Здравствуйте помогите переделать программу под этот монохромный дисплей: 128X64 I2C SSD1306.
Сб, 30/06/2018 - 22:43
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1331.h>
#define UP_BUTTON 2
#define DOWN_BUTTON 3
// Color definitions
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
const unsigned long PADDLE_RATE = 33;
const unsigned long BALL_RATE = 20;
const uint8_t PADDLE_HEIGHT = 24;
int MAX_SCORE = 8;
int CPU_SCORE = 0;
int PLAYER_SCORE = 0;
// You can use any (4 or) 5 pins
#define sclk 13
#define mosi 11
#define cs 10
#define rst 9
#define dc 8
// MOSI is Data pin on display breakout
Adafruit_SSD1331 display = Adafruit_SSD1331(cs, dc, rst);
void drawCourt();
uint8_t ball_x = 64, ball_y = 32;
uint8_t ball_dir_x = 1, ball_dir_y = 1;
boolean gameIsRunning = true;
boolean resetBall = false;
static const unsigned char pong []PROGMEM = {
0xff,0xe0,0x0,0x3f,0x80,0x7,0xe0,0x7,0xc0,0x3,0xfc,0x0,
0xff,0xf8,0x1,0xff,0xe0,0x7,0xf0,0x7,0xc0,0x1f,0xff,0x0,
0xff,0xfc,0x3,0xff,0xf0,0x7,0xf0,0x7,0xc0,0x3f,0xff,0x0,
0xff,0xfe,0x7,0xff,0xf8,0x7,0xf8,0x7,0xc0,0xff,0xff,0x0,
0xf8,0x7f,0xf,0xff,0xfc,0x7,0xfc,0x7,0xc0,0xff,0xff,0x0,
0xf8,0x3f,0xf,0xe0,0xfe,0x7,0xfc,0x7,0xc1,0xfc,0x7,0x0,
0xf8,0x1f,0x1f,0x80,0x7e,0x7,0xfe,0x7,0xc3,0xf8,0x1,0x0,
0xf8,0x1f,0x1f,0x0,0x3e,0x7,0xfe,0x7,0xc3,0xf0,0x0,0x0,
0xf8,0x1f,0x3f,0x0,0x3f,0x7,0xdf,0x7,0xc7,0xe0,0x0,0x0,
0xf8,0x1f,0x3e,0x0,0x1f,0x7,0xdf,0x87,0xc7,0xc0,0x0,0x0,
0xf8,0x3f,0x3e,0x0,0x1f,0x7,0xcf,0x87,0xc7,0xc1,0xff,0x80,
0xf8,0x7e,0x3e,0x0,0x1f,0x7,0xc7,0xc7,0xc7,0xc1,0xff,0x80,
0xff,0xfe,0x3e,0x0,0x1f,0x7,0xc7,0xe7,0xc7,0xc1,0xff,0x80,
0xff,0xfc,0x3e,0x0,0x1f,0x7,0xc3,0xe7,0xc7,0xc1,0xff,0x80,
0xff,0xf8,0x3e,0x0,0x1f,0x7,0xc1,0xf7,0xc7,0xc0,0xf,0x80,
0xff,0xe0,0x3f,0x0,0x3f,0x7,0xc1,0xf7,0xc7,0xe0,0xf,0x80,
0xf8,0x0,0x1f,0x0,0x3e,0x7,0xc0,0xff,0xc3,0xe0,0xf,0x80,
0xf8,0x0,0x1f,0x80,0x7e,0x7,0xc0,0x7f,0xc3,0xf0,0xf,0x80,
0xf8,0x0,0x1f,0xc0,0xfc,0x7,0xc0,0x7f,0xc3,0xfc,0xf,0x80,
0xf8,0x0,0xf,0xff,0xfc,0x7,0xc0,0x3f,0xc1,0xff,0xff,0x80,
0xf8,0x0,0x7,0xff,0xf8,0x7,0xc0,0x3f,0xc0,0xff,0xff,0x80,
0xf8,0x0,0x3,0xff,0xf0,0x7,0xc0,0x1f,0xc0,0x7f,0xff,0x80,
0xf8,0x0,0x1,0xff,0xe0,0x7,0xc0,0xf,0xc0,0x3f,0xff,0x0,
0xf8,0x0,0x0,0x7f,0x0,0x7,0xc0,0xf,0xc0,0x7,0xf8,0x0
static const unsigned char game []PROGMEM ={
0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x80,
0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x1,0xff,0x80,
0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xc3,0xff,0x80,
