// Written by Nick Gammon
// February 2011
// Note: maximum address is 0x7FFF (32 Kbytes)
#include <Wire.h>
const byte rom = 0x50; // Address of 24LC256 eeprom chip
void setup (void)
Serial.begin (9600); // debugging
Wire.begin ();
// test: write the number 123 to address 0x1234
writeEEPROM (rom, 0x1234, 123);
// read back to confirm
byte a = readEEPROM (rom, 0x1234);
Serial.println (a, DEC); // display to confirm
// test: write a string to address 0x1000
byte hello [] = "Hello, world!";
writeEEPROM (rom, 0x1000, hello, sizeof hello);
byte test [sizeof hello];
byte err = readEEPROM (rom, 0x1000, test, sizeof test);
Serial.println ((char *) test); // display to confirm
} // end of setup
void loop() {} // no main loop
// write len (max 32) bytes to device, returns non-zero on error
// return code: 0xFF means buffer too long
// other: other error (eg. device not present)
// Note that if writing multiple bytes the address plus
// length must not cross a 64-byte boundary or it will "wrap"
byte writeEEPROM (byte device, unsigned int addr, byte * data, byte len )
byte err;
byte counter;
if (len > BUFFER_LENGTH) // 32 (in Wire.h)
return 0xFF; // too long
Wire.beginTransmission(device);
Wire.write ((byte) (addr >> 8)); // high order byte
Wire.write ((byte) (addr & 0xFF)); // low-order byte
Wire.write (data, len);
err = Wire.endTransmission ();
if (err != 0)
return err; // cannot write to device
// wait for write to finish by sending address again
// ... give up after 100 attempts (1/10 of a second)
for (counter = 0; counter < 100; counter++)
delayMicroseconds (300); // give it a moment
Wire.beginTransmission (device);
if (err == 0)
return err;
} // end of writeEEPROM
// write one byte to device, returns non-zero on error
byte writeEEPROM (byte device, unsigned int addr, byte data )
return writeEEPROM (device, addr, &data, 1);
// read len (max 32) bytes from device, returns non-zero on error
// 0xFE means device did not return all requested bytes
// Note that if reading multiple bytes the address plus
byte readEEPROM (byte device, unsigned int addr, byte * data, byte len )
byte err;
byte counter;
if (err != 0)
return err; // cannot read from device
// initiate blocking read into internal buffer
Wire.requestFrom (device, len);
// pull data out of Wire buffer into our buffer
for (counter = 0; counter < len; counter++)
data [counter] = Wire.read ();
return 0; // OK
} // end of readEEPROM
// read one byte from device, returns 0xFF on error
byte readEEPROM (byte device, unsigned int addr )
byte temp;
if (readEEPROM (device, addr, &temp, 1) == 0)
return temp;
return 0xFF;
мне просто нужно записать 10 переменных и потом просто их только читать. Можете помочь только с одним как записать данные в одну ячейку допустим в 100 и число десятичное 155
Очень давно хотелось поделиться своим опытом, с начинающими радиолюбителями, потому что об этом пишут очень мало и разрозненно. Мой опыт не хороший, не плохой, он такой какой есть. С некоторыми утверждениями вы в праве не согласиться и это нормально, ведь у каждого свое видение ситуации. Цель данного материала, обратить внимание читателя на некоторые вещи, что то взять на заметку и сформировать собственное мнение и видение ситуации, ни в коем случае нельзя воспринимать это как истину. 1. Многие начинающие электронщики не знают с чего начать, поэтому спрашивают совета. Большинство бывалых радиолюбителей ответят, что начни собирать какую нибудь схему. Естественно в голове любого начинающего сразу мелькает LCD дисплей с jpeg картинками, какой нибудь mp3 плеер или часы, без малейшей мысли о том, что не имея базовых знаний это неподъемная задача.
