Arduino uno r3 и 3,5 TFT
Чт, 19/03/2015 - 23:01
Покупал вот здесь: http://ru.aliexpress.com/item/Free-shipping-LCD-Display-Module-TFT-3-5-inch-TFT-LCD-screen-for-Arduino-UNO-R3/1995671772.html?isOrig=true#extend
Не получается завести не тач ни дисплей, библиотеки UTFT и UTouch поставил.
Кинте плиз какой нибудь скетч для примера
Работает только:
// ic:ili9327
#define LCD_RD A0
#define LCD_WR A1
#define LCD_RS A2
#define LCD_CS A3
#define LCD_REST A4
void Lcd_Writ_Bus(char VH)
unsigned char i,temp,data;
data=VH;
for(i=8;i<=9;i++)
temp=(data&0x01);
if(temp)
digitalWrite(i,HIGH);
digitalWrite(i,LOW);
data=data>>1;
for(i=2;i<=7;i++)
temp=(data&0x01);
if(temp)
data=data>>1;
digitalWrite(LCD_WR,LOW);
digitalWrite(LCD_WR,HIGH);
void Lcd_Write_Com(char VH)
digitalWrite(LCD_RS,LOW);
Lcd_Writ_Bus(VH);
void Lcd_Write_Data(char VH)
digitalWrite(LCD_RS,HIGH);
Lcd_Writ_Bus(VH);
void Lcd_Write_Com_Data(int com,int dat)
Lcd_Write_Com(com);
Lcd_Write_Data(dat);
void Address_set(unsigned int x1,unsigned int y1,unsigned int x2,unsigned int y2)
Lcd_Write_Com(0x2a); // Set_column_address 4 parameters
Lcd_Write_Data(x1>>8);
Lcd_Write_Data(x1);
Lcd_Write_Data(x2>>8);
Lcd_Write_Data(x2);
Lcd_Write_Com(0x2b); // Set_page_address 4 parameters
Lcd_Write_Data(y1>>8);
Lcd_Write_Data(y1);
Lcd_Write_Data(y2>>8);
Lcd_Write_Data(y2);
Lcd_Write_Com(0x2c); // Write_memory_start
void Lcd_Init(void)
digitalWrite(LCD_REST,HIGH);
delay(5);
digitalWrite(LCD_REST,LOW);
delay(15);
delay(15);
digitalWrite(LCD_CS,HIGH);
digitalWrite(LCD_CS,LOW); //CS
Lcd_Write_Com(0xE9);
Lcd_Write_Data(0x20);
Lcd_Write_Com(0x11); //Exit Sleep
delay(100);
Lcd_Write_Com(0xD1);
Lcd_Write_Data(0x00);
Lcd_Write_Data(0x71);
Lcd_Write_Data(0x19);
Lcd_Write_Com(0xD0);
Lcd_Write_Data(0x07);
Lcd_Write_Data(0x01);
Lcd_Write_Data(0x08);
Lcd_Write_Com(0x36);
Lcd_Write_Data(0x48);
Lcd_Write_Com(0x3A);
Lcd_Write_Data(0x05);
Lcd_Write_Com(0xC1);
Lcd_Write_Data(0x10);
Lcd_Write_Data(0x02);
Lcd_Write_Com(0xC0); //Set Default Gamma
Lcd_Write_Data(0x35);
Lcd_Write_Com(0xC5); //Set frame rate
Lcd_Write_Data(0x04);
Lcd_Write_Com(0xD2); //power setting
Lcd_Write_Data(0x44);
Lcd_Write_Com(0xC8); //Set Gamma
Lcd_Write_Data(0x67);
Lcd_Write_Data(0x06);
Lcd_Write_Data(0x24);
Lcd_Write_Data(0x37);
Lcd_Write_Data(0x40);
Lcd_Write_Data(0x03);
Lcd_Write_Data(0x80);
Lcd_Write_Com(0x2A);
Lcd_Write_Data(0xeF);
Lcd_Write_Com(0x2B);
// Lcd_Write_Data(0x3F);
Lcd_Write_Data(0x8F); // on internet