0x0,0x0,0x0,0x0,0x0,0x0,0xf,0xc3,0xff,0x80,
0x0,0x0,0x0,0x0,0x3,0xe0,0xf,0xc3,0xe0,0x0,
0x0,0x0,0x0,0x0,0x7,0xf0,0x1f,0xc1,0xe0,0x0,
0x0,0x0,0x0,0xf8,0x7,0xf0,0x1f,0xc1,0xe0,0x0,
0x0,0xfc,0x1,0xfc,0x7,0xf8,0x1f,0xc1,0xe0,0x0,
0x7,0xfc,0x1,0xfc,0x3,0xf8,0x1f,0xe1,0xff,0x80,
0x1f,0xfc,0x1,0xde,0x3,0xbc,0x3d,0xe1,0xff,0x80,
0x3f,0xfe,0x1,0xde,0x3,0xbc,0x39,0xe1,0xff,0x80,
0x7e,0x0,0x3,0xdf,0x3,0xde,0x39,0xe1,0xfc,0x0,
0x7c,0x0,0x3,0xcf,0x3,0xde,0x39,0xe1,0xe0,0x0,
0xf8,0x0,0x3,0xcf,0x3,0xcf,0x39,0xe1,0xf0,0x0,
0xf8,0x0,0x3,0x87,0x83,0xcf,0x79,0xe0,0xf0,0x0,
0xf0,0x7f,0x7,0x87,0x83,0xc7,0xf1,0xe0,0xf0,0xe0,
0xf0,0xff,0x7,0x83,0xc3,0xc7,0xf1,0xe0,0xff,0xe0,
0xf0,0xff,0x7,0xff,0xc1,0xc3,0xf1,0xf0,0xff,0xe0,
0xf0,0xff,0x7,0xff,0xe1,0xc3,0xf0,0xf0,0xff,0xe0,
0xf8,0xf,0xf,0xff,0xe1,0xc1,0xe0,0xf0,0xe0,0x0,
0xf8,0xf,0x8f,0x1,0xf1,0xe1,0xe0,0xf0,0x0,0x0,
0x7c,0xf,0x8f,0x0,0xf1,0xe1,0xe0,0x0,0x0,0x0,
0x7f,0x1f,0x8f,0x0,0xf9,0xc0,0x0,0x0,0x0,0x0,
0x3f,0xff,0x9f,0x0,0x0,0x0,0x0,0x0,0x0,0x0,
0x1f,0xff,0x1f,0x0,0x0,0x0,0x0,0x0,0x0,0x0,
0x7,0xfc,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0
unsigned long ball_update;
unsigned long paddle_update;
const uint8_t CPU_X = 12;
uint8_t cpu_y = 16;
const uint8_t PLAYER_X = 85;
uint8_t player_y = 16;
pinMode(UP_BUTTON, INPUT_PULLUP);
pinMode(DOWN_BUTTON, INPUT_PULLUP);
display.begin();
display.fillScreen(BLACK);
display.drawBitmap(3,0,pong,89,24,GREEN);
display.drawBitmap(10,30,game,75,26,RED);
while(digitalRead(UP_BUTTON) == HIGH && digitalRead(DOWN_BUTTON) == HIGH)
delay(100);
unsigned long start = millis();
drawCourt();
while(millis() - start < 2000);
ball_update = millis();
paddle_update = ball_update;
ball_x = random(25,65);
ball_y = random(3,63);
unsigned long time = millis();
static bool up_state = false;
static bool down_state = false;
up_state |= (digitalRead(UP_BUTTON) == LOW);
down_state |= (digitalRead(DOWN_BUTTON) == LOW);
if(resetBall)
ball_x = random(25,70);
do
ball_dir_x = random(-1,2);
}while(ball_dir_x==0);
do
ball_dir_y = random(-1,2);
}while(ball_dir_y==0);
resetBall=false;
if(time > ball_update && gameIsRunning) {
uint8_t new_x = ball_x + ball_dir_x;
uint8_t new_y = ball_y + ball_dir_y;
// Check if we hit the vertical walls
if(new_x == 0) //Player Gets a Point
PLAYER_SCORE++;
if(PLAYER_SCORE==MAX_SCORE)
gameOver();
}else
showScore();
if(new_x == 95) //CPU Gets a Point
CPU_SCORE++;
if(CPU_SCORE==MAX_SCORE)
gameOver();
}else
showScore();
// Check if we hit the horizontal walls.