Я категорически против такого подхода. Обычно это все заканчивается — либо ничем, либо забитые форумы с мольбами помочь. Даже если кому то помогают, то в 90% он больше никогда не всплывет на сайтах по электронике. В остальных 10% он так и продолжает заливать форумы мольбами, его будут сначала пинать, затем поливать грязью. Из этих 10% отсеивается еще 9%. Далее два варианта: либо таки до глупой головы доходит и все же происходит goto к началу, либо в особо запущенных вариантах, его удел копировать чужие конструкции, без единой мысли о том как это работает. Из последних зачастую рождаются ардуинщики.
Путь с нуля на мой взгляд заключается в изучении периферии и особенностей, если это микроконтроллер. Правильнее сначала разобраться с тем как дрыгать ножками, потом с таймерами, затем интерфейсами. И только тогда пытаться поднимать свой FAT. Да это не быстро, да это потребует времени и усилий, но практика показывает, как бы вы не пытались сократить этот путь, все равно всплывут проблемы, которые придется решать и время вы потратите куда больше, не имея этой базы.
Только не нужно путать теплое и мягкое. Первое — из всех правил есть исключения, лично видел людей, которые в руках раньше не держали микроконтроллеров, но за крайне короткий срок смогли обскакать бывалых опытных радиолюбителей, их в расчет не берем. Второе — мне попадались личности, которые начинали с копирования схем и сходу разбирались, но скорее это тоже исключение из правил. Третье — и среди ардуинщиков попадаются опытные программисты, это ведь всего навсего платформа, но и это скорее исключение.
Если говорить об общей массе, то дела обстоят именно так как я описал вначале: нежелание разбираться с основами, в лучшем случае оттягивает момент того, когда придется вернуться к этим вопросам. В худшем случае, вы быстро упретесь в потолок своих знаний и все время винить в своих проблемах кого то другого.
2. Перед решением задачи, дробите ее до абсурда вплоть до «припаять резистор», это помогает, проверено. Мелкие задачи решать куда проще. Когда большая задача разбита на кучу мелких действий, то все что остается — это выполнить их. Могу привести еще один годный совет, хоть он вам и покажется бредовым — заведите блокнотик и пишите в него все что собираетесь сделать. Вы думаете, итак запомню, но нет. Допустим сегодня у меня хорошее настроение и думаю о том, как собрать плату. Запиши план действий: сходить купить резистор, подготовить провода, сделать крепление дисплея. Потом все забудешь, откроешь блокнотик и смотришь — ага сегодня настроение попилить и построгать, сделаю крепление. Или собираешь ты плату и уже осталось допаять последний компонент, но не тут то было резисторы кончились, вот записал бы перед тем как паять, то вспомнил.
3. Не пользуйтесь кодогенераторами, нестандартными фичами и прочими упрощалками, хотя бы на первых этапах. Могу привести свой личный пример. Во времена активного использования AVR я пользовался кодогеном CAVR. Меня он полностью устраивал, хотя все говорили, что он кака. Звоночки звенели постоянно, были проблемы с библиотеками, с синтаксисом, с портированием, но было тяжело от этого отказаться. Я не разбирался как это работает, просто знал где и как поставить галочки.
Кол в мой гроб был вбит с появлением STM32, нужно было обязательно переползать на них, вот тогда то и появились проблемы. Проблемы мягко сказано, фактически мне пришлось осваивать микроконтроллеры и язык Си с нуля. Больше я не повторял прошлых ошибок. Надо сказать это уже пригодилось и не один раз. С тех пор мне довелось поработать с другими платформами и никаких затруднений не испытываю, подход оправдывает себя.
По поводу всех улучшалок и упрощалок, было одно очень хорошее сравнение, что они подобны инвалидным коляскам, которые едут по рельсам, можно ехать и наслаждаться, но вставать нельзя, куда везут — туда и приедешь.
4. Изучайте язык Си. Эх, как же часто я слышу, как начинающие радиолюбители хвалятся, что хорошо знают сишку. Для меня это стало кормом, всегда люблю проконсультироваться у таких собеседников. Обычно сразу выясняется, что язык они совершенно не знают. Могу сказать, что не смотря на кажущуюся простоту, людей которые действительно хорошо бы его знали, встречал не так много. В основном все его знают на столько, на сколько требуется для решения задач.