Lcd_Write_Com(0x29); //display on
Lcd_Write_Com(0x2C); //display on
void H_line(unsigned int x, unsigned int y, unsigned int l, unsigned int c)
unsigned int i,j;
Lcd_Write_Com(0x02c); //write_memory_start
l=l+x;
Address_set(x,y,l,y);
j=l*2;
for(i=1;i<=j;i++)
Lcd_Write_Data(c);
void V_line(unsigned int x, unsigned int y, unsigned int l, unsigned int c)
unsigned int i,j;
l=l+y;
Address_set(x,y,x,l);
j=l*2;
for(i=1;i<=j;i++)
Lcd_Write_Data(c);
void Rect(unsigned int x,unsigned int y,unsigned int w,unsigned int h,unsigned int c)
H_line(x , y , w, c);
H_line(x , y+h, w, c);
V_line(x , y , h, c);
V_line(x+w, y , h, c);
void Rectf(unsigned int x,unsigned int y,unsigned int w,unsigned int h,unsigned int c)
unsigned int i;
for(i=0;i<h;i++)
H_line(x , y+i, w, c);
void LCD_Clear(unsigned int j)
unsigned int i,m;
Address_set(0,0,479,399);
for(i=0;i<480;i++)
for(m=0;m<400;m++)
Lcd_Write_Data(j);
for(int p=2;p<10;p++)
pinMode(p,OUTPUT);
pinMode(A0,OUTPUT);
pinMode(A1,OUTPUT);
pinMode(A2,OUTPUT);
pinMode(A3,OUTPUT);
pinMode(A4,OUTPUT);
digitalWrite(A0, HIGH);
digitalWrite(A1, HIGH);
digitalWrite(A2, HIGH);
digitalWrite(A3, HIGH);
digitalWrite(A4, HIGH);
Lcd_Init();
LCD_Clear(0x00);
for(int i=0;i<1000;i++)
Rect(random(300),random(300),random(300),random(300),random(65535)); // rectangle at x, y, with, hight, color
LCD_Clear(0x00);
Помогите нубу =(
Поправленная для этого модуля библиотека, там же примеры есть.
https://github.com/dgolda/UTFT
Гит полностьб скачал? Папка hardware тоже нужна.
Да, папка hardware есть в папке с библиотекой
Вот содержание файла HW_ATmega328P.h, на который компилятор ругается:
// *** Hardwarespecific functions *** void UTFT::_hw_special_init() { } void UTFT::LCD_Writ_Bus(char VH,char VL, byte mode) { switch (mode) { case 1: if (display_serial_mode==SERIAL_4PIN) { if (VH==1) sbi(P_SDA, B_SDA); else cbi(P_SDA, B_SDA); pulse_low(P_SCL, B_SCL); } else { if (VH==1) sbi(P_RS, B_RS); else cbi(P_RS, B_RS); } if (VL & 0x80) sbi(P_SDA, B_SDA); else cbi(P_SDA, B_SDA); pulse_low(P_SCL, B_SCL); if (VL & 0x40) sbi(P_SDA, B_SDA); else cbi(P_SDA, B_SDA); pulse_low(P_SCL, B_SCL); if (VL & 0x20) sbi(P_SDA, B_SDA); else cbi(P_SDA, B_SDA); pulse_low(P_SCL, B_SCL); if (VL & 0x10) sbi(P_SDA, B_SDA); else cbi(P_SDA, B_SDA); pulse_low(P_SCL, B_SCL); if (VL & 0x08) sbi(P_SDA, B_SDA); else cbi(P_SDA, B_SDA); pulse_low(P_SCL, B_SCL); if (VL & 0x04) sbi(P_SDA, B_SDA); else