if(new_y == 0 || new_y == 63) {
ball_dir_y = -ball_dir_y;
new_y += ball_dir_y + ball_dir_y;
// Check if we hit the CPU paddle
if(new_x == CPU_X && new_y >= cpu_y && new_y <= cpu_y + PADDLE_HEIGHT) {
ball_dir_x = -ball_dir_x;
new_x += ball_dir_x + ball_dir_x;
// Check if we hit the player paddle
if(new_x == PLAYER_X
&& new_y >= player_y
&& new_y <= player_y + PADDLE_HEIGHT)
display.drawPixel(ball_x, ball_y, BLACK);
display.drawPixel(new_x, new_y, WHITE);
ball_x = new_x;
ball_y = new_y;
ball_update += BALL_RATE;
if(time > paddle_update && gameIsRunning) {
paddle_update += PADDLE_RATE;
// CPU paddle
display.drawFastVLine(CPU_X, cpu_y,PADDLE_HEIGHT, BLACK);
const uint8_t half_paddle = PADDLE_HEIGHT >> 1;
if(cpu_y + half_paddle > ball_y) {
cpu_y -= 1;
if(cpu_y + half_paddle < ball_y) {
cpu_y += 1;
if(cpu_y < 1) cpu_y = 1;
if(cpu_y + PADDLE_HEIGHT > 63) cpu_y = 63 - PADDLE_HEIGHT;
display.drawFastVLine(CPU_X, cpu_y, PADDLE_HEIGHT, RED);
// Player paddle
display.drawFastVLine(PLAYER_X, player_y,PADDLE_HEIGHT, BLACK);
if(up_state) {
player_y -= 1;
if(down_state) {
player_y += 1;
up_state = down_state = false;
if(player_y < 1) player_y = 1;
if(player_y + PADDLE_HEIGHT > 63) player_y = 63 - PADDLE_HEIGHT;
display.drawFastVLine(PLAYER_X, player_y, PADDLE_HEIGHT, GREEN);
void drawCourt() {
display.drawRect(0, 0, 96, 64, WHITE);
void gameOver()
gameIsRunning = false;
drawCourt();
if(PLAYER_SCORE>CPU_SCORE)
display.setCursor(5,4);
display.setTextColor(WHITE);
display.setTextSize(2);
display.print("You Won");
}else
display.print("CPU WON");
display.setCursor(20,30);
display.setTextColor(RED);
display.setTextSize(3);
display.print(String(CPU_SCORE));
display.setCursor(60,30);
display.setTextColor(GREEN);
display.print(String(PLAYER_SCORE));
delay(2000);
delay(100);
CPU_SCORE = PLAYER_SCORE = 0;
drawCourt();
resetBall=true;
void showScore()
drawCourt();
display.setCursor(15,4);
display.print("Score");
delay(2000);
drawCourt();
resetBall=true;
Сам что пытался сделать? Показывай попытки и говори, что именно не получается.
http://arduino.ru/forumy/ishchu-ispolnitelya
может кто нибудь и возмётся.