Однако, проблема на мой взгляд заключается в том, что не зная возможностей, вы сильно ограничиваете себя. С одной стороны не оптимальные решения, которые потребуют более мощного железа, с другой стороны не читаемый код, который сложно поддерживать. На мой взгляд, читаемость и поддерживаемость кода занимает одно из важнейших мест и мне сложно представить, как можно этого добиться не используя все возможности языка Си.
Очень многие начинающие брезгуют изучением языка, поэтому если вы не будете как все, то сразу станете на две ступени выше остальных новичков. Так же не никакой разницы, где изучать язык. На мой взгляд, микроконтроллер для этого не очень подходит. Гораздо проще поставить какую нибудь Visual studio или Qt Creator и порешать задачки в командной строке.
Хорошим подспорьем будет также изучение всяких тестов по языку, которые дают при собеседованиях. Если порыться то можно много нового узнать.
5. Изучение ассемблера? Бояться его не нужно, равно как и боготворить. Не нужно думать, что умея написать программу на ассемблере, вы сразу станете гуру микроконтроллеров, почему то это частое заблуждение. В первую очередь это инструмент. Даже если вы не планируете использовать его, то все равно я бы настоятельно рекомендовал написать хотя бы пару программ. Это сильно упростит понимание работы микроконтроллера и внутреннего устройства программ.
6. Читайте даташит. Многие разработчики, пренебрегают этим. Изучая даташит вы будете на две ступени выше тех разработчиков. Делать это крайне полезно, во первых это первоисточник, какие бы сайты вы не читали, в большинстве случаев они повторяют информацию из даташита, зачастую с ошибками и недосказанностями. Кроме того, там может находиться информация, о которой вы не задумываетесь сейчас, но которая может пригодиться в будущем. Может статься так, что вылезет какая то ошибка и вы вспомните что да, в даташите об этом было сказано. Если ваша цель стать хорошим разработчиком, то этого этапа не избежать, читать даташиты придется, чем раньше вы начнете это делать, тем быстрее пойдет рост.
7. Часто народ просит прислать даташит на русском. Даташит — это то, что должно восприниматься как истина, самая верная информация. Даже там не исключены ошибки. Если к этому добавятся ошибки переводчика, он ведь тоже человек, может даже не нарочно, просто опечататься. Либо у него свое видение, может что-то упустить, на его взгляд не важное, но возможно крайне важное для вас. Особенно смешной становится ситуация, когда нужно найти документацию на не сильно популярные компоненты.
На мой взгляд, намного проще исключить заранее весь слой этих проблем, чем вылавливать их потом. Поэтому я категорически против переводов, единственный верный совет — изучайте английский язык, чтобы читать даташиты и мануалы в оригинале. Понять смысл фразы с помощью программ переводчиков можно, даже если уровень вашего языка полный ноль.
Мною был проведен эксперимент: в наличии был студент, даташит и гугл переводчик. Эксперимент №1: студенту вручен даташит и дано задание самостоятельно найти нужные значения, результат — «да как я смогу», «да я не знаю английский», «я ничего не нашел/я не понял» типичные фразы, говорящие о том, что он даже не пытался. Эксперимент №2: тому же студенту, вручен все тот же даташит и тоже задание, с той разницей, что я сел рядом. Результат — через 5 минут он сам нашел все нужные значения, абсолютно без моего участия, без знания английского.
8. Изобретайте велосипед. Например, изучаете какую то новую штуку, допустим транзистор, дядька Хоровиц со страниц своей книги авторитетно заявляет, что транзистор усиливает, всегда говорите — НЕ ВЕРЮ. Берем в руки транзистор включаем его в схему и убеждаемся что это действительно так. Есть целый пласт проблем и тонкостей, которые не описываются в книгах. Прочувствовать их можно только, когда возьмешь в руки и попробуешь собрать. При этом получаем кучу попутных знаний, узнаем тонкости. Кроме того, любая теория без практики забудется намного быстрее.