cbi(P_SDA, B_SDA); pulse_low(P_SCL, B_SCL); if (VL & 0x02) sbi(P_SDA, B_SDA); else cbi(P_SDA, B_SDA); pulse_low(P_SCL, B_SCL); if (VL & 0x01) sbi(P_SDA, B_SDA); else cbi(P_SDA, B_SDA); pulse_low(P_SCL, B_SCL); break; case 8: PORTD = VH; pulse_low(P_WR, B_WR); PORTD = VL; pulse_low(P_WR, B_WR); break; case 16: PORTD = VH; cport(PORTC, 0xFC); sport(PORTC, (VL>>6) & 0x03); PORTB = VL & 0x3F; pulse_low(P_WR, B_WR); break; case LATCHED_16: PORTD = VH; cbi(P_ALE, B_ALE); pulse_high(P_ALE, B_ALE); cbi(P_CS, B_CS); PORTD = VL; pulse_low(P_WR, B_WR); sbi(P_CS, B_CS); break; } } void UTFT::_set_direction_registers(byte mode) { DDRD = 0xFF; if (mode==16) { DDRB |= 0x3F; DDRC |= 0x03; } } void UTFT::_fast_fill_16(int ch, int cl, long pix) { long blocks; PORTD = ch; cport(PORTC, 0xFC); sport(PORTC, (cl>>6) & 0x03); PORTB = cl & 0x3F; blocks = pix/16; for (int i=0; i<blocks; i++) { pulse_low(P_WR, B_WR); pulse_low(P_WR, B_WR); pulse_low(P_WR, B_WR); pulse_low(P_WR, B_WR); pulse_low(P_WR, B_WR); pulse_low(P_WR, B_WR); pulse_low(P_WR, B_WR); pulse_low(P_WR, B_WR); pulse_low(P_WR, B_WR); pulse_low(P_WR, B_WR); pulse_low(P_WR, B_WR); pulse_low(P_WR, B_WR); pulse_low(P_WR, B_WR); pulse_low(P_WR, B_WR); pulse_low(P_WR, B_WR); pulse_low(P_WR, B_WR); } if ((pix % 16) != 0) for (int i=0; i<(pix % 16)+1; i++) { pulse_low(P_WR, B_WR); } } void UTFT::_fast_fill_8(int ch, long pix) { long blocks; PORTD = ch; blocks = pix/16; for (int i=0; i<blocks; i++) { pulse_low(P_WR, B_WR);pulse_low(P_WR, B_WR); pulse_low(P_WR, B_WR);pulse_low(P_WR, B_WR); pulse_low(P_WR, B_WR);pulse_low(P_WR, B_WR); pulse_low(P_WR, B_WR);pulse_low(P_WR, B_WR); pulse_low(P_WR, B_WR);pulse_low(P_WR, B_WR); pulse_low(P_WR, B_WR);pulse_low(P_WR, B_WR); pulse_low(P_WR, B_WR);pulse_low(P_WR, B_WR); pulse_low(P_WR, B_WR);pulse_low(P_WR, B_WR); pulse_low(P_WR, B_WR);pulse_low(P_WR, B_WR); pulse_low(P_WR, B_WR);pulse_low(P_WR, B_WR); pulse_low(P_WR, B_WR);pulse_low(P_WR, B_WR); pulse_low(P_WR, B_WR);pulse_low(P_WR, B_WR); pulse_low(P_WR, B_WR);pulse_low(P_WR, B_WR); pulse_low(P_WR, B_WR);pulse_low(P_WR, B_WR); pulse_low(P_WR, B_WR);pulse_low(P_WR, B_WR); pulse_low(P_WR, B_WR);pulse_low(P_WR, B_WR); } if ((pix % 16) != 0) for (int i=0; i<(pix % 16)+1; i++) { pulse_low(P_WR, B_WR);pulse_low(P_WR, B_WR); } }http://arduino.ru/forum/apparatnye-voprosy/tft-35-i-arduino - тут еще покури тред.
http://arduino.ru/forum/apparatnye-voprosy/displei-na-ili9341
Это для Mega а у меня UNO