Сделал так но нет изображения. (я думал что есть универсальное решение, вроде как экраны очень похожи.) #include <SPI.h> #include <Wire.h> #include <Adafruit_GFX.h> #include <Adafruit_SSD1306.h> #define UP_BUTTON 2 #define DOWN_BUTTON 3 #define OLED_RESET 4 // MOSI is Data pin on display breakout const unsigned long PADDLE_RATE = 33; const unsigned long BALL_RATE = 20; const uint8_t PADDLE_HEIGHT = 24; int MAX_SCORE = 8; int CPU_SCORE = 0; int PLAYER_SCORE = 0; Adafruit_SSD1306 display(OLED_RESET); void drawCourt(); uint8_t ball_x = 64, ball_y = 32; uint8_t ball_dir_x = 1, ball_dir_y = 1; boolean gameIsRunning = true; boolean resetBall = false; static const unsigned char pong []PROGMEM = { 0xff,0xe0,0x0,0x3f,0x80,0x7,0xe0,0x7,0xc0,0x3,0xfc,0x0, 0xff,0xf8,0x1,0xff,0xe0,0x7,0xf0,0x7,0xc0,0x1f,0xff,0x0, 0xff,0xfc,0x3,0xff,0xf0,0x7,0xf0,0x7,0xc0,0x3f,0xff,0x0, 0xff,0xfe,0x7,0xff,0xf8,0x7,0xf8,0x7,0xc0,0xff,0xff,0x0, 0xf8,0x7f,0xf,0xff,0xfc,0x7,0xfc,0x7,0xc0,0xff,0xff,0x0, 0xf8,0x3f,0xf,0xe0,0xfe,0x7,0xfc,0x7,0xc1,0xfc,0x7,0x0, 0xf8,0x1f,0x1f,0x80,0x7e,0x7,0xfe,0x7,0xc3,0xf8,0x1,0x0, 0xf8,0x1f,0x1f,0x0,0x3e,0x7,0xfe,0x7,0xc3,0xf0,0x0,0x0, 0xf8,0x1f,0x3f,0x0,0x3f,0x7,0xdf,0x7,0xc7,0xe0,0x0,0x0, 0xf8,0x1f,0x3e,0x0,0x1f,0x7,0xdf,0x87,0xc7,0xc0,0x0,0x0, 0xf8,0x3f,0x3e,0x0,0x1f,0x7,0xcf,0x87,0xc7,0xc1,0xff,0x80, 0xf8,0x7e,0x3e,0x0,0x1f,0x7,0xc7,0xc7,0xc7,0xc1,0xff,0x80, 0xff,0xfe,0x3e,0x0,0x1f,0x7,0xc7,0xe7,0xc7,0xc1,0xff,0x80, 0xff,0xfc,0x3e,0x0,0x1f,0x7,0xc3,0xe7,0xc7,0xc1,0xff,0x80, 0xff,0xf8,0x3e,0x0,0x1f,0x7,0xc1,0xf7,0xc7,0xc0,0xf,0x80, 0xff,0xe0,0x3f,0x0,0x3f,0x7,0xc1,0xf7,0xc7,0xe0,0xf,0x80, 0xf8,0x0,0x1f,0x0,0x3e,0x7,0xc0,0xff,0xc3,0xe0,0xf,0x80, 0xf8,0x0,0x1f,0x80,0x7e,0x7,0xc0,0x7f,0xc3,0xf0,0xf,0x80, 0xf8,0x0,0x1f,0xc0,0xfc,0x7,0xc0,0x7f,0xc3,0xfc,0xf,0x80, 0xf8,0x0,0xf,0xff,0xfc,0x7,0xc0,0x3f,0xc1,0xff,0xff,0x80, 0xf8,0x0,0x7,0xff,0xf8,0x7,0xc0,0x3f,0xc0,0xff,0xff,0x80, 0xf8,0x0,0x3,0xff,0xf0,0x7,0xc0,0x1f,0xc0,0x7f,0xff,0x80, 0xf8,0x0,0x1,0xff,0xe0,0x7,0xc0,0xf,0xc0,0x3f,0xff,0x0, 0xf8,0x0,0x0,0x7f,0x0,0x7,0xc0,0xf,0xc0,0x7,0xf8,0x0 }; static const unsigned char game []PROGMEM ={ 0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x80, 0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x1,0xff,0x80, 0x0,0x0,0x0,0x0,0x0,0x0,0x0,0xc3,0xff,0x80, 0x0,0x0,0x0,0x0,0x0,0x0,0xf,0xc3,0xff,0x80, 0x0,0x0,0x0,0x0,0x3,0xe0,0xf,0xc3,0xe0,0x0, 0x0,0x0,0x0,0x0,0x7,0xf0,0x1f,0xc1,0xe0,0x0, 0x0,0x0,0x0,0xf8,0x7,0xf0,0x1f,0xc1,0xe0,0x0, 0x0,0xfc,0x1,0xfc,0x7,0xf8,0x1f,0xc1,0xe0,0x0, 0x7,0xfc,0x1,0xfc,0x3,0xf8,0x1f,0xe1,0xff,0x80, 0x1f,0xfc,0x1,0xde,0x3,0xbc,0x3d,0xe1,0xff,0x80, 0x3f,0xfe,0x1,0xde,0x3,0xbc,0x39,0xe1,0xff,0x80, 