На первоначальном этапе, мне очень сильно помог один метод — сначала собираешь схему и смотришь как она работает, а затем пытаешься найти обоснование в книге. То же самое и с программной частью, когда есть готовая программа, то проще разобраться в ней и соотнести куски кода, какой за что отвечает.
Также важно выходить за рамки дозволенного, подать побольше/поменьше напряжение, делать больше/меньше резисторы и следить за изменениями в работе схемы. В мозгу все это остается и оно пригодится в будущем. Да это чревато расходом компонентов, но я считаю это неизбежным. Первое время я сидел и палил все подряд, но теперь перед тем как поставить тот или иной номинал, всегда вспоминаю те веселые времена и последствия того, если поставить неверный номинал.
9. А как бы я сделал это, если бы находился на месте разработчиков? Могу ли я сделать лучше? Каждый раз задавайте себе эти вопросы, это очень хорошо помогает продвигаться в обучении. Например, изучите интерфейсы 1wire, i2c, spi, uart, а потом подумайте чем они отличаются, можно ли было сделать лучше, это поможет осознать почему все именно так, а не иначе. Так же вы будете осознавать, когда и какой лучше применить.
10. Не ограничивайтесь в технологиях. Важно что этот совет имеет очень тонкую грань. Был этап в жизни, когда из каждой подворотни доносилось «надо бы знать ПЛИС», «а вот на ПЛИС то можно сделать». Формально у меня не было целей изучать ПЛИСины, но и пройти мимо было никак нельзя. Этому вопросу было выделено немного времени на ознакомление. Время не прошло зря, у меня был целый ряд вопросов, касаемых внутреннего устройства микроконтроллеров, именно после общения с плисинами я получил ответы на них. Подобных примеров много, все знания, которые я приобретал в том или ином виде, рано или поздно пригодились. У меня нет ни единого бесполезного примера.
Но как было сказано, вопрос технологий имеет тонкую грань. Не нужно хвататься за все подряд. В электронике много направлений. Может вам нравится аналог, может цифра, может вы специалист по источникам питания. Если не понятно, то попробуйте себя везде, но практика показывает, что вначале лучше сконцентрироваться на чем то конкретном. Даже если нужно жать в нескольких направлениях, то лучше делать это ступеньками, сначала продавить что то одно.
11. Если спросить начинающего радиолюбителя, что ему больше нравится программирование или схемотехника, то с вероятностью 99% ответ будет программирование. При этом большую часть времени эти программисты тратят на изготовление плат ЛУТом/фоторезистом. Причины в общем то понятны, но довольно часто это переходит в некий маразм, который состоит в изготовлении плат ради изготовления плат.
В интернетах практически единственный трушный путь к программированию это стать джедаем изготовления печатных плат. Я тоже прошел через этот путь, но каждый раз задаю себе вопрос зачем? С тех пор, как я приобрел себе пару плат, на все случаи жизни, каждый раз думаю о том, что мог бы спокойно прожить все это время без самодельных плат. Мой совет, если есть хоть капля сомнений, то лучше не заморачиваться и взять готовую отладочную плату, а время и средства лучше бы потратить на программирование.
12. Следующий совет, особенно болезненный, мне очень не хочется его обсуждать, но надо. Часто мне пишут, мол ххх руб за ууу дорого, где бы подешевле достать. Вроде бы обычный вопрос, но обычно я сразу напрягаюсь от него, так как зачастую он переходит в бесконечные жалобы на отсутствие денег. У меня всегда возникает вопрос: почему бы не оторвать пятую точку и не пойти работать? Хоть в тот же макдак, хоть на стройку, потерпеть месяц, зато потом можно приобрести парочку плат, которых хватит на ближайший год. Да я знаю, что маленьких городах и селах сложно найти работу, переезжайте в большой город. Работайте на удаленке, в общем нужно крутиться. Просто жаловаться нет смысла, выход из ситуации есть, кто ищет его тот находит.
