помогите скрестить Funduino mega с LCD-Blue-I2C
vshuka
всем здрасте. никак не могу скрестить плату с жк.вроде всего 4 провода а работать не хочет.есть скеч,есть соединение с пин 20 и 21 а толку нет.помогите пожалуста
/* YourDuino.com Example Software Sketch
 20 character 4 line I2C Display
 Backpack Interface labelled "LCM1602 IIC  A0 A1 A2"
 terry@yourduino.com */
/*-----( Import needed libraries )-----*/
#include <Wire.h>  // Comes with Arduino IDE
// Get the LCD I2C Library here:
// Move any other LCD libraries to another folder or delete them
// See Library "Docs" folder for possible commands etc.
/*-----( Declare Constants )-----*/
//none
/*-----( Declare objects )-----*/
// set the LCD address to 0x27 for a 20 chars 4 line display
// Set the pins on the I2C chip used for LCD connections:
//                    addr, en,rw,rs,d4,d5,d6,d7,bl,blpol
LiquidCrystal_I2C lcd(0x20, 4, 5, 6, 0, 1, 2, 3, 7, NEGATIVE);  // Set the LCD I2C address
/*-----( Declare Variables )-----*/
//none
void setup()   /*----( SETUP: RUNS ONCE )----*/
  Serial.begin(9600);  // Used to type in characters
  lcd.begin(20,4);         // initialize the lcd for 20 chars 4 lines
// NOTE: Cursor Position: CHAR, LINE) start at 0
  lcd.setCursor(3,0); //Start at character 4 on line 0
  lcd.print("Hello, world!");
  lcd.setCursor(2,1);
  lcd.print("From YourDuino");
  lcd.setCursor(0,2);
  lcd.print("20 by 4 Line Display");
  lcd.setCursor(0,3);
  delay(2000);
  lcd.print("http://YourDuino.com");
  delay(8000);
// Wait and then tell user they can start the Serial Monitor and type in characters to
// Display. (Set Serial Monitor option to "No Line Ending")
  lcd.setCursor(0,0); //Start at character 0 on line 0
  lcd.print("Start Serial Monitor");
  lcd.setCursor(0,1);
  lcd.print("Type chars 2 display");
}/*--(end setup )---*/
void loop()   /*----( LOOP: RUNS CONSTANTLY )----*/
    // when characters arrive over the serial port...
    if (Serial.available()) {
      // wait a bit for the entire message to arrive
      delay(100);
      // clear the screen
      lcd.clear();
      // read all the available characters
      while (Serial.available() > 0) {
        // display each character to the LCD
        lcd.write(Serial.read());
}/* --(end main loop )-- */
/* ( THE END ) */
Snubist
Первое, http://arduino.ru/forum/obshchii/vstavka-programmnogo-koda-v-temukommentarii
Второе. Адрес точно 0x20?
Третье. Какой дисплей, 16х2 или 20х4 и откуда куча цифирь и что они обозначают?
когда достаточно
LiquidCrystal_I2C lcd(0x20,16,2);
vshuka
дисплей 20х4
когда я ставлю
выдает ошибку при компиляции
а за адрес я даже не знаю,объясни пожалуста подробней
step962
Онлайн
Wiki вам в помощь
vshuka
хорошо,прочел,адрес деыствительно 0х20 но ничего не изменилось,все равно не работает
Snubist
попробуй
#include <Wire.h>
   lcd.begin(20,4);
  lcd.backlight();
И проверь, контакты точно так подключены как ты их инициализируешь. Еще случайно Sda и Scl местами не перепутал?
vshuka
неа,синий экран и мертвый
Snubist
Ты, SDA и SCL к плюсу подтянул?
vshuka
извени,но можно поподробней?
я сделал все как указано в инструкции:YwRobot Arduino LCM1602 IIc V1  4 выхода: gnd-gnd vcc-+5 sda-21 scl-20
экран горит синим светом,видно разделение рядов,одни более светлее другие нет,но на экран ничего не выводится.в соседней ветке я прочитал что у кого то тоже была такая проблема типа "непропай" как это можно проверить и как исправить? спасибо
vshuka
