop() // run over and over again { switchValue = digitalRead(switchPin); // check to see if the switch is pressed if ((switchValue == LOW) && (counter <= 1)) { // if the switch is pressed then, for(int ii = 0; ii <= 5; ii++) { digitalWrite(ledPin, !digitalRead(ledPin)); delay(900); counter++; } } if (switchValue == HIGH) //if ((switchValue == HIGH) && (counter > 2)) { counter = 0; delay(100); } }извините за безпориадок а втарая кнопка и лампоцто далзна маркат тоэст пиервая кнопка вклиучатет пирвыи лед и магаэт 3 раза а втарая кнопка вклиучает втарую лампачку каторая мафаэт 3 раза
Это что, гугл-транслятор так переводит?
здрастуите!
дабавил и кнопку и лампацку.
ни блогадори!
здрастуите!
ни блогадори!
co neponiatno zriote tut a ne ruski