13. В ту же копилку внесу очень болезненный вопрос инструмента. Инструмент должен позволять вам максимально быстро разрабатывать устройства. Почему то очень многие разработчики не ценят свое время. Типичный пример, дешевая обжимка для клемм, на которой так любят экономить многие работодатели. Проблема в том, что она даже обжимает не правильно, из-за этого провода вываливаются. Приходится производить кучу дополнительных манипуляций, соответственно тратить время. Но как известно дурак платит трижды, поэтому низкая цена кримпера возрастет во много раз, за счет затрачиваемого времени и плохого качества обжима.
Не говорю что дешевое = плохое, нет — все зависит от ситуации. Вернусь к примеру кримпера, было время когда обжимал чем попало, поэтому часто возникали проблемы. Особенно неприятно, когда заводишь плату и она не работает, после долгих поисков ошибки понимаешь что из-за плохо обжатого проводочка, обидно. С тех пор как появилась нормальная обжимка этих проблем нет. Да внутренняя жаба и квакала, и душилась от ее стоимости, но ни разу не пожалел об этом решении. Все что я хочу сказать, что поработав с нормальным инструментом, совершенно не хочется возвращаться к плохому, даже не хочется обсуждать это. Как показывает практика, лучше не экономить на инструментах, если сомневаетесь — возьмите у кого нибудь потестить, почитайте отзывы, обзоры.
14. Заведите сайт, можно писать на нем, что угодно, просто как записки. Практика показывает, что работодатели все равно его не читают, но сам факт производит большой эффект.
15. Тонкий вопрос: профильное высшее образование, нужно ли оно? Мне известны не единичные случаи, когда люди работали абсолютно без образования и по опыту и знаниям они могли дать прикурить любому дипломированному специалисту. Собственно, у меня нет профильного образования, испытываю ли я от этого дискомфорт? В определенной степени да.
Еще в самом начале, когда микроконтроллеры были для меня хобби, я много помогал с курсовыми и дипломами разных вузов, просто чтобы оценить свой уровень. Могу сказать уверенно, что уровень в целом невысок вне зависимости от имени вуза. Учиться несколько лет, для того чтобы написать такой диплом, совершенно необязательно. Достигнуть этого можно самостоятельно за весьма короткий срок. И все же зачастую бывали моменты, когда студенты знали какой то предмет, который они проходили на 2-3 курсе, а я этого не знал. Хоть все эти знания и компенсировались самообразованием, но все же лучше было бы не тратить на это время.
Вуз ради бумажки. Могу сказать, что были и такие ситуации, когда предлагали работу, которая требовала обязательного наличия образования и было обидно, что именно в тот момент бумажки не было. Но в целом, история показывает, что большинству работодателей наплевать на вашу бумажку.
Следующий момент довольно часто не учитывается, это окружение. Не забывайте, что люди, с которыми вы учитесь это ваше поколение, не исключено что вам с ними работать. Количество фирм работающих в одной отрасли сильно ограничено. Практика показывает, что даже в больших городах все и все друг о друге знают, вплоть до интимных подробностей.
Еще один момент это возможности. Зачастую у вузов есть свои возможности — оборудование, может какие то секции, может какие то программы работы за рубежом, этим нужно пользоваться, если есть хоть малейшая возможность. Если в вузе вы не видите перспективы, идите в другой, мир на каком то одном не заканчивается.
Если подытожить то совет таков: если есть хоть малейшая возможность — нужно идти учиться, обязательно по профилю, если есть хоть какие то шансы, то лезть везде, а не отсиживать штаны на задней парте. Заводить знакомства, параллельно дома самому практиковаться, развиваться.
16. Поздно ли начинать программировать в 20, 30, 40, 50 лет? Практика других людей показывает, что возраст вообще не помеха. Многие почему то не учитывают то, что есть целый пласт работы, которую молодые в силу своих амбиций не хотят делать. Поэтому работодатели предпочитают брать тех, кто будет ее тащить. Это ваш шанс зацепиться, а дальше все зависит только от вас.