0x7e,0x0,0x3,0xdf,0x3,0xde,0x39,0xe1,0xfc,0x0, 0x7c,0x0,0x3,0xcf,0x3,0xde,0x39,0xe1,0xe0,0x0, 0xf8,0x0,0x3,0xcf,0x3,0xcf,0x39,0xe1,0xf0,0x0, 0xf8,0x0,0x3,0x87,0x83,0xcf,0x79,0xe0,0xf0,0x0, 0xf0,0x7f,0x7,0x87,0x83,0xc7,0xf1,0xe0,0xf0,0xe0, 0xf0,0xff,0x7,0x83,0xc3,0xc7,0xf1,0xe0,0xff,0xe0, 0xf0,0xff,0x7,0xff,0xc1,0xc3,0xf1,0xf0,0xff,0xe0, 0xf0,0xff,0x7,0xff,0xe1,0xc3,0xf0,0xf0,0xff,0xe0, 0xf8,0xf,0xf,0xff,0xe1,0xc1,0xe0,0xf0,0xe0,0x0, 0xf8,0xf,0x8f,0x1,0xf1,0xe1,0xe0,0xf0,0x0,0x0, 0x7c,0xf,0x8f,0x0,0xf1,0xe1,0xe0,0x0,0x0,0x0, 0x7f,0x1f,0x8f,0x0,0xf9,0xc0,0x0,0x0,0x0,0x0, 0x3f,0xff,0x9f,0x0,0x0,0x0,0x0,0x0,0x0,0x0, 0x1f,0xff,0x1f,0x0,0x0,0x0,0x0,0x0,0x0,0x0, 0x7,0xfc,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0 }; unsigned long ball_update; unsigned long paddle_update; const uint8_t CPU_X = 12; uint8_t cpu_y = 16; const uint8_t PLAYER_X = 85; uint8_t player_y = 16; void setup() { display.begin(SSD1306_SWITCHCAPVCC, 0x3D); // Display the splash screen (we're legally required to do so) display.display(); delay(2000); display.clearDisplay(); pinMode(UP_BUTTON, INPUT_PULLUP); pinMode(DOWN_BUTTON, INPUT_PULLUP); display.fillScreen(BLACK); display.drawBitmap(3,0,pong,89,24,WHITE); display.drawBitmap(10,30,game,75,26,WHITE); while(digitalRead(UP_BUTTON) == HIGH && digitalRead(DOWN_BUTTON) == HIGH) { delay(100); } unsigned long start = millis(); display.fillScreen(BLACK); drawCourt(); while(millis() - start < 2000); ball_update = millis(); paddle_update = ball_update; ball_x = random(25,65); ball_y = random(3,63); } void loop() { unsigned long time = millis(); static bool up_state = false; static bool down_state = false; up_state |= (digitalRead(UP_BUTTON) == LOW); down_state |= (digitalRead(DOWN_BUTTON) == LOW); if(resetBall) { ball_x = random(25,70); ball_y = random(3,63); do { ball_dir_x = random(-1,2); }while(ball_dir_x==0); do { ball_dir_y = random(-1,2); }while(ball_dir_y==0); resetBall=false; } if(time > ball_update && gameIsRunning) { uint8_t new_x = ball_x + ball_dir_x; uint8_t new_y = ball_y + ball_dir_y; // Check if we hit the vertical walls if(new_x == 0) //Player Gets a Point { PLAYER_SCORE++; if(PLAYER_SCORE==MAX_SCORE) { gameOver(); }else { showScore(); } } // Check if we hit the vertical walls if(new_x == 95) //CPU Gets a Point { CPU_SCORE++; if(CPU_SCORE==MAX_SCORE) { gameOver(); }else { showScore(); } } // Check if we hit the horizontal walls. if(new_y == 0 || new_y == 63) { ball_dir_y = -ball_dir_y; new_y += ball_dir_y + ball_dir_y; } // Check if we hit the CPU paddle if(new_x == CPU_X && new_y >= cpu_y && new_y <= cpu_y + PADDLE_HEIGHT) { ball_dir_x = -ball_dir_x; new_x += ball_dir_x + ball_dir_x; } // Check if we