И последний совет. Многие радиолюбители необщительные, сердитые и раздражительные — считайте это спецификой работы. Излучайте добро и позитив, будьте хорошим человеком.
как работать с такой платой ?
что? где? когда?
хрустальный шар сломался :(
ну не шар сломался немогу с ней разобратся
#include <Wire.h> #include <Eeprom24C01_02.h> #define EEPROM_ADDRESS 0x50 static Eeprom24C01_02 eeprom(EEPROM_ADDRESS); int address = 0; void setup() { eeprom.initialize(); Serial.begin(9600); } void loop() { Serial.println("Write byte to EEPROM memory..."); eeprom.writeByte(address, 100); delay(10); Serial.println("Read byte from EEPROM memory..."); Serial.print("Read byte = "); Serial.print(address); Serial.print(" "); Serial.print(eeprom.readByte(address), DEC); Serial.println(""); }так записывал в 24С02
#include <Wire.h> #include <Eeprom24C01_02.h> #define EEPROM_ADDRESS 0x50 static Eeprom24C01_02 eeprom(EEPROM_ADDRESS); int address = 0; void setup() { eeprom.initialize(); Serial.begin(9600); } void loop() { Serial.println("Write byte to EEPROM memory..."); eeprom.writeByte(address, 100); delay(10); Serial.println("Read byte from EEPROM memory..."); Serial.print("Read byte = "); Serial.print(address); Serial.print(" "); Serial.print(eeprom.readByte(address), DEC); Serial.println(""); }а как по дш надо?, читаем дш
а где ёго найти то ...
в гугле забанили?
http://lib.chipdip.ru/021/DOC001021684.pdf
непомогло
я ищу скетч к ардуинке uno
вот вам работа с I2C
http://www.gammon.com.au/i2c
и обращайтесь напрямую, без библиотек
там есть пример
// Written by Nick Gammon // February 2011 // Note: maximum address is 0x7FFF (32 Kbytes) #include <Wire.h> const byte rom = 0x50; // Address of 24LC256 eeprom chip void setup (void) { Serial.begin (9600); // debugging Wire.begin (); // test: write the number 123 to address 0x1234 writeEEPROM (rom, 0x1234, 123); // read back to confirm byte a = readEEPROM (rom, 0x1234); Serial.println (a, DEC); // display to confirm // test: write a string to address 0x1000 byte hello [] = "Hello, world!"; writeEEPROM (rom, 0x1000, hello, sizeof hello); // read back to confirm byte test [sizeof hello]; byte err = readEEPROM (rom, 0x1000, test, sizeof test); Serial.println ((char *) test); // display to confirm } // end of setup void loop() {} // no main loop // write len (max 32) bytes to device, returns non-zero on error // return code: 0xFF means buffer too long // other: other error (eg. device not present) // Note that if writing multiple bytes the address plus // length must not cross a 64-byte boundary or it will "wrap" byte writeEEPROM (byte device, unsigned int addr, byte * data, byte len ) { byte err; byte counter; if (len > BUFFER_LENGTH) // 32 (in Wire.h) return 0xFF; // too long Wire.beginTransmission(device); Wire.write ((byte) (addr >> 8)); // high order byte Wire.write ((byte) (addr & 0xFF)); // low-order byte Wire.write (data, len); err = Wire.endTransmission (); if (err != 0) return err; // cannot write to device // wait for write to finish by sending address again // ... give up after 100 attempts (1/10 of a second) for (counter = 0; counter < 100; counter++) { delayMicroseconds (300); // give it a moment Wire.beginTransmission (device); Wire.write ((byte) (addr >> 8)); // high order byte Wire.write ((byte) (addr & 0xFF)); // low-order byte err = Wire.endTransmission (); if (err == 0) break; } return err; } // end of writeEEPROM // write one byte to device, returns non-zero on error byte writeEEPROM (byte device, unsigned int addr, byte data ) { return writeEEPROM (device, addr, &data, 1); } // end of writeEEPROM // read len (max 32) bytes from device, returns non-zero on error // return code: 0xFF means buffer too long // 0xFE means device did not return all requested bytes // other: other error (eg. device not present) // Note that if reading multiple bytes the address plus // length must not cross a 64-byte boundary or it will "wrap" byte readEEPROM (byte device, unsigned int addr, byte * data, byte len ) { byte err; byte counter; if (len > BUFFER_LENGTH) // 32 (in Wire.h) return 0xFF; // too long Wire.beginTransmission (device); Wire.write ((byte) (addr >> 8)); // high order byte Wire.write ((byte) (addr & 0xFF)); // low-order byte err = Wire.endTransmission (); if (err != 0) return err; // cannot read from device // initiate blocking read into internal buffer Wire.requestFrom (device, len); // pull data out of Wire buffer into our buffer for (counter = 0; counter < len; counter++) { data [counter] = Wire.read (); } return 0; // OK } // end of readEEPROM // read one byte from device, returns 0xFF on error byte readEEPROM (byte device, unsigned int addr ) { byte temp; if (readEEPROM (device, addr, &temp, 1) == 0) return temp; return 0xFF; } // end of readEEPROMнаверно этот пример ?
ну и?
за вас я писать не буду, по этой ссылке вы сможете понять принцип работы I2C
я непрошу за меня писать
этот пример рабочий
тут адресация другая не такая как 24С02
а почему должно соответствовать? другая память, другие принципы работы
так благодаря вашему примеру понял почему непишится туда нечего
"пилите Шура, пилите" :)
не помогу, читаем пример и вдумываемся
когда поймете, жить легче станет:)
ну в этом как то я и несомневался
ну извини, надо мозг включать, оссобенно с новым поколением, которые даже думать не хотят или не могут
так я контроллер купил недавно
язык програмирования незнаком
вот тренируюсь на примерах
я тоже 3 месяца назад купил первый и?
дустрочный дисплей подключал работает с реле разобрался и цифровым датчиком температуры тоже недолго мучился
вот с одной епром разобрался ну которая 24с02
с 24с256 пока ещё разбираюсь но вы продвинули процесс
ещё есть датчик влажности грунта по ним вот ничего ненашел
в гугле пока ненагуглил
я все делаю сам, читаю даташиты, пытаюсь понять принцип работы, и никогда не спрашиваю у кого нибуть, если только ради прикола,,,,,,,,,,
прямо гений ....
приколы так же гуглишь ?
grbox, без наездов. Нужен готовый скетч -> "Ищу исполнителя". Хотите сами разобраться - Вам дали ссылку.
форум создан для общения или вот этого гения с приколами ????
если следовать его параметрам то форум просто ненужен или просто человек нечем неможет помочь и хвастается своей некомпетентностью
с вашей помощью сложно в чём либо разобратся ваш коментарий вообще не потеме
Если Вас нужно ткнуть носом в решение - я сказал, куда обращаться. А по ссылке, которой с вами любезно поделились, расписано даже больше, чем надо.
http://habrahabr.ru/post/274601/ Изучайте.
Советы начинающим программистам микроконтроллеров https://habracdn.net/habr/images/1451404126/flags.png?r=55) 100% -25px no-repeat;" title="Перейти в песочницу">из песочницы
Вы молодец, умеете копировать текст-Вы это хотели нам показать? Я эту статью читал, и не раз.
ну как то вы сильно напряглись тыкать ссылками я подтянул инфу ближе чтобы неутруждались )))
#include <Wire.h> #define i2caddr 0x50 byte d=0; void setup() { Serial.begin(115200); Wire.begin(); Serial.println("Writing data..."); for (int i=0; i<255; i++) { writeData(i,(255-i)); } Serial.println("DONE"); } void writeData(unsigned int addr, byte data) { Wire.beginTransmission(i2caddr); // set the pointer position Wire.write((int)(addr >> 8)); Wire.write((int)(addr & 0xFF)); Wire.write(data); Wire.endTransmission(); delay(10); } void loop() { }как видите с кодом разобрался
теперь ищу как преобразовать из ячеек памяти данные в символы
желаете помочь ?