hit the player paddle if(new_x == PLAYER_X && new_y >= player_y && new_y <= player_y + PADDLE_HEIGHT) { ball_dir_x = -ball_dir_x; new_x += ball_dir_x + ball_dir_x; } display.drawPixel(ball_x, ball_y, BLACK); display.drawPixel(new_x, new_y, WHITE); ball_x = new_x; ball_y = new_y; ball_update += BALL_RATE; } if(time > paddle_update && gameIsRunning) { paddle_update += PADDLE_RATE; // CPU paddle display.drawFastVLine(CPU_X, cpu_y,PADDLE_HEIGHT, BLACK); const uint8_t half_paddle = PADDLE_HEIGHT >> 1; if(cpu_y + half_paddle > ball_y) { cpu_y -= 1; } if(cpu_y + half_paddle < ball_y) { cpu_y += 1; } if(cpu_y < 1) cpu_y = 1; if(cpu_y + PADDLE_HEIGHT > 63) cpu_y = 63 - PADDLE_HEIGHT; display.drawFastVLine(CPU_X, cpu_y, PADDLE_HEIGHT, WHITE); // Player paddle display.drawFastVLine(PLAYER_X, player_y,PADDLE_HEIGHT, BLACK); if(up_state) { player_y -= 1; } if(down_state) { player_y += 1; } up_state = down_state = false; if(player_y < 1) player_y = 1; if(player_y + PADDLE_HEIGHT > 63) player_y = 63 - PADDLE_HEIGHT; display.drawFastVLine(PLAYER_X, player_y, PADDLE_HEIGHT, WHITE); } } void drawCourt() { display.drawRect(0, 0, 96, 64, WHITE); } void gameOver() { gameIsRunning = false; display.fillScreen(BLACK); drawCourt(); if(PLAYER_SCORE>CPU_SCORE) { display.setCursor(5,4); display.setTextColor(WHITE); display.setTextSize(2); display.print("You Won"); }else { display.setCursor(5,4); display.setTextColor(WHITE); display.setTextSize(2); display.print("defeat"); } display.setCursor(20,30); display.setTextColor(WHITE); display.setTextSize(3); display.print(String(CPU_SCORE)); display.setCursor(60,30); display.setTextColor(WHITE); display.setTextSize(3); display.print(String(PLAYER_SCORE)); delay(2000); while(digitalRead(UP_BUTTON) == HIGH && digitalRead(DOWN_BUTTON) == HIGH) { delay(100); } gameIsRunning = true; CPU_SCORE = PLAYER_SCORE = 0; unsigned long start = millis(); display.fillScreen(BLACK); drawCourt(); while(millis() - start < 2000); ball_update = millis(); paddle_update = ball_update; gameIsRunning = true; resetBall=true; } void showScore() { gameIsRunning = false; display.fillScreen(BLACK); drawCourt(); display.setCursor(15,4); display.setTextColor(WHITE); display.setTextSize(2); display.print("Score"); display.setCursor(20,30); display.setTextColor(WHITE); display.setTextSize(3); display.print(String(CPU_SCORE)); display.setCursor(60,30); display.setTextColor(WHITE); display.setTextSize(3); display.print(String(PLAYER_SCORE)); delay(2000); unsigned long start = millis(); display.fillScreen(BLACK); drawCourt(); while(millis() - start < 2000); ball_update = millis(); paddle_update = ball_update; gameIsRunning = true; resetBall=true